[Live-demo] Submit New Project - MapIgniter2
Paragon Corporation lr at pcorp.us
Fri Nov 27 22:35:15 PST 2015
Clement,
That is a pretty harsh statement to make.  But sadly you are more or less correct.  The main issue being there are probably a ton of new promising open source GIS projects
And since the LiveDemo initiative is to spread the FOSS4G gospel and is created by volunteers, it does mean that they have to pick what is most commonly used and easy to get up and going and things the group expects will be easy for users to grasp and run with.
That said though, I think there is room for new projects with not a large community and LiveDemo can help enlargining that community. LiveDemo group needs to weigh in on the benefit of including such a project as well as how much additional disk space it would take up on the OSGEO Live cd, as well as how well it plays with other things already on the cd.
So in the case of Marco's project, my suspicion is that his doesn't add too much additional weight – I could be mistaken though, because I forget what's on LiveCD already.
So Marco's builds on OpenLayers, Laravel, CodeIgnite (both of Laravel and CodeIgnite anre PHP frameworks so just PHP scripts), JQuery, AnuglarJS  (both JQuery and AngularJS are just a bunch of javascript files).  It can use Apache which I think is already on the CD.
I don't recall if the CD has PHP already. I presume it does since I think GeoMoose requires it.  It can use Mapserver, PostGIS, GeoServer data sources which are already on the CD.
So from my vantage point, all the services Marco's app needs to work (including data) are already on the CD.
So that said, I think aside from judging how large a community is to decide if it deserves to be on OSGEO-Live we should also consider
a)      How much of a foot-print does the project app add to the CD?
b)      How much of things already on the CD can a project app take advantage of?
c)       Are the developer's (or somebody) willing to put in the work to get it on the CD and maintain it on the CD?
d)      How redundant is it with other things on the Cd.  In case of Marco's app one may consider there is a lot of overlap with GeoMoose for example.  Though GeoMoose at a glance strives to be more ambitious, which may turn off people looking for something a bit lighter they can more easily integrate in a larger application.
e)      Licensing of course
As a user looking at OSGeo for the first time, I may not have any experience with anything GIS related.  I may actually have more experience with PHP and AngularJS than anything else. So just because GeoServer or MapServer are the big kings in OSGeo doesn't mean they will be seen as such from a newbie webdeveloper's perview.  They'll jump at something that looks more familiar to them, which could very well be Mario's app.
Sidenote – when I was starting out in GIS, I got turned on to MapServer first cause hey it's this executable I can load shapefiles with and I can run in Microsoft IIS (that's all I knew and cared).  That turned me on to PostGIS, hey it’s a database thingy I already know cause I'm an SQL guru :) and it works with Mapserver, and I can finally get rid of those stupid shapefiles or generate them automagically. Didn't care no one else had heard about it, meant I could use the knowledge I had already to get stuff done.
Thanks,
Regina
From: Live-demo [mailto:live-demo-bounces at lists.osgeo.org] On Behalf Of clement at igonet.fr
Sent: Saturday, November 28, 2015 12:43 AM
To: Cameron Shorter <cameron.shorter at gmail.com>; Marco Afonso <mafonso333 at gmail.com>; live-demo at lists.osgeo.org
Subject: Re: [Live-demo] Submit New Project - MapIgniter2
That's the answer I got for OpenEarthView project...
OsGeoLive is made for user only, not at all to help starting promising projects.
That's frustrating.
They get the good part of free and open source projects, refusing to take the risk of helping new ones.
What to say... That's not the open source (and open mind) philosophy...
Le 26 novembre 2015 19:28:14 UTC+01:00, Cameron Shorter <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com> > a écrit :
Hi Marco,
It sounds like you have the start of a good project.
However, my feeling is that has not yet reached the maturity of the other projects we have on OSGeo-Live.
In particular, we help new users answer the questions:
* What good open source GIS projects are out there?
* What is everyone else using?
What I suggest working on is getting a stronger answer to the second question.
Aim to build up a community behind your project.
Look to get your project used by many organisations.
