[Live-demo] Starting build cycle for OSGeo-Live 9.0
Sebastiaan Couwenberg
sebastic at xs4all.nl
Fri May 22 16:05:18 PDT 2015
On 05/23/2015 12:51 AM, Johan Van de Wauw wrote:
> On Sat, May 23, 2015 at 12:23 AM, Sebastiaan Couwenberg
> <sebastic at xs4all.nl> wrote:
>> On 05/22/2015 11:16 PM, Johan Van de Wauw wrote:
>>> On Fri, May 22, 2015 at 9:26 PM, <mail at activityworkshop.net> wrote:
>>>> But if I look at the "gpsprune" package, I can see version 15.1 in Trusty,
>>>> 17.1 in Vivid, 17.2 in Debian stable-backports, but only 10.1 in
>>>> ubuntugis-unstable (unless I'm reading it wrong). So does that mean for
>>>> gpsprune, OSGeoLive will continue to include version 15.1 for the next
>>>> release? Unless somebody at ubuntugis does some repackaging or backporting
>>>> or something?
>>> I had a look to backport gpsprune.
>>> It will also require a backport of libmetadata-extrI wiactor-java, which
>>> in turn will break josm, so that will need an update as well (which is
>>> probably a good idea, the version in trusty is old.
>>> But this requires also an update to jmapviewer.... (I have not yet
>>> looked further).
>> Just backport gpsprune (17.2-1) like I did for jessie-backports.
>> gpsprune (17.2-2~exp1) only has a patch for libmetadata-extractor-java
>> 2.7.2.
>> gpsprune 18 is expected to include this patch, so it will need to be
>> reverted in future backports to not require the
>> libmetadata-extractor-java update.
> It is not just the latest update. Trusty has
> libmetadata-extractor-java (2.3.1+dfsg-2) while gpsprune requires >=2.6.4
> I suppose there was a good reason to add that requirement, though I
> could not find it in the debian commit log.
Yes, that was the previous libmetadata-extractor-java update and the
associated API breakage. See the related discussion in the BTS:
https://bugs.debian.org/725186
libmetadata-extractor-java updates tend to requires changes in its
reverse dependencies: josm, gpsprune & tika. The latter is maintained by
the Java team like libmetadata-extractor-java itself.
> Anyway, updating josm seems a good thing to do anyway.
Yes, I'd also like to get the experimental version into unstable. Just
beware that until JCS is packaged (#783538) no further updates to josm
are possible in Debian and derivatives.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
More information about the Live-demo
