[Live-demo] Local installation
Cameron Shorter cameron.shorter at gmail.com
Thu Jan 8 13:28:35 PST 2015
Hi Pietro,
Could you please provide some context to help with locating the problem.
Which version of OSGeo-Live are you using?
What process did you follow to install OSGeo-Live?
If you have not already tried it, I suggest following this process:
http://live.osgeo.org/en/quickstart/osgeolive_install_quickstart.html
We usually test by installing OSGeo-Live into a VirtualMachine (for me,
I use VirtualBox).
It is possible this tip from the docs might be relevant:
Tip
Installation Tips In case you are installing using a username other than
“user”, tomcat applications require to have permission to service
command as described inhttp://trac.osgeo.org/osgeo/ticket/1153
On 9/01/2015 7:41 am, Brian M Hamlin wrote:
>     Hi Pietro -
>    I am late to this thread, so there may be details I have missed,
> however...  I have OSGeo-Live 8.5 a3 installed into a VirtualBox vmdk.
> Geoserver works
>    -Brian
> On Thu, 8 Jan 2015 10:37:07 +0000 (UTC), Pietro Blu Giandonato
> <p.giandonato at gmail.com> wrote:
> Hi all,
>  > Cameron Shorter <cameron.shorter at ...> writes:
>  > > Hi Giuseppe,
>  > > I suspect that you have not started GeoServer?
>  > > Steps for running geoserver are explained in the
> Quickstart:http://live.osgeo.org/en/quickstart/geoserver_quickstart.html
>  > I have the same issue: after installing OSGEO Live on a machine,
>  > Geoserver doesn't work at all, even after starting it manually.  >
>  > > Note, you are also looking on the wrong port:
>  > http://localhost:8082/geoserver/webOn
>  > Looking at it, at http://localhost:8082/geoserver/web this is what is
>  > issued:
>  > HTTP ERROR: 404
>  > NOT_FOUND
>  > RequestURI=/geoserver/web/
>  > Powered by jetty://
>  > I've searched around the web for some hint, other users are
> experiencing
>  > the same, but didn't find any solution.  >
>  > The weird thing is that starting OSGEO Live DVD, Geoserver works
>  > smoothly. The problem arise after local installation of the entire
>  > suite.  >
>  > Is there any solution possible?
>  > Thanks,
>  > Pietro Blu
>  > 3/01/2015 5:56 am, Giuseppe wrote:
>  > > After I install osgeo live 8 on local hd, geoserver don't start.
>  > I tried localhost and 127.0.0.1.  > > Why?
>  > > _______________________________________________
>  > > Live-demo mailing list
>  > > Live-demo at lists.osgeo.org
>  > > http://lists.osgeo.org/mailman/listinfo/live-demo
>  > > http://wiki.osgeo.org/wiki/Live_GIS_Disc
>  > > Cameron Shorter,
>  > > Software and Data Solutions Manager
>  > > LISAsoft
>  > > Suite 112, Jones Bay Wharf,
>  > > 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>  > > P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
>  > > <div>
>  > > Hi Giuseppe,<br>
>  > > I suspect that you have not started GeoServer? <br><br>
>  > > Steps for running geoserver are explained in the Quickstart:<br><a
>  > class="moz-txt-link-freetext"
> href="http://live.osgeo.org/en/quickstart/geoserver_quickstart.html">htt
>  > p://live.osgeo.org/en/quickstart/geoserver_quickstart.html</a><br><br>
>  > > Note, you are also looking on the wrong port:<br><a
>  > class="reference external"
> href="http://localhost:8082/geoserver/web">http://localhost:8082/geoserv
>  > er/web</a><br><br><div class="moz-cite-prefix">On 3/01/2015 5:56 am,
>  > Giuseppe wrote:<br>
>  > > </div>
>  > > <blockquote cite="mid:5A291148-8BC3-4E09-8B14-F97CA9FBAA30 at ..."
>  > type="cite">
>  > > <a class="moz-txt-link-abbreviated"
> href="mailto:Live-demo at ...">Live-
>  > demo at ...</a>
>  > > <a class="moz-txt-link-freetext"
>  > href="http://lists.osgeo.org/mailman/listinfo/live-
>  > demo">http://lists.osgeo.org/mailman/listinfo/live-demo</a>
>  > href="http://live.osgeo.org">http://live.osgeo.org</a>
> href="http://wiki.osgeo.org/wiki/Live_GIS_Disc">http://wiki.osgeo.org/wi
>  > ki/Live_GIS_Disc</a>
>  > > </blockquote>
>  > > <br>--
>  > > Cameron Shorter,
>  > > LISAsoft
>  > > P +61 2 9009 5000, W <a class="moz-txt-link-abbreviated"
>  > href="http://www.lisasoft.com">www.lisasoft.com</a>, F +61 2 9009 5099
>  > > </div>
> Brian M Hamlin
>  OSGeo California Chapter
>  blog.light42.com
Cameron Shorter,
LISAsoft
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20150109/84a6c20f/attachment.html>
More information about the Live-demo mailing list
