[Live-demo] [OSGeo] #1965: ipywidgets unresolved?
OSGeo trac_osgeo at osgeo.org
Fri Jul 14 16:48:34 PDT 2017
 Reporter:  darkblueb  |      Owner:  live-demo@…
     Type:  defect     |     Status:  new
 Priority:  major      |  Milestone:  OSGeoLive11.0
Component:  LiveDVD    |   Keywords:  jupyter, python
 the current collection of components for **ipython** and **Jupyter** is a
 mix of newer and older.
 Therefore, not all the features of Jupyter Notebook interaction are
 expected to work perfectly. Notebook interaction is (mostly) replaced by
 **JupyterLab** in the future.
 But what we ship should be consistant. This test is failing.
 from ipywidgets import IntSlider
 from IPython.display import display
 slider = IntSlider(min=1, max=10)
 display(slider)
 Widget Javascript not detected.  It may not be installed properly. Did you
 enable the widgetsnbextension? If not, then run "jupyter nbextension
 enable --py --sys-prefix widgetsnbextension"
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1965>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
