[Live-demo] Jump 1.11 on OSGeoLive 11
Brian M Hamlin maplabs at light42.com
Wed Jun 28 20:58:02 PDT 2017
sort of has a catchy sound to it, no?
This is for FOSS4G Boston in August, and others worldwide..
The OSGeo-Live team is pleased to announce Beta1 of the 11th edition.
We are a week behind schedule, but things are looking solid, very much
in part because Ubuntu 1604 base, and excellent tech from many groups.
Enclosed is a terminal log from starting OpenJUMP 1.11 in a VM
Please check this for any surprises.. thanks in advance
user at live11-beta1:~$ openjump
---JUMP_HOME---
/usr/lib/OpenJUMP-1.11
---JAVA---
Using 'java' found in '/usr/lib/jvm/java-8-openjdk-amd64/jre/bin'
openjdk version "1.8.0_131"; OpenJDK Runtime Environment (build
1.8.0_131-8u131-b11-0ubuntu1.16.04.2-b11); OpenJDK 64-Bit Server VM
(build 25.131-b11, mixed mode);
---LD_LIBRARY_PATH---
./lib/native/gdal-linux-x64:./lib/native/gdal-linux-x64/lib:./lib/native/gdal-linux-x64/java:./lib/native/x64:./lib/native:./lib/ext:
---PATH---
./lib/native:/home/user/bin:/home/user/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/gmt/bin:/usr/lib/gmt/bin:/opt/rasdaman//bin:/opt/rasdaman//bin
---CLASSPATH---
./lib/native/gdal-linux-x64/java/gdal.jar:.:./bin:./conf:./lib/native/*.jar:./lib/native/x64/*.jar:./lib/xz-1.5.jar:./lib/xmlParserAPIs-2.0.2.jar:./lib/xml-apis-1.4.01.jar:./lib/xercesImpl-2.11.0.jar:./lib/postgresql-9.4.1208.jre6.jar:./lib/org-netbeans-swing-outline-7.2.jar:./lib/log4j-1.2.17.jar:./lib/jython-2.2.jar:./lib/jts-io-1.14.0.jar:./lib/jts-core-1.14.0.jar:./lib/json-simple-1.1.1.jar:./lib/js-1.5R4.1.jar:./lib/jmathplot-20070905.jar:./lib/jmatharray-20070905.jar:./lib/jdom2-2.0.6.jar:./lib/jama-1.0.2.jar:./lib/jai_imageio-1.1.jar:./lib/jai_core-1.1.3.jar:./lib/jai_codec-1.1.3.jar:./lib/hamcrest-core-1.3.jar:./lib/commons-logging-1.2.jar:./lib/commons-lang3-3.5.jar:./lib/commons-io-2.5.jar:./lib/commons-imaging-1.0-20130811.122228-3.jar:./lib/commons-compress-1.12.jar:./lib/commons-codec-1.10.jar:./lib/buoy-1.8.jar:./lib/bsh-2.0b4.jar:./lib/batik-xml-1.6.jar:./lib/batik-util-1.6.jar:./lib/batik-transcoder-1.6.jar:./lib/batik-swing-1.6.jar:./lib/batik-svggen-1.6.jar:./lib/batik-svg-dom-1.6.jar:./lib/batik-squiggle-1.6.jar:./lib/batik-script-1.6.jar:./lib/batik-parser-1.6.jar:./lib/batik-gvt-1.6.jar:./lib/batik-gui-util-1.6.jar:./lib/batik-ext-1.6.jar:./lib/batik-dom-1.6.jar:./lib/batik-css-1.6.jar:./lib/batik-bridge-1.6.jar:./lib/batik-awt-util-1.6.jar:./lib/OpenJUMP-1.11-r5434-nosrc.jar:./lib/*.zip:
---Save logs & state to---
/home/user/.openjump/
---Detect maximum memory limit---
set max. memory limit to 15022 MiB
---Start OJ---
[INFO] 20:56:52.143 Restore state from
/home/user/.openjump/workbench-state.xml
[ERROR] 20:56:52.145 /home/user/.openjump/workbench-state.xml (No such
file or directory)
java.io.FileNotFoundException: /home/user/.openjump/workbench-state.xml
(No such file or directory)
    at java.io.FileInputStream.open0(Native Method)
    at java.io.FileInputStream.open(FileInputStream.java:195)
    at java.io.FileInputStream.<init>(FileInputStream.java:138)
    at
