[Live-demo] Translations and Proj4 documentation
Vicky Vergara vicky at georepublic.de
Tue Jun 13 18:02:11 PDT 2017
Hello Julien,
Now about the documentation
I see you've worked on your fork, these are the differences:
is that correct?
https://github.com/OSGeo/OSGeoLive-doc/compare/master...julien2512:master
I dont think you are incubating project (I dont see it in the list of
incubating projects), so this might not apply.
.. image:: ../../images/logos/OSGeo_incubation.png
  :scale: 100 %
  :alt: OSGeo Project
  :align: right
  :target: http://www.osgeo.org/incubator/process/principles.html
​But I see you advanced a lot on the documentation 👍​
​You might as well do the PR so that the other members of the team can give
you feed back.​
​Vicky.​
PS, in pgRouting   the documentation is done in such a way, to make minimal
changes in further releases of OSGeo Live.
On Tue, Jun 13, 2017 at 5:23 PM, Julien Moquet <moquet.julien at gmail.com>
wrote:
> Hi Vicky,
> My fork is up to date regarding the overview and quickstart:
> https://github.com/julien2512/OSGeoLive-doc
> Before making a pull request, I need to test it over the OsGeoLive-10.5
> (on wednesday or thursday).
> Although, as I read the sources.list include in this version, I don't
> really think the latest proj4 will be used.
> The ubuntugis is used for that, and there is only the stable 4.8.0-3 proj4
> release to be used.
> See : http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/
> ubuntu/pool/main/p/proj/
> and https://github.com/OSGeo/OSGeoLive/blob/osgeolive_10_5/
> sources.list.d/ubuntugis.list
> That's why I finally don't have to change the proj4 release on its
> overview.
> I only bypass the metacrs and stuff.
> Regards,
> Julien.
> 2017-06-11 18:11 GMT+02:00 Vicky Vergara <vicky at georepublic.de>:
>> Hi Julien, et all
>> Maybe you can help me.
>> It so happened that I sent another mail asking about what version to use,
>> while reviewing today, I saw that I didn't send the mail to proj4.
>> (my mail merge skills are not so good)
>> So, here is the hand made mail:
>> Hi all,
>> With the upcoming OSGeo-Live 11.0 reboot, we will be re-inserting each
>> project into the OSGeo-Live baseline once someone from each project has
>> replied to confirm that they have reviewed docs and verified the
>> application works as expected.
>> Can you please:
>>  0. Reply by return email to confirm that you have recieved this email
>> and that you are able to check docs within the next 2 weeks. (sooner would
>> be better if you can)
>>  1. Reply to confirm the Project Overview is still accurate, or has been
>> updated, (and version numbers are correct)
>>  2. Reply to confirm you have run a recent OSGeo-Live version (the
>> previous 10.5 version is ok), and updated the quickstart where needed.
>>  We understand that version 4.9.2 of proj4 will be installed on
>> OSGeo-Live 11.0 (Version 4.9.2 was installed on OSGeo-Live 10.5.)
>> (all in one reply is ok)
>> Full package status can be seen here:
>> https://docs.google.com/spreadsheets/d/1Q5BaEgQtgw4O1bXyeWMl
>> M8XtAOhUgcjZ7Y2O0FZc2H0/edit?hl=en_GB#gid=2014800150
>> Key Milestones
>> 18-Jun-2017    All docs reviewed and verified
>> 21-Jun-2017    OSGeo-Live delivered to UAT (final application versions
>> installed - Beta stage)
>> 24-Jul-2017    OSGeo-Live Final ISO
>> 14-Aug-2017 FOSS4G 2017 Boston
>> ... full schedule http://spreadsheets.google.com
>> /ccc?key=0Al9zh8DjmU_RdE1SYUN3YWJ2N1NpSUczbW9IRWZNclE&hl=en_GB
>> On Thu, Jun 1, 2017 at 3:09 PM, Cameron Shorter <
>> cameron.shorter at gmail.com> wrote:
>>> Hi Julien,
>>> Thanks for offering to help with translations. I'm looping in Niko and
>>> Vicky who are currently wrestling with trying to get transifex to work. If
>>> you are familiar with it, you might be able to help them.
>>> Warm regards, Cameron
>>> On 2/6/17 3:22 am, Julien Moquet wrote:
>>> Hi,
>>> >> It would be ok to say "Proj4 has been translated into other
>>> languages, including proj4js, ..."
>>> > Agreed that metacrs is probably a bit too ..
>>> I am fully agree too.
>>> And as OsGeoLive aims to be multilanguages, I can help on the proj4
>>> French Translation pages.
>>> Regards,
>>> 2017-05-31 22:15 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
>>>> On jeudi 1 juin 2017 05:57:38 CEST Cameron Shorter wrote:
>>>> > Hi Evan,
>>>> > Yes, MetaCRS was a project gathering all the Proj4 projects together.
>>>> > However, it appears that proj4 is the only project in that grouping
>>>> > which is active?
>>>> > Hence my thoughts are that "MetaCRS" should be dropped from OSGeo-Live
>>>> > as a concept and "Proj4" be used instead. It would be ok to say "Proj4
>>>> > has been translated into other languages, including proj4js, ..."
>>>> > Your thoughts are welcome.
>>>> Regarding what is listed currently in metacrs :
>>>> - proj4js: no opinion
>>>> - cs-map: no-opinion
>>>> - geotiff/libgeotiff: heavily used underneath by GDAL in particular,
>>>> mostly in maintaince mode, but can be treated as a technical dependency
>>>> that doesn't require to be visible from users.
>>>> - proj4j: no opinion
>>>> - spatialreference.org: not maintained in years. http://epsg.io/ would
>>>> be a possible replacement
>>>> Agreed that metacrs is probably a bit too ... meta for folks exploring
>>>> OSGeo-Live content, so it could make sense exposing proj.4 as a standalone
>>>> project.
>>>> Spatialys - Geospatial professional services
>>>> http://www.spatialys.com
>>> Cameron Shorter
>>> M +61 419 142 254 <+61%20419%20142%20254>
>> Georepublic UG (haftungsbeschränkt)
>> Salzmannstraße 44,
>> 81739 München, Germany
>> Vicky Vergara
>> Operations Research
>> eMail: vicky at georepublic.de
>> Web: https://georepublic.info
>> Tel: +49 (089) 4161 7698-1
>> Fax: +49 (089) 4161 7698-9
>> Commercial register: Amtsgericht München, HRB 181428
>> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170613/2f927ed2/attachment-0001.html>
More information about the Live-demo mailing list
