[Live-demo] [OSGeo] #1716: MapBender fails to start on Xenial
OSGeo trac_osgeo at osgeo.org
Fri Jun 3 13:31:50 PDT 2016
 Reporter:  kalxas     |       Owner:  live-demo@…
     Type:  defect     |      Status:  new
 Priority:  blocker    |   Milestone:  OSGeoLive10.0
Component:  LiveDVD    |  Resolution:
 Keywords:  mapbender  |
Comment (by kalxas):
 From build log:
 2016-06-03 12:23:08 (246 MB/s) - 'mapbender3-3.0.5.3_parameters.yml' saved
 [1072/1072]
 PHP Fatal error:  Uncaught Error: Class 'DOMDocument' not found in
 /var/www/html/mapbender3/vendor/symfony/symfony/src/Symfony/Component/Config/Util/XmlUtils.php:52
 Stack trace:
 #0
 /var/www/html/mapbender3/vendor/symfony/symfony/src/Symfony/Component/DependencyInjection/Loader/XmlFileLoader.php(207):
 Symfony\Component\Config\Util\XmlUtils::loadFile('/var/www/html/m...',
 Array)
 #1
 /var/www/html/mapbender3/vendor/symfony/symfony/src/Symfony/Component/DependencyInjection/Loader/XmlFileLoader.php(39):
 Symfony\Component\DependencyInjection\Loader\XmlFileLoader->parseFile('/var/www/html/m...')
 #2
 /var/www/html/mapbender3/vendor/symfony/symfony/src/Symfony/Bundle/FrameworkBundle/DependencyInjection/FrameworkExtension.php(42):
 Symfony\Component\DependencyInjection\Loader\XmlFileLoader->load('web.xml')
 #3
 /var/www/html/mapbender3/vendor/symfony/symfony/src/Symfony/Component/DependencyInjection/Compiler/MergeExtensionConfigurationPass.php(50):
 Symfony\Bundle\FrameworkBundle\DependencyInjection\FrameworkExtension->load(Array,
 Object(Symf in
 on line 52
 Stack trace:
 #0
 Array)
 #1
 #2
 #3
 Object(Symf in
 on line 52
 Stack trace:
 #0
 Array)
 #1
 #2
 #3
 Object(Symf in
 on line 52
 Stack trace:
 #0
 Array)
 #1
 #2
 #3
 Object(Symf in
 on line 52
 Stack trace:
 #0
 Array)
 #1
 #2
 #3
 Object(Symf in
 on line 52
 Stack trace:
 #0
 Array)
 #1
 #2
 #3
 Object(Symf in
 on line 52
 Stack trace:
 #0
 Array)
 #1
 #2
 #3
 Object(Symf in
 on line 52
 Stack trace:
 #0
 Array)
 #1
 #2
 #3
 Object(Symf in
 on line 52
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1716#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