com.vividsolutions.jump.workbench.ui.plugin.PersistentBlackboardPlugIn.load(PersistentBlackboardPlugIn.java:155)
    at
com.vividsolutions.jump.workbench.ui.plugin.PersistentBlackboardPlugIn.restoreState(PersistentBlackboardPlugIn.java:76)
    at
com.vividsolutions.jump.workbench.ui.plugin.PersistentBlackboardPlugIn.initialize(PersistentBlackboardPlugIn.java:63)
    at
com.vividsolutions.jump.workbench.JUMPWorkbench.main(JUMPWorkbench.java:438)
    at
com.vividsolutions.jump.workbench.JUMPWorkbench.main(JUMPWorkbench.java:386)
[INFO] 20:56:53.357 Loading Plugin
com.vividsolutions.jump.workbench.datasource.InstallStandardDataSourceQueryChoosersPlugIn took
0.04s
[INFO] 20:56:53.446 Loading Plugin
org.openjump.core.ui.plugin.file.OpenFilePlugIn took 0.09s
[INFO] 20:56:53.448 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.FirstTaskFramePlugIn took
0.00s
[INFO] 20:56:53.452 Loading Plugin
org.openjump.core.ui.plugin.file.FileDragDropPlugin took 0.00s
[INFO] 20:56:53.455 Loading Plugin
org.openjump.core.ui.plugin.view.InstallKeyPanPlugIn took 0.00s
[INFO] 20:56:53.459 Loading Plugin
org.openjump.core.ui.plugin.view.MapToolTipPlugIn took 0.00s
[INFO] 20:56:53.462 Loading Plugin
org.openjump.core.ui.plugin.view.ShowFullPathPlugIn took 0.00s
[INFO] 20:56:53.628 Loading Plugin
org.openjump.core.ui.plugin.datastore.postgis.SaveToPostGISPlugIn took
0.17s
[INFO] 20:56:53.630 Loading Plugin
org.openjump.core.ccordsys.srid.EnsureAllLayersHaveSRIDStylePlugIn took
0.00s
[INFO] 20:56:53.631 Loading Plugin
org.openjump.core.ui.plugin.view.helpclassescale.InstallShowScalePlugIn
took 0.00s
[INFO] 20:56:53.632 Loading Plugin
org.openjump.core.ui.plugin.view.NorthArrowInstallRenderer took 0.00s
[INFO] 20:56:53.634 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.InstallStandardFeatureTextWritersPlugIn took
0.00s
[INFO] 20:56:53.635 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.datastore.InstallDatastoreLayerRendererHintsPlugIn took
0.00s
[INFO] 20:56:53.637 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.scalebar.InstallScaleBarPlugIn
took 0.00s
[INFO] 20:56:53.654 Loading Plugin
com.vividsolutions.jump.workbench.ui.snap.InstallGridPlugIn took 0.02s
[INFO] 20:56:53.849 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.InstallZoomBarPlugIn took
0.19s
[INFO] 20:56:53.867 Loading Plugin
org.openjump.core.ui.plugin.datastore.postgis2.SaveToPostGIS2PlugIn
took 0.02s
[INFO] 20:56:53.870 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.NewTaskPlugIn took 0.00s
[INFO] 20:56:53.874 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.AddNewLayerPlugIn took 0.00s
[INFO] 20:56:53.878 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.AddNewCategoryPlugIn took
0.00s
[INFO] 20:56:53.880 Loading Plugin
org.openjump.core.ui.plugin.file.OpenWizardPlugIn took 0.00s
[INFO] 20:56:53.898 Loading Plugin
org.openjump.core.ui.plugin.file.OpenProjectPlugIn took 0.02s
[INFO] 20:56:53.901 Loading Plugin
org.openjump.core.ui.plugin.file.OpenRecentPlugIn took 0.00s
[INFO] 20:56:53.904 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.datastore.RunDatastoreQueryPlugIn
took 0.00s