Aim to attract developers from these organisations.
I know this is a tough ask, and often takes years to attract such a community.
But attracting a community is the true test of whether a project is valuable or not.
Apache has a good page about building a community which might be worth a read:
http://incubator.apache.org/guides/community.html
On 26/11/2015 6:39 am, Marco Afonso wrote:
Hello Alex,
Thank you for your reply.
Follows the MapIgniter application request to integrate OSGeo Live. As we can see, this is a very recent project but with very good technological background to evolve and specially satisfy user needs.
I hope it can be accepted. If work has to be done, I'm on it!
Cheers,
Marco
Please describe your application.
What is its name?
It's name is MapIgniter2. The name came from previous release, where it was based on CodeIgniter PHP framework.
What is the home page URL?
The project's home is hosted on GitHub at https://github.com/taviroquai/mapigniter2
Which OSI approved Open Source Licence is used?
It uses the MIT license.
What does the application do and how does it add value to the GeoSpatial stack of software?
MapIgniter is a GeoCMS which combines web mapping features with Content Management System (CMS) features. It is a browser-based software, or more commonly refered as a web application. The main purpose of this software is to let users publish Geographic Information on the Internet / Intranet on a free and Open Source platform. Considering that there are other Open Source web mapping platforms, MapIgniter distinguishes it self, and adds value to GeoSpatial stack software, by being powered by cutting edge Javascript and PHP frameworks/libraries, providing the best tools for creating modern web applications.
Does the application make use of OGC standards? Which versions of the standards? Client or server? You may wish to add comments about how standards are used.
This software makes use of a subset of OGC standards; currently WMS and WFS. Specific version numbers can be configured by the user. MapIgniter backoffice interface allows to configure these OGC service parameters to be used by OpenLayers 3 (frontend web mapping library).
What language is it written in?
The default interface language is English. Also includes Portuguese language files. Any idiom can be added later. This is a feature of the PHP Laravel Architecture which is the PHP Framework that powers this software.
Which version of the application should be included in the next OSGeo-Live release?
MapIgniter2 targets release 1.0 for the next release of OSGeo-Live.
Stability is very important to us on OSGeo-Live. If a new user finds a bug in one application, it will tarnish the reputation of all other OSGeo-Live applications as well. (We pay most attention to the following answers):
If risk adverse organisations have deployed your application into production, it would imply that these organisations have verified the stability of your software. Has the application been rolled out to production into risk (ideally risk adverse) organisations? Please mention some of these organisations?
The number of organisations using MapIgniter2 is unknown. Mainly because this is a very recent software. Although, being MapIgniter built upon Laravel 5.1 and OpenLayers 3, these two frameworks have proven it's success in web development applications it's usage by a number of companies.
Please see
Laravel Jobs https://larajobs.com/?partner=5#/
Openlayers Sponsors http://openlayers.org/sponsors.html
Open HUB provides metrics to help assess the health of a project. Eg: http://adhoc.osgeo.osuosl.org/livedvd/docs/en/metrics.html Could you please ensure that your project is registered with Open HUB, and Open HUB has been updated to reference the correct code repository(s) for your project. What is the Open HUB URL for your project?
The Open Hub URL is https://www.openhub.net/p/mapigniter2
What is the size of the user community? You can often answer this by mentioning downloads, or describing a healthy, busy email list?
MapIgniter2 has no community yet. The previous release has 10 forks on GitHub, 19 starred and 9 people watching the repository. The Google groups has been some activity since 2012 until April 2015 from several users.
What is the size of your developer community?
Currently there is one developer.
Do you have a bug free, stable release?
Not yet.
Please discuss the level of testing that your project has gone through.
There will be automated tests in soon.
How long has the project has had mature code.
The project is very recent.
OSGeo-Live is targeted at applications that people can use rather than libraries. Does the application have a user interface (possibly a command line interface) that a user can interact with? (We do make an exception for Incubated OSGeo Libraries, and will include Project Overviews for these libraries, even if they don't have a user interface.)
Yes the software works on a web browser interface.
