[Live-demo] Translations and Proj4 documentation
Vicky Vergara vicky at georepublic.de
Sun Jun 11 09:11:15 PDT 2017
Hi Julien, et all
Maybe you can help me.
It so happened that I sent another mail asking about what version to use,
while reviewing today, I saw that I didn't send the mail to proj4.
(my mail merge skills are not so good)
So, here is the hand made mail:
Hi all,
With the upcoming OSGeo-Live 11.0 reboot, we will be re-inserting each
project into the OSGeo-Live baseline once someone from each project has
replied to confirm that they have reviewed docs and verified the
application works as expected.
Can you please:
 0. Reply by return email to confirm that you have recieved this email and
that you are able to check docs within the next 2 weeks. (sooner would be
better if you can)
 1. Reply to confirm the Project Overview is still accurate, or has been
updated, (and version numbers are correct)
 2. Reply to confirm you have run a recent OSGeo-Live version (the previous
10.5 version is ok), and updated the quickstart where needed.
 We understand that version 4.9.2 of proj4 will be installed on OSGeo-Live
11.0 (Version 4.9.2 was installed on OSGeo-Live 10.5.)
(all in one reply is ok)
Full package status can be seen here:
https://docs.google.com/spreadsheets/d/1Q5BaEgQtgw4O1bXyeWMl
M8XtAOhUgcjZ7Y2O0FZc2H0/edit?hl=en_GB#gid=2014800150
Key Milestones
18-Jun-2017    All docs reviewed and verified
21-Jun-2017    OSGeo-Live delivered to UAT (final application versions
installed - Beta stage)
24-Jul-2017    OSGeo-Live Final ISO
14-Aug-2017 FOSS4G 2017 Boston
... full schedule http://spreadsheets.google.com
/ccc?key=0Al9zh8DjmU_RdE1SYUN3YWJ2N1NpSUczbW9IRWZNclE&hl=en_GB
On Thu, Jun 1, 2017 at 3:09 PM, Cameron Shorter <cameron.shorter at gmail.com>
wrote:
> Hi Julien,
> Thanks for offering to help with translations. I'm looping in Niko and
> Vicky who are currently wrestling with trying to get transifex to work. If
> you are familiar with it, you might be able to help them.
> Warm regards, Cameron
> On 2/6/17 3:22 am, Julien Moquet wrote:
> Hi,
> >> It would be ok to say "Proj4 has been translated into other languages,
> including proj4js, ..."
> > Agreed that metacrs is probably a bit too ..
> I am fully agree too.
> And as OsGeoLive aims to be multilanguages, I can help on the proj4 French
> Translation pages.
> Regards,
> 2017-05-31 22:15 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
>> On jeudi 1 juin 2017 05:57:38 CEST Cameron Shorter wrote:
>> > Hi Evan,
>> > Yes, MetaCRS was a project gathering all the Proj4 projects together.
>> > However, it appears that proj4 is the only project in that grouping
>> > which is active?
>> > Hence my thoughts are that "MetaCRS" should be dropped from OSGeo-Live
>> > as a concept and "Proj4" be used instead. It would be ok to say "Proj4
>> > has been translated into other languages, including proj4js, ..."
>> > Your thoughts are welcome.
>> Regarding what is listed currently in metacrs :
>> - proj4js: no opinion
>> - cs-map: no-opinion
>> - geotiff/libgeotiff: heavily used underneath by GDAL in particular,
>> mostly in maintaince mode, but can be treated as a technical dependency
>> that doesn't require to be visible from users.
>> - proj4j: no opinion
>> - spatialreference.org: not maintained in years. http://epsg.io/ would
>> be a possible replacement
>> Agreed that metacrs is probably a bit too ... meta for folks exploring
>> OSGeo-Live content, so it could make sense exposing proj.4 as a standalone
>> project.
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> Cameron Shorter
> M +61 419 142 254
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170611/1a13b6b9/attachment.html>
More information about the Live-demo mailing list
