[Live-demo] [OSGeo] #1710: ZOO packages missing from Xenial
OSGeo trac_osgeo at osgeo.org
Thu Jun 9 06:18:59 PDT 2016
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  OSGeoLive10.0
Component:  LiveDVD  |  Resolution:
 Keywords:           |
Comment (by djay):
 You can use the following command from a running OSGeoLiveDVD 10.
 == Packages required to build ==
 sudo apt-get install flex bison libfcgi-dev libxml2 libxml2-dev curl
 openssl autoconf apache2 python-software-properties subversion
 libmozjs185-dev python-dev build-essential libxslt1-dev libmapserver-dev
 libgdal-dev
 == ZOO-Project building for OSGeoLive ==
 mkdir src
 svn checkout http://svn.zoo-project.org/svn/trunk zoo
 cd zoo/zoo-project/thirds/cgic206/
 make
 cd ../../zoo-project/zoo-kernel/
 autoconf
 ./configure --with-python --with-js --with-java=/usr/lib/jvm/java-8
 -openjdk-amd64 --with-mapserver=/usr --with-ms-version=7
 make
 sudo make install
 sudo cp main.cfg /usr/lib/cgi-bin/
 sudo cp ../zoo-api/js/* /usr/lib/cgi-bin
 cd ../zoo-services/ogr/base-vect-ops
 make
 sudo cp cgi-env/* /usr/lib/cgi-bin
 == ZOO-Project configuration ==
 echo "/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/amd64/server/" >
 /etc/ld.so.conf.d/zoo.conf
 sudo ldconfig
 == Web UI to interract with the OGR services ==
 wget http://zoo-project.org/dl/examples.7z
 7zr x examples.7z
 cp -r examples /var/www/html/zoo-demo
 Now, you can access the demo using the following URL: http://localhost
 /zoo-demo/ .
 Let me know if I need to provide an archive containing the pre-built
 binaries.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1710#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
