[Live-demo] OSGeo-Live 11.0 - please confirm that you have reviewed udig docs by 18 June 2017
Frank Gasdorf fgdrf at users.sourceforge.net
Sun Jun 18 11:48:57 PDT 2017
Reviewed and extended a tip how to use local data from DVD/USB (geoserver).
Frank
2017-06-14 15:37 GMT+02:00 Jody Garnett <jody.garnett at gmail.com>:
> It already uses data on osgeo live. We helped set this policy with this
> QuickStart. The WMS is an external data service, optional if they have
> connectivity.
> On Wed, Jun 14, 2017 at 4:16 AM Cameron Shorter <cameron.shorter at gmail.com>
> wrote:
>> Hi Frank,
>> I'm looping Angelos into this conversation who is our build manager.
>> With regards to selecting the version to install on OSGeo-Live, our
>> policy is select stability over bleeding edge.
>> We are targeting new users who will be less tolerant to potential errors,
>> and if they want to see the latest features, they can always go to the
>> project's website to find out more. Based on that logic, I'd suggest
>> version 1.4.0 would probably be preferable to (potentially unstable)
>> 2.0.0RC1. I'm open to being convinced otherwise.
>> Hi Jody,
>> With regards to selecting a WMS for UDig, can you please select one of
>> the datasets already on OSGeo-Live. We aim to have OSGeo-Live demos able to
>> be run when not connected to the internet, as is sometimes the case in
>> workshops. The mapserver WMS is preferred to GeoServer for demos as it
>> doesn't use as much RAM.
>> I'll answer your other questions in another thread.
>> Cheers, Cameron
>> On 14/6/17 5:34 pm, Frank Gasdorf wrote:
>> Just reviewed the current state of Codebase. It looks like 1.4.0 is
>> configured (see install_udig.sh).
>> <https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_udig.sh#L51>
>> Q: Is there still time to upgrade to 2.0.0.RC1? What about the Review
>> Milestone of the docs, does it include changeing installations?
>> Frank
>> 2017-06-13 18:53 GMT+02:00 Jody Garnett <jody.garnett at gmail.com>:
>>> Quickly looking at:
>>> 1) https://live.osgeo.org/en/quickstart/udig_quickstart.html
>>> The WMS http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?Service=
>>> WMS&VERSION=1.1.0&REQUEST=GetCapabilities is no longer active; suggest
>>> replace with demo.boundlessgeo.com (which was just setup on new
>>> hardware).
>>> - http://demo.boundlessgeo.com/geoserver/ows?service=wms&
>>> version=1.1.1&request=GetCapabilities
>>> (we could also rewrite this section to use a local WMS service on the VM)
>>> The "data tab" no longer points to refractions (since they have shut
>>> down the udig wiki), looks like they are holding on to a static copy here
>>> http://udig.refractions.net/confluence/display/DATA/Home.html
>>> 2) https://live.osgeo.org/en/overview/udig_overview.html
>>> Can we add the LocationTech logo to this (and other) LocationTech
>>> projects?
>>> Software Version: 2.0.0.RC1
>>> Jody Garnett
>>> On 13 June 2017 at 02:10, Frank Gasdorf <fgdrf at users.sourceforge.net>
>>> wrote:
>>>> Hi folks,
>>>> I'll have a look at within the next two days. First I need to verify
>>>> the version has been upgraded ;)
>>>> Basically the workflow hasn't changes since the major changes from 1.4
>>>> to 2.0. are the core-libraries uDig is based on (GeoTools, Eclipse, Jts).
>>>> I'll let you know about my findings this week
>>>> Frank
>>>> 2017-06-12 22:38 GMT+02:00 Vicky Vergara <vicky at georepublic.de>:
>>>>> Hi Jody, Frank,
>>>>> We are a bit worried about that the overview and quick start are still
>>>>> ok,
>>>>> With the change from v1.4.0b to the 2.0 there might be changes that
>>>>> you need to review.
>>>>> This are the contents for 1.4.0b in Osgeo live 10.5
>>>>> Here are the files to be modified for the new version:
>>>>> https://github.com/OSGeo/OSGeoLive-doc/blob/master/en/
>>>>> overview/udig_overview.rst
>>>>> quickstart/udig_quickstart.rst
>>>>> Here is the link of the alpha OSGEO Live version:
>>>>> http://aiolos.survey.ntua.gr/gisvm/11.0/
>>>>> Key Milestones -------------------
>>>>> 18-Jun-2017 All docs reviewed and verified
>>>>> 21-Jun-2017 OSGeo-Live delivered to UAT (final application versions
>>>>> installed - Beta stage)
>>>>> 24-Jul-2017 OSGeo-Live Final ISO
>>>>> 14-Aug-2017 FOSS4G 2017 Boston
>>>>> Thanks in advance.
>>>>> Vicky
>>>>> Hey... congrats its nice to see a "mayor" version change.
>>>>> On Thu, Jun 8, 2017 at 12:28 AM, <astroidex at gmail.com> wrote:
>>>>>> Hi Jody, Frank,
>>>>>> With the upcoming OSGeo-Live 11.0 reboot, we will be re-inserting
>>>>>> each project into the OSGeo-Live baseline once someone from each
>>>>>> project has replied to confirm that they have reviewed docs and
>>>>>> verified the application works as expected.
>>>>>> Can you please:
>>>>>> 0. Reply by return email to confirm that you have recieved this email
>>>>>> and that you are able to check docs within the next 2 weeks. (sooner would
>>>>>> be better if you can)
>>>>>> 1. Reply to confirm the Project Overview is still accurate, or has
>>>>>> been updated, (and version numbers are correct): ,
>>>>>> 2. Reply to confirm you have run a recent OSGeo-Live version (the
>>>>>> previous 10.5 version is ok), and updated the quickstart where needed.
>>>>>> We understand that version 2.0 of  udig will be installed on
>>>>>> OSGeo-Live 11.0? (Version 1.4.0b was installed on OSGeo-Live 10.5.)
>>>>>> Our prior review of udig  stated:
>>>>>> Our prior documentation reivew of udig  noted:
>>>>>> Full package status: https://docs.google.com/spreadsheets/d/
>>>>>> 1Q5BaEgQtgw4O1bXyeWMlM8XtAOhUgcjZ7Y2O0FZc2H0/edit?hl=en_GB#
>>>>>> gid=2014800150
>>>>>> Key Milestones
>>>>>> versions installed - Beta stage)
>>>>>> ... full schedule http://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_
>>>>>> RdE1SYUN3YWJ2N1NpSUczbW9IRWZNclE&hl=en_GB
>>>>> Georepublic UG (haftungsbeschränkt)
>>>>> Salzmannstraße 44,
>>>>> 81739 München, Germany
>>>>> Vicky Vergara
>>>>> Operations Research
>>>>> eMail: vicky at georepublic.de
>>>>> Web: https://georepublic.info
>>>>> Tel: +49 (089) 4161 7698-1
>>>>> Fax: +49 (089) 4161 7698-9
>>>>> Commercial register: Amtsgericht München, HRB 181428
>>>>> CEO: Daniel Kastl
>> Cameron Shorter
>> M +61 419 142 254 <+61%20419%20142%20254>
> Jody Garnett
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170618/6aa1d711/attachment-0001.html>
More information about the Live-demo mailing list