[INFO] 20:56:53.915 Loading Plugin
org.openjump.core.ui.plugin.file.SaveLayersWithoutDataSourcePlugIn took
0.01s
[INFO] 20:56:53.922 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.SaveDatasetsPlugIn took 0.00s
[INFO] 20:56:53.926 Loading Plugin
com.vividsolutions.jump.workbench.datasource.SaveDatasetAsPlugIn took
0.00s
[WARN] 20:56:53.928 No translation for key
'org.openjump.core.ui.plugin.file.SaveWizardPlugIn' in bundle
'language/jump'.
[WARN] 20:56:53.929 Can't find resource for bundle
java.util.PropertyResourceBundle, key
org.openjump.core.ui.plugin.file.SaveWizardPlugIn no default value, the
resource key is used: SaveWizardPlugIn
[INFO] 20:56:53.934 Loading Plugin
org.openjump.core.ui.plugin.file.SaveWizardPlugIn took 0.01s
[INFO] 20:56:53.944 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.SaveProjectPlugIn took 0.01s
[INFO] 20:56:53.955 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.SaveProjectAsPlugIn took
0.01s
[INFO] 20:56:53.990 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.SaveImageAsPlugIn took 0.03s
[INFO] 20:56:54.003 Loading Plugin
org.openjump.core.ui.plugin.file.SaveImageAsSVGPlugIn took 0.01s
[INFO] 20:56:54.006 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.clipboard.CopyImagePlugIn
took 0.00s
[INFO] 20:56:54.010 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.UndoPlugIn took 0.00s
[INFO] 20:56:54.012 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.RedoPlugIn took 0.00s
[INFO] 20:56:54.024 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.clipboard.CutSelectedItemsPlugIn
took 0.01s
[INFO] 20:56:54.028 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.clipboard.CopySelectedItemsPlugIn
took 0.00s
[INFO] 20:56:54.035 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.clipboard.PasteItemsPlugIn
took 0.01s
[INFO] 20:56:54.040 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.DeleteSelectedItemsPlugIn
took 0.00s
[INFO] 20:56:54.044 Loading Plugin
org.openjump.core.ui.plugin.edit.SelectAllLayerItemsPlugIn took 0.00s
[INFO] 20:56:54.047 Loading Plugin
org.openjump.core.ui.plugin.edit.SelectAllModifiedFeaturesPlugIn took
0.00s
[INFO] 20:56:54.049 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.SelectFeaturesInFencePlugIn
took 0.00s
[INFO] 20:56:54.052 Loading Plugin
org.openjump.core.ui.plugin.edit.SelectItemsByFenceFromSelectedLayersPlugIn
took 0.00s
[INFO] 20:56:54.055 Loading Plugin
org.openjump.core.ui.plugin.edit.SelectItemsByCircleFromSelectedLayersPlugIn
took 0.00s
[INFO] 20:56:54.058 Loading Plugin
org.openjump.core.ui.plugin.edit.SelectByTypePlugIn took 0.00s
[INFO] 20:56:54.060 Loading Plugin
org.openjump.core.ui.plugin.edit.SelectGeometryCollectionsPlugIn took
0.00s
[INFO] 20:56:54.062 Loading Plugin
org.openjump.core.ui.plugin.edit.SelectLayersWithSelectedItemsPlugIn
took 0.00s
[INFO] 20:56:54.065 Loading Plugin
org.openjump.core.ui.plugin.edit.InvertSelectionPlugIn took 0.00s
[INFO] 20:56:54.070 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.ClearSelectionPlugIn took
0.00s
[INFO] 20:56:54.078 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.AddNewFeaturesPlugIn took
