[Live-demo] IPython 4.0.0 and Jupyter ppa
Angelos Tzotsos gcpp.kalxas at gmail.com
Mon Feb 1 07:09:22 PST 2016
Hi, there is an updated build with some fixes:
http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build62-amd64-96cd3d3.iso
Best,
Angelos
On Mon, Feb 1, 2016 at 1:12 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
> Hi all,
> After some debugging (thanks Brian and Massimo), the Jupyter and IPython
> packages are working fine.
> In case you want to test, there is a new build available:
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build58-amd64-b81d61d.iso
> http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/9.5nightly/osgeo-live-nightly-build58-amd64-b81d61d.iso
> I will merge the pull request and then we can work on the ipython
> installer for the remaining details (launchers, converted notebooks etc).
> We also need to make a plan integrating Massimo's work from GSoC 2015,
> which has to be re-based to the new setup.
> Happy hacking,
> Angelos
> On 01/27/2016 04:41 PM, Angelos Tzotsos wrote:
>> Hi all,
>> I have prepared a ppa to include all the Jupyter and IPython libraries
>> that are pulled when someone does "pip install jupyter"
>> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/jupyter
>> I have a local git branch including the apt-get install command to get
>> those libraries in the system:
>> https://github.com/kalxas/OSGeoLive/commit/48292e078b2bace861dffbe3310ddfdde05ce078
>> Based on the above commit, I have prepared a nightly build:
>> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build32-amd64-48292e0.iso
>> http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/9.5nightly/osgeo-live-nightly-build32-amd64-48292e0.iso
>> We need a volunteer to check for any missing libraries and complete the
>> missing installation parts so that the notebook works again as expected.
>> Cheers,
>> Angelos
> Angelos Tzotsos, PhD
> OSGeo Charter Member
> http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20160201/def607a9/attachment.html>
More information about the Live-demo mailing list
