[Live-demo] [Proj] Fwd: [OSGeo-Live] Proj4 documentation
Cameron Shorter cameron.shorter at gmail.com
Thu Jun 1 14:06:33 PDT 2017
Hi Even,
I agree with you assessment. So the question now is would you like to:
Write a project overview and quickstart from proj4?
How to write it is described here:
https://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Documentation
(The wiki text is a bit old, it references svn instead of git. Feel free
to correct)
Do ask questions if you have any.
Warm regards, Cameron
On 1/6/17 5:45 am, Even Rouault wrote:
> On jeudi 1 juin 2017 05:57:38 CEST Cameron Shorter wrote:
> > Hi Evan,
> > Yes, MetaCRS was a project gathering all the Proj4 projects together.
> > However, it appears that proj4 is the only project in that grouping
> > which is active?
> > Hence my thoughts are that "MetaCRS" should be dropped from OSGeo-Live
> > as a concept and "Proj4" be used instead. It would be ok to say "Proj4
> > has been translated into other languages, including proj4js, ..."
> > Your thoughts are welcome.
> Regarding what is listed currently in metacrs :
> - proj4js: no opinion
> - cs-map: no-opinion
> - geotiff/libgeotiff: heavily used underneath by GDAL in particular,
> mostly in maintaince mode, but can be treated as a technical
> dependency that doesn't require to be visible from users.
> - proj4j: no opinion
> - spatialreference.org: not maintained in years. http://epsg.io/ would
> be a possible replacement
> Agreed that metacrs is probably a bit too ... meta for folks exploring
> OSGeo-Live content, so it could make sense exposing proj.4 as a
> standalone project.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Cameron Shorter
M +61 419 142 254
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170602/8421ed09/attachment-0001.html>
More information about the Live-demo mailing list
