[Live-demo] [OSGeo] #1474: Sahana fails to install due to web2py error
OSGeo trac_osgeo at osgeo.org
Thu Feb 12 17:51:49 PST 2015
 Reporter:  kalxas    |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  OSGeoLive8.5
Component:  LiveDVD   |    Keywords:  sahana
 Similar to sahana, web2py has been used from git master so far, with no
 tagged releases. Apparently a recent change in master broke our
 installation:
   File "web2py.py", line 18, in <module>
     import gluon.widget
   File "/usr/local/lib/web2py/gluon/__init__.py", line 29, in <module>
     "You can also download a complete copy from http://www.web2py.com."
 RuntimeError: web2py depends on pydal, which apparently you have not
 installed.
 Probably you cloned the repository using git without '--recursive'
 To fix this, please run (from inside your web2py folder):
     git submodule init && git submodule update
     import gluon.widget
 installed.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1474>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
