[Live-demo] [OSGeo] #1394: uDig: fails to start on first launch
OSGeo trac_osgeo at osgeo.org
Fri Jan 23 14:57:05 PST 2015
 Reporter:  hamish    |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  OSGeoLive8.5
Component:  LiveDVD   |    Keywords:  udig
Comment(by jive):
 Checking the provided core dump this failure is happening outside of the
 Java VM .. so I am expecting a change of operating environment ...
 uDig has two things that hit native code:
 * Java (looks like OpenJDK is used)
 * SWT (this integrates with the operating system to create widgets)
 The initial bug discussion (and deleting the .metadata folder idea) does
 not seem on the right track as this is a "working directory" for the
 plugin system....
 Has OSGeo live updates operating systems or version of Java used recently?
 I would like to check that it is running a supported environment....
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1394#comment:7>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
