[Live-demo] [OSGeo] #1710: ZOO packages missing from Xenial
OSGeo trac_osgeo at osgeo.org
Tue Jun 14 06:09:49 PDT 2016
 Reporter:  kalxas   |       Owner:  kalxas
     Type:  defect   |      Status:  closed
 Priority:  blocker  |   Milestone:  OSGeoLive10.0
Component:  LiveDVD  |  Resolution:  fixed
 Keywords:           |
Comment (by djay):
 Angelos,
 I have made some modification to the procedure to install the ZOO-Project
 including both CGAL and OTB services. this new version provides also a new
 demo index page giving access to each individual demo UIs (for org, cgal
 and otb respectively).
 Here is the sligthly modified procedure.
 = New install procedure =
 You can use the following command from a running OSGeoLiveDVD 10 to
 install ZOO-Project revision 776 including both CGAL and OTB services, and
 the corresponding demo UI to interact with.
 == Packages required to build ==
 sudo apt-get install flex bison libfcgi-dev libxml2 libxml2-dev curl
 openssl autoconf apache2 python-software-properties subversion
 libmozjs185-dev python-dev build-essential libxslt1-dev libmapserver-dev
 libgdal-dev libcgal-dev libotb-dev libfftw3-dev libtinyxml-dev
 == ZOO-Project building for OSGeoLive ==
 mkdir src
 svn checkout http://svn.zoo-project.org/svn/trunk zoo
 cd zoo/zoo-project/thirds/cgic206/
 make
 cd ../../zoo-project/zoo-kernel/
 autoconf
 ./configure --with-python --with-js --with-java=/usr/lib/jvm/java-8
 -openjdk-amd64 --with-mapserver=/usr --with-ms-version=7 --with-cgal=/usr
 --with-otb=/usr --with-itk-version=4.9 --with-itk=/usr --with-otb-
 version=5.4
 make
 sudo make install
 sudo cp ../zoo-api/js/* /usr/lib/cgi-bin
 cd ../zoo-services/utils/status
 make
 sudo cp cgi-env/* /usr/lib/cgi-bin
 sudo mkdir /var/data
 sudo cp cgi-env/updateStatus.xsl /var/data
 cd ../../ogr/base-vect-ops
 make
 cd ../../cgal
 make
 cd ../../thirds/otb2zcfg
 mkdir build
 cd build
 cmake ..
 make
 mkdir ../zcfgs
 cd ../zcfgs
 export ITK_AUTOLOAD_PATH=/usr/lib/otb/applications/
 otb2zcfg
 for i in BandMath Despeckle KMeansClassification; do
 sudo sed "s:mimeType = image/png:mimeType = image/png\nuseMapserver =
 true\nmsClassify = true:g" -i $i.zcfg
 done
 for i in Smoothing; do
 true" -i $i.zcfg
 done
 sudo mkdir /usr/lib/cgi-bin/OTB
 sudo cp *zcfg /usr/lib/cgi-bin/OTB
 == ZOO-Project configuration ==
 echo "/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/amd64/server/" >
 /etc/ld.so.conf.d/zoo.conf
 sudo ldconfig
 == Web UI to interract with the OGR/CGAL/OTB services ==
 wget http://zoo-project.org/dl/examples-livedvd.tar.bz2
 tar -xf examples-livedvd.tar.bz2
 sudo cp -r zoo-demo /var/www/html/zoo-demo
 sudo cp zoo-demo/main.cfg /usr/lib/cgi-bin
 sudo cp zoo-demo/symbols.sym /var/data
 sudo ln -s /tmp /var/www/html/mpPathRelativeToServerAdress
 sudo chown -R www-data:www-data /var/data
 rm -rf zoo-demo
 Now, you can access the demos index page using the following URL:
 http://localhost/zoo-demo/ .
 I would like to know if it may be possible to integrate this new version
 on OSGeoLiveDVD.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1710#comment:12>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
