[Live-demo] Report 5 - Integration of geospatial OSS in educational notebooks
epi massimodisasha at gmail.com
Tue Jun 30 04:51:18 PDT 2015
Hi Johan,
thank you for you feedback!
I was planning to use Fiona and Shapely later on on int eh map algebra and vector processing notebooks, I forgot about RasterIO (great lib!).
I wanted to start low level (gdal-python) to then use high level tools to perform more complex workflow, for this I was thinking to use Fiona and Shapely in the "Map algebra section” and “ vector geoprocessing".
But thanks for your advice, I definitely agree with you, It is better to have Fiona, RasterIO and Shapely introduced in the  “Access geospatial data” section In a dedicated notebook after goal-python. And then re-use them in the following notebooks.
Thanks,
Massimo.
> On Jun 30, 2015, at 5:46 AM, Johan Van de Wauw <johan.vandewauw at gmail.com> wrote:
>> Week 5 report
>> What have I completed this week?
>> working on introductive notebook (note the hyperlink doesn't work on git,
>> they are supposed to work inside the live as they point to relative paths)
>> I revisited the notebook layout, the first topic (I/O) is now dedicated to
>> Access to Geospatial Data and will include 3 main notebooks:
>> GDAL/OGR Quickstart - bash) almost finished
>> Introduction to GDAL Python bindings (studing here)
> Perhaps it is a better idea to use fiona and rasterio for this
> tutorial? They hide a lot of the low-level details of GDAL. They will
> be present on the live dvd.
> Kind Regards,
> Johan
More information about the Live-demo mailing list
