[Live-demo] OSGeo live - osm2x3d
clement at igonet.fr clement at igonet.fr
Sun May 31 14:50:13 PDT 2015
Yes, a deb file will be provided soon.
Thank you for the advice.
Clément.
Le 31 mai 2015 22:27:27 UTC+02:00, Angelos Tzotsos <gcpp.kalxas at gmail.com> a écrit :
>There is no reason for disappointment.
>I would suggest to prepare an installer for the project (or even better
>a deb file), to make it easy for users to install and try your software
>from within the Live VM.
>Then we can add the installer in our beta area and we can reconsider
>for
>later releases.
>Best,
>Angelos
>On 05/31/2015 03:12 PM, clement at igonet.fr wrote:
>> I'm sad...
>> Le 31 mai 2015 14:10:07 UTC+02:00, Cameron Shorter
><cameron.shorter at gmail.com> a écrit :
>>> Hi Clement,
>>> Thanks for answering the questions below. It is very helpful for
>>> understanding the maturity of a project.
>>> My initial assessment is that the project looks to be showing a lot
>of
>>> promise, but is probably not ready yet for OSGeo-Live.
>>> OSGeo-Live's core aim is to help new users find established Open
>Source
>>> GIS applications on OSGeo-Live, which is good for the established
>>> projects, but unfortunately a bit hard on new projects looking to
>find
>>> users.
>>> I'd encourage you to continue working to attract a user and
>developer
>>> community, as you appear to be doing. You might also align with an
>>> existing established project, which in turn will help you adopt
>their
>>> community.
>>> You are also welcome to write OSGeo-Live installer scripts for
>osm2x3d.
>>> Other projects have done this in the past, including the installer
>>> scripts a few releases before actually being included on OSGeo-Live.
>>> This made it easy to set up the application on OSGeo-Live to be run
>as
>>> a
>>> base for workshops or similar, and helps build up a community and
>show
>>> robustness of the application.
>>> I suggest you also look at the OSGeo Incubation process [1].
>Although
>>> your project might not be ready to go through the process yet, it is
>a
>>> good thing to be thinking about as your grow your project and are
>>> putting processes in place, such that it is easier to incubation
>when
>>> you are ready.
>>> Kind regards,
>>> Cameron
>>> [1]
>http://www.osgeo.org/incubator/process/project_graduation_checklist.html
>>> On 31/05/2015 8:53 am, Clément Igonet wrote:
>>>> On 2015-05-24 05:12, Cameron Shorter wrote:
>>>>> On 24/05/2015 7:33 am, clement at igonet.fr wrote:
>>>>>> May we add osm2x3d command line tool to the distribution?
>>>>>> I'm the author of this open and free project.
>>>>>> Clement Igonet
>>>>> Hi Clement,
>>>>> Nice to hear your interest in joining OSGeo-Live.
>>>>> I'm moving your request across to the OSGeo-Live email list.
>>>>> I'm interested to know more about osm2x3d to see if it fits in
>with
>>>>> our project selection criteria.
>>>>> Why don't you have a look at our selection criteria, and if you
>>> think
>>>>> your project qualifies, and you are up to putting in the effort
>>>>> required to bring the project onto OSGeo-Live, then fill out the
>>>>> application form and email to our OSGeo-Live list.
>>>>> Your timing is good, as we are just starting the build process for
>>>>> OSGeo-Live 9.0.
>>>>> Details here:
>http://wiki.osgeo.org/wiki/Live_GIS_Disc#How_to_add_a_project_to_OSGeoLive
>>>> Hi Cameron,
>>>> Questions I have answered for requesting to add an application to
>>>> OSGeo-Live:
>>>> What is its name?
>>>> osm2x3d
>>>> What is the home page URL?
>>>> http://wiki.openstreetmap.org/wiki/Osm2x3d
>>>> Which OSI approved Open Source Licence is used?
