[Live-demo] qgis 2.6.1 pluging for grass7
Giuseppe Amatulli giuseppe.amatulli at gmail.com
Thu May 21 06:49:44 PDT 2015
we are close to use the OSGeo-Live 8.5 for several workshop (info
<http://www.spatial-ecology.net>) and I would like to know if the
OSGeo-Live 8.5 support the  QGIS 2.6.1 pluging for grass7?
With the default installation, in QGIS i can see the Grass7 commands in the
processing toolbox but there is not the grass-pluging which allows to open
grass data in QGIS.
If i run apt-get install qgis-plugin-grass the command install grass64 and
qgis-plugin-grass. The grass plugin is visible in QGIS but if i open QGIS
inside grass command line ( GRASS 7.0.0 (loc_rast_small):~ > qgis & )
everything collapse.
Do you know if the OSGeo-Live 8.5 supports the qgis-plugin-grass for GRASS7
and if yes may be available trough the ppa:osgeolive/release-8.5?
Thanks
Best Regards
Giuseppe Amatulli, Ph.D.
Department of Ecology and Evolutionary Biology, Yale University.
Jetz Lab, OML Room 405
P.O. Box 208106
165 PROSPECT ST
New Haven, CT 06520-8106
Teaching: spatial-ecology.net
Work:  http://sbsc.yale.edu/giuseppe-amatulli
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20150521/02c62a94/attachment.html>
More information about the Live-demo mailing list
