[Live-demo] [OSGeo] #1850: ZOO-Project-1.6.0
OSGeo trac_osgeo at osgeo.org
Sun Jan 22 04:59:20 PST 2017
 Reporter:  djay     |      Owner:  live-demo@…
     Type:  defect   |     Status:  new
 Priority:  normal   |  Milestone:  OSGeoLive10.5
Component:  LiveDVD  |   Keywords:
 I have tried today the following [http://aiolos.survey.ntua.gr/gisvm/dev
 /osgeo-live-nightly-build37-amd64-e19a115.iso iso image].
 When starting it, none of the ZOO-Project demos were working. He are the
 solutions I have used to get the demos working again.
 By using the ldd tool, I was able to identify that the {{{libjvm.so}}}
 cannot be found. So, I have added a {{{zo-project.conf}}} file to the
 {{{/etc/ld.so.conf.d/}}} directory to add a file containing the directory
 where the {{{libjvm.so}}} can be found. Run the {{{sudo ldconfig}}}
 command and from here, both the CGAL and the OGR base-vect-ops demos were
 working.
 When trying to run the OTB demo, I noticed in the apache's {{{error.log}}}
 file says that the {{{updateStatus.xsl}}} cannot be found in
 {{{/var/data}}}. Indeed, the {{{/var/data}}} directory does not exists (a
 file with the same name is present), so I have removed the file and
 created a directory, I have set {{{www-data}}} the owner of the directory
 and downloaded there the {{{updateStatus.xsl}}} file. From here, the
 Smoothing service from the demo UI was working for both image/tiff and
 image/jpeg. Still the image/png output does not work currently. I am
 working on this and will provide feedbacks asap.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1850>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
