[Live-demo] [OSGeo] #1722: GeoNode packages missing for Xenial
OSGeo trac_osgeo at osgeo.org
Sun Jun 12 14:32:57 PDT 2016
 Reporter:  kalxas   |       Owner:  kalxas
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  OSGeoLive10.0
Component:  LiveDVD  |  Resolution:
 Keywords:           |
Comment (by kalxas):
 We now have all the packages installed in build 138 and a pull request
 with the changes:
 https://github.com/OSGeo/OSGeoLive/pull/124
 Unfortunately, it seems that some django package is still picked up from
 default Xenial and breaks GeoNode. This is the build error:
 Unpacking python-geonode (2.4-0~xenial0) ...
 Processing triggers for man-db (2.7.5-1) ...
 Processing triggers for install-info (6.1.0.dfsg.1-5) ...
 Setting up curl (7.47.0-1ubuntu2) ...
 Setting up gettext (0.19.7-2ubuntu3) ...
 Setting up libxslt1-dev:amd64 (1.1.28-2.1) ...
 Setting up python-amqp (1.4.9-1) ...
 Setting up python-anyjson (0.3.3-1build1) ...
 Setting up python-regex (0.1.20160110-1) ...
 Setting up python-unidecode (0.04.19-1) ...
 Setting up python-awesome-slugify (1.6.2-1~xenial0) ...
 Setting up python-billiard (3.3.0.22-1) ...
 Setting up python-bs4 (4.4.1-1) ...
 Setting up python-kombu (3.0.33-1ubuntu2) ...
 Setting up python-mailer (0.7-1.1) ...
 Setting up python-memcache (1.57-1) ...
 Setting up python-celery (3.1.20-1) ...
 Setting up python-dialogos (0.4-1~xenial0) ...
 Setting up python-django-activity-stream (0.4.5beta1-1~xenial0) ...
 Setting up python-django-autocomplete-light (2.2.11-1~xenial0) ...
 Setting up python-django-bootstrap3-datetimepicker (2.2.3-1~xenial0) ...
 Setting up python-django-celery (3.1.17-3) ...
 Setting up python-django-extensions (1.5.9-1) ...
 Setting up python-django-forms-bootstrap (3.0.1-1~xenial0) ...
 Setting up python-django-friendly-tag-loader (1.1-1~xenial0) ...
 Setting up python-django-geoexplorer (4.0.5-1~xenial0) ...
 Setting up python-django-jsonfield (0.9.15-2) ...
 Setting up python-django-leaflet (0.13.7-1~xenial0) ...
 Setting up python-django-modeltranslation (0.8b3-1~xenial0) ...
 Setting up python-django-mptt (0.8.0-1) ...
 Setting up python-django-nose (1.4.3-1) ...
 Setting up python-django-pagination (1.0.7-1) ...
 Setting up python-django-south (1.0-0.1) ...
 Setting up python-django-taggit (0.18.0-1) ...
 Setting up python-django-templatetag-sugar (0.1-1~xenial0) ...
 Setting up python-django-taggit-templatetags (0.4.6dev-1~xenial0) ...
 Setting up python-geonode-agon-ratings (0.3.1-1~xenial0) ...
 Setting up python-geonode-notification (1.1.1-1~xenial0) ...
 Setting up python-django-appconf (1.0.1-4) ...
 Setting up python-geonode-user-accounts (1.0.11-1~xenial0) ...
 Setting up python-geonode-avatar (2.1.5-1~xenial0) ...
 Setting up python-gisdata (0.5.4-1~xenial0) ...
 Setting up python-gsconfig (1.0.3-1~xenial0) ...
 Setting up python-paver (1.2.1-1.1) ...
 Setting up python-geonode-user-messages (0.1.3-1~xenial0) ...
 Setting up python-geonode-announcements (1.0.6-1~xenial0) ...
 Setting up python-pinax-theme-bootstrap (3.0a11-1~xenial0) ...
 Setting up python-pinax-theme-bootstrap-account (1.0b2-1~xenial0) ...
 Setting up python-multipartposthandler (0.1.0-2) ...
 Setting up python-mimeparse (0.1.4-1build1) ...
 Setting up python-tastypie (0.9.15-1~xenial0) ...
 Setting up python-gsimporter (0.1-1~xenial0) ...
 Setting up python-geonode-arcrest (10.2-1~xenial0) ...
 Setting up python-geonode (2.4-0~xenial0) ...
 Processing triggers for libc-bin (2.23-0ubuntu3) ...
 127.0.0.1 geonode
 Deploying geonode demonstration instance
 Done
 create geonode database with PostGIS
 CREATE EXTENSION
 Done
 patching settings files
 Done
 Configuring GeoNode
 Not enabling BingMaps base layer as a BING_API_KEY is not defined in
 local_settings.py file.
   File "/usr/bin/django-admin", line 5, in <module>
     management.execute_from_command_line()
   File "/usr/lib/python2.7/dist-
 packages/django/core/management/__init__.py", line 399, in
     utility.execute()
 packages/django/core/management/__init__.py", line 392, in execute
     self.fetch_command(subcommand).run_from_argv(self.argv)
   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
 line 242, in run_from_argv
     self.execute(*args, **options.__dict__)
 line 284, in execute
     self.validate()
 line 310, in validate
     num_errors = get_validation_errors(s, app)
 packages/django/core/management/validation.py", line 34, in
     for (app_name, error) in get_app_errors().items():
   File "/usr/lib/python2.7/dist-packages/django/db/models/loading.py",
 line 196, in get_app_errors
     self._populate()
 line 75, in _populate
     self.load_app(app_name, True)
 line 99, in load_app
     models = import_module('%s.models' % app_name)
   File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py", line
 40, in import_module
     __import__(name)
   File "/usr/lib/python2.7/dist-packages/mptt/models.py", line 15, in
 <module>
     from mptt.managers import TreeManager
   File "/usr/lib/python2.7/dist-packages/mptt/managers.py", line 63, in
 <module>
     class TreeManager(models.Manager.from_queryset(TreeQuerySet)):
 AttributeError: type object 'Manager' has no attribute 'from_queryset'
     utility.execute()
 packages/django/core/management/__init__.py", line 272, in fetch_command
     klass = load_command_class(app_name, subcommand)
 packages/django/core/management/__init__.py", line 76, in
 load_command_class
     return module.Command()
 packages/django/contrib/auth/management/commands/createsuperuser.py", line
 26, in __init__
     self.UserModel = get_user_model()
   File "/usr/lib/python2.7/dist-packages/django/contrib/auth/__init__.py",
 line 127, in get_user_model
     user_model = get_model(app_label, model_name)
 line 271, in get_model
     self._populate()
     __import__(name)
 <module>
 <module>
     utility.execute()
     self.validate()
     self._populate()
     __import__(name)
 <module>
 <module>
 Done
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1722#comment:3>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