We give preference to OSGeo Incubated Projects, or Projects which are presented at FOSS4G conferences. If your project is involved in OSGeo Incubation, or has been selected to be presented at FOSS4G, then please mention it.
Previous release of MapIgniter was presented to the OSGeo Portuguese community on the 16th November 2012.
Please see
http://www.osgeo.org/node/1318
http://osgeopt.pt/eventos/sasig5.markdown/
With around 50 applications installed on OSGeo-Live, us core packagers do not have the time to liaise with every single project email list for each OSGeo-Live release. So we require a volunteer (or two) to take responsibility for liaising between OSGeo-Live and the project's communities. This volunteer will be responsible for ensuring the install scripts and English documentation are updated by someone for each OSGeo-Live release. Also test that the installed application and Quickstart documentation works as expected on release candidate releases of OSGeo-Live. Who will act as the project's liaison person.
OSGeo-Live is Ubuntu Linux based. Our installation preference is:
Install from UbuntuGIS or DebianGIS
Install .deb files from a PPA
Write a custom install script
Can you please discuss how your application will be installed.
MapIgniter is a web mapping application based on PHP Laravel 5.1 Framework. Laravel framework runs over Apache2 or Nginx web servers. MapIgniter system requirements matches Laravel 5.1 requirements.
MapIgniter install procedure is similar to Laravel install procedure. It can be manually installed by using the instructions documented in MapIgniter GitHub repository. Also, there is an install script (linux) that automates the install process. Just enter onto Apache public folder and run from shell curl https://raw.githubusercontent.com/taviroquai/mapigniter2/master/install.sh | sudo sh
Please see
Laravel Documentation http://laravel.com/docs/5.1
Install script https://github.com/taviroquai/mapigniter2/blob/master/install.sh
OSGeo-Live is memory and disk constrained. Can the application run in 512 Meg of RAM?
Yes.
How much disk space will be required to install the application and a suitable example application?
Approximately 38 Mbytes.
We aim to reduce disk space by having all applications make use of a common dataset. We encourage applications to make use of the example datasets already installed:
http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets If another dataset would be more appropriate, please discuss here. Is it appropriate, to remove existing demo datasets which may already be included in the standard release.
Examples datasets provided by OSGeo Live are fine to be used with MapIgniter. Optimum data is with native Web Mercator projection.
Each OSGeo-Live application requires a Project Overview available under a CC By and a Quickstart available under a CC By-SA license. (You may release under a second license as well). Will you produce this?
Yes.
In past releases, we have included Windows and Mac installers for some applications. It is likely we won't have space for these in future releases. However, if there is room, would you be wishing to include Windows and/or Mac installers?
Yes, Windows installer.
2015-11-25 17:01 GMT+00:00 Alex Mandel <tech_dev at wildintellect.com <mailto:tech_dev at wildintellect.com> >:
On 11/25/2015 08:24 AM, Marco Afonso wrote:
> Hi,
> I would like to submit a new project for OSGeo-Live.
> The project in case is MapIgniter2.
> Here is the home of the project: https://github.com/taviroquai/mapigniter2
> I would like to know what are the requirements and procedures to be
> accepted to integrate OSGeo Live.
Marco,
Reply to this thread with the answers to the following questions:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Apply
The expanded details of adding new projects is documented at:
Thanks,
Alex
Regards,
Marco Afonso
http://goo.gl/ZDtQjm
  <https://dl.dropboxusercontent.com/u/17607469/qr.png>
Live-demo mailing list
Live-demo at lists.osgeo.org <mailto:Live-demo at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/live-demo
http://live.osgeo.org
Cameron Shorter,
Software and Data Solutions Manager
LISAsoft
Suite 112, Jones Bay Wharf,
26 - 32 Pirrama Rd, Pyrmont NSW 2009
P +61 2 9009 5000,  W www.lisasoft.com <http://www.lisasoft.com> ,  F +61 2 9009 5099
  _____
clement at igonet.fr <mailto:clement at igonet.fr>
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20151128/ab69eead/attachment-0001.html>
More information about the Live-demo mailing list
