[Live-demo] [OSGeo] #1522: GeoNetwork 3.0.1 fails to start in a VM
OSGeo
trac_osgeo at osgeo.org
Sun Aug 30 03:15:43 PDT 2015
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: critical | Milestone: OSGeoLive9.0
Component: LiveDVD | Resolution:
Keywords: |
Comment (by fxp):
> So, I understand that providing the database binary now works fine
After further testing of last build with different VM configuration, I
would say:
* use GN3 on a virtual box with at least 3+Go RAM (as it looks like
startup issues are mainly related to memory troubles) - 1Go does not
start, 2Go sometimes starts.
* on first startup, it still create the database and load default data so
it takes some times.
* sometimes (not sure exactly when and why) it refresh the JS cache and
needs memory for that
* ImageIO, it looks related to JDK version and the imageio version used
(first time this issue is observed AFAIK). Removing imageio from the lib
folder fix the issue:
/usr/local/lib/geonetwork/bin$ rm ../web/geonetwork/WEB-
INF/lib/jai_imageio-1.1.jar
Once you have an application running with a default db and a JS cache
populated, startup and using the application is fast.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1522#comment:13>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
