[Live-demo] Online WhatIf for OSGeo
Robert Hutton rhutton at unimelb.edu.au
Thu May 26 17:03:02 PDT 2016
On 27/05/16 07:11, Cameron Shorter wrote:
> Any progress getting your application together for WhatIf to join OSGeo-Live?
> https://wiki.osgeo.org/wiki/Live_GIS_Disc_Apply
> We really should start working through an application within the next few days if we are going to
> have time to get onto the next 10.0 release of OSGeo-Live.
Hi Cameron,
Here are my answers to the standard list of questions, an easy-to-read version on google docs:
https://docs.google.com/document/d/1XEh90Uf2Er1Cl3jE1r5Z2LAMokhcVybHc4z7tSe8O2k/edit?usp=sharing
And in plain text:
Please describe your application.
  * What is its name?
     * Online WhatIf
  * What is the home page URL?
     * http://aurin.org.au/projects/portal-and-infrastructure/what-if/
     * https://github.com/AURIN/online-whatif
  * Which OSI approved Open Source Licence is used?
     * MIT and GPLv3
     * A list of dependencies and their licenses for each component:
     * https://github.com/AURIN/online-whatif/blob/master/DEPENDENCIES.md
     * https://github.com/AURIN/online-whatif-ui/blob/master/DEPENDENCIES.md
     * https://github.com/AURIN/workbenchauth/blob/master/DEPENDENCIES.md
  * What does the application do and how does it add value to the GeoSpatial stack of software?
     * Online WhatIf uses existing GIS data to support some of the most important and difficult
aspects of the land planning process: analyzing the suitability of land for different uses,
projecting future land use demands, and allocating the projected demands to the most suitable
locations. It can also be used to prepare long-term projections for future land uses, population and
housing, and employment for a user-defined area.
  * Does the application make use of OGC standards? Which versions of the standards? Client or
server? You may wish to add comments about how standards are used.
     * WMS and WFS
  * What language is it written in?
     * Backend: Java
     * Front end: JavaScript with ExtJS
WMS, WFS.
  * Which version of the application should be included in the next OSGeo-Live release?
     * Version 1.0
  * Stability is very important to us on OSGeo-Live. If a new user finds a bug in one application,
it will tarnish the reputation of all other OSGeo-Live applications as well. (We pay most attention
to the following answers):
     * If risk adverse organisations have deployed your application into production, it would imply
that these organisations have verified the stability of your software. Has the application been
rolled out to production into risk (ideally risk adverse) organisations? Please mention some of
these organisations?
       * AURIN (Australian Urban Research Infrastructure Network)
     * Open HUB provides metrics to help assess the health of a project. Eg:
http://adhoc.osgeo.osuosl.org/livedvd/docs/en/metrics.html Could you please ensure that your project
is registered with Open HUB, and Open HUB has been updated to reference the correct code
repository(s) for your project. What is the Open HUB URL for your project?
       * https://www.openhub.net/p/online-whatif
     * What is the size of the user community? You can often answer this by mentioning downloads, or
describing a healthy, busy email list?
       * ~50
     * What is the size of your developer community?
       * 3, soon to be 4
     * Do you have a bug free, stable release?
       * Yes, version 1.0
     * Please discuss the level of testing that your project has gone through.
       * There are many test units written in TestNG for all functions of the tool.  Also the tool’s
modules have been tested by AURIN's domain expert in terms of the formulas and outputs. There is a
sample project which is copied into the account of each user after logging in. This sample project
is a completed project which contains all modules like Suitability, Demand and Allocation.
     * How long has the project has had mature code.
       * 2 years
     * OSGeo-Live is targeted at applications that people can use rather than libraries. Does the
application have a user interface (possibly a command line interface) that a user can interact with?
(We do make an exception for Incubated OSGeo Libraries, and will include Project Overviews for these
libraries, even if they don't have a user interface.)
       * Online WhatIf has a web-based user interface.
     * We give preference to OSGeo Incubated Projects, or Projects which are presented at FOSS4G
conferences. If your project is involved in OSGeo Incubation, or has been selected to be presented
at FOSS4G, then please mention it.
     * With around 50 applications installed on OSGeo-Live, us core packagers do not have the time
to liaise with every single project email list for each OSGeo-Live release. So we require a
volunteer (or two) to take responsibility for liaising between OSGeo-Live and the project's
communities. This volunteer will be responsible for ensuring the install scripts and English
documentation are updated by someone for each OSGeo-Live release. Also test that the installed
application and Quickstart documentation works as expected on release candidate releases of
OSGeo-Live. Who will act as the project's liaison person.
       * Robert Hutton <rhutton at unimelb.edu.au>
     * OSGeo-Live is Ubuntu Linux based. Our installation preference is:
       * Install from UbuntuGIS or DebianGIS
       * Install .deb files from a PPA
       * Write a custom install script
         * Online WhatIf has a custom install script for OSGeo
     * Can you please discuss how your application will be installed.
         * 3 WAR files installed in the local tomcat
           * Front end
           * Back end
           * Authentication manager
         * 1 PostGIS database
         * 1 CouchDB database
         * Layers hosted in the local geoserver
         * Optional dependencies (not installed by default)
           * Postfix and dovecot for emailing new user accounts
     * OSGeo-Live is memory and disk constrained. Can the application run in 512 Meg of RAM?
       * No.  Minimum requirement of 1GB RAM.
     * How much disk space will be required to install the application and a suitable example
application?
       * 250MB
     * We aim to reduce disk space by having all applications make use of a common dataset. We
encourage applications to make use of the example datasets already installed:
http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets If another dataset would be more
appropriate, please discuss here. Is it appropriate, to remove existing demo datasets which may
already be included in the standard release.
       * A demo dataset is included pre-loaded into PostGIS
     * Each OSGeo-Live application requires a Project Overview available under a CC By and a
Quickstart available under a CC By-SA license. (You may release under a second license as well).
Will you produce this?
       * Yes
     * In past releases, we have included Windows and Mac installers for some applications. It is
likely we won't have space for these in future releases. However, if there is room, would you be
wishing to include Windows and/or Mac installers?
       * No
Regards,
Rob
Robert Hutton
AURIN Systems Administrator
Level 2 West, Alice Hoy Building
University of Melbourne VIC 3010
AUSTRALIA
+61 3 8344 4795
More information about the Live-demo mailing list