>>>> GPL v3 in licenses/gpl.txt
>>>> What does the application do and how does it add value to the
>>>> GeoSpatial stack of software?
>>>> osm2x3d converts Open Street Map xml data to X3D file, exploiting
>>>> buildings info like elevation, number of floors, roof type, etc...
>>>> It is comparable to OSM2World but osm2x3d is focused on X3D format
>>> and
>>>> aims to provide access to building indoor, using a project like
>Open
>>>> Earth View (3D web navigation with x3dom javascript library).
>>>> Next features:
>>>>     - building textures,
>>>>     - link with floor plan in SVG format,
>>>>     - link with Point of Interest for a given floor
>>>> Does the application make use of OGC standards?
>>>> It makes use of OSM xml data and X3D format.
>>>> Client or server?
>>>> It is a command line tool and can be used in client or server side.
>>>> What language is it written in?
>>>> osm2x3d is currently written in C++ language, using some boost
>>> features.
>>>> Which version of the application should be included in the next
>>>> OSGeo-Live release?
>>>> V1.0.0
>>>> OpenHUB:
>>>> "Account creation is temporarily suspended".
>>>> What is the size of the user community?
>>>> This project has been presented in OSGeo, framasoft, X3D and x3dom
>>>> mailing lists.
>>>> osm2x3d is used by Open Earth View project.
>>>> What is the size of your developer community?
>>>> One person at the moment.
>>>> Do you have a bug free, stable release?
>>>> Bug free, but restricted features.
>>>> Please discuss the level of testing that your project has gone
>>> through.
>>>> osm2x3d is a command line tool.
>>>> As a black box, it gets OSM xml data as input and provide 3D scene
>>>> file (X3D file format) as output.
>>>> Is has been tested using several kind of OSM xml data.
>>>> How long has the project has had mature code.
>>>> The architecture os the code is mature, but osm2x3d, as a very
>basic
>>>> tool (using linux command line), will be continuously improved
>adding
>>>> lot of new features.
>>>> Manual:
>>>> This tool is a converter from Open Street Map xml data file to X3D
>>>> scene graph for buildings.
>>>> Usage:
>>>>      osm2x3d.uexe -i/--input INPUT -o/--output OUTPUT
>>>>      cat INPUT | osm2x3d.uexe > OUTPUT
>>>> Example :
>>>> $ osm2x3d.uexe -i esb.osm -o result.x3d --verbose
>>>> Options :
>>>> -h / --help             print this help
>>>> --verbose / --brief     verbose / brief mode
>>>> -s / --noStrictBounds   permissive bounds mode
>>>> -t / --noTile           no OSM png tile
>>>> -i / --input            Open Street Map xml input file
>>>> -o / --output           X3D xml scene graph. Default is
>"result.x3d"
>>>> on working
>>>>                          directory
>>>> -l / --LoD              Level of Detail (Building, BuildingPart)
>>>> Project presentation:
>>>> Friday june 19th (17:00 PM), in Paris, PSES (Pas Sage En Seine).
>>>> I'm volunteer to be responsible for ensuring the install scripts.
>>>> I'm volunteer to update English documentation for each OSGeo-Live
>>>> release.
>>>> I will act as the project's liaison person.
>>>> Application installation:
>>>> I need to discuss how my application will be installed.
>>>> For sure, osm2x3d runs in 512 Meg of RAM.
>>>> Disk space to install the application and a suitable example
>>>> application: about 1 MB.
>>>> My project overview is available under a CC By and a Quickstart
>>>> available under a CC By-SA license.
>>> Cameron Shorter,
>>> Software and Data Solutions Manager
>>> LISAsoft
>>> Suite 112, Jones Bay Wharf,
>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>Angelos Tzotsos
>Remote Sensing Laboratory
>National Technical University of Athens
>http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20150531/d72eba5b/attachment-0001.html>
More information about the Live-demo mailing list