0.01s
[INFO] 20:56:54.083 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.EditSelectedFeaturePlugIn
took 0.00s
[INFO] 20:56:54.087 Loading Plugin
org.openjump.core.ui.plugin.edit.ReplicateSelectedItemsPlugIn took 0.00s
[INFO] 20:56:54.093 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.MeasureSelectedPlugIn took 0.00s
[INFO] 20:56:54.098 Loading Plugin
org.openjump.core.ui.plugin.layer.ExtractLayersByGeometry took 0.00s
[INFO] 20:56:54.101 Loading Plugin
org.openjump.core.ui.plugin.layer.ExtractLayerInFence took 0.00s
[INFO] 20:56:54.104 Loading Plugin
org.openjump.core.ui.plugin.layer.ExtractLayersByAttribute took 0.00s
[INFO] 20:56:54.107 Loading Plugin
org.openjump.core.ui.plugin.edit.ClipToFencePlugIn took 0.00s
[INFO] 20:56:54.110 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.ZoomPreviousPlugIn took 0.00s
[INFO] 20:56:54.113 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.ZoomNextPlugIn took 0.00s
[INFO] 20:56:54.117 Loading Plugin
com.vividsolutions.jump.workbench.ui.cursortool.editing.EditingPlugIn
took 0.00s
[INFO] 20:56:54.119 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.MapToolTipsPlugIn took 0.00s
[INFO] 20:56:54.121 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.ZoomBarPlugIn took 0.00s
[INFO] 20:56:54.126 Loading Plugin
org.openjump.core.ui.plugin.view.ShowScalePlugIn took 0.00s
[INFO] 20:56:54.130 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.scalebar.ScaleBarPlugIn
took 0.00s
[INFO] 20:56:54.133 Loading Plugin
org.openjump.core.ui.plugin.view.NorthArrowPlugIn took 0.00s
[INFO] 20:56:54.135 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.ZoomToFullExtentPlugIn took
0.00s
[INFO] 20:56:54.140 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.ZoomToFencePlugIn took 0.00s
[INFO] 20:56:54.144 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.ZoomToSelectedItemsPlugIn
took 0.00s
[INFO] 20:56:54.146 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.ZoomToCoordinatePlugIn took
0.00s
[INFO] 20:56:54.150 Loading Plugin
org.openjump.core.ui.plugin.wms.ZoomToWMSLayerPlugIn took 0.00s
[INFO] 20:56:54.152 Loading Plugin
org.openjump.core.ui.plugin.view.ZoomToScalePlugIn took 0.00s
[INFO] 20:56:54.158 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.FeatureInfoPlugIn took 0.00s
[INFO] 20:56:54.161 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.VerticesInFencePlugIn took
0.00s
[INFO] 20:56:54.163 Loading Plugin
org.openjump.core.ui.plugin.edit.CopyBBoxPlugin took 0.00s
[INFO] 20:56:54.170 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.clipboard.CutSelectedLayersPlugIn
took 0.01s
[INFO] 20:56:54.174 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.clipboard.CopySelectedLayersPlugIn
took 0.00s
[INFO] 20:56:54.177 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.clipboard.PasteLayersPlugIn
took 0.00s
[INFO] 20:56:54.181 Loading Plugin
org.openjump.core.ui.plugin.layer.CombineSelectedLayersPlugIn took 0.00s
[INFO] 20:56:54.185 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.DisposeSelectedLayersPlugIn
took 0.00s
[INFO] 20:56:54.190 Loading Plugin
org.openjump.core.ui.plugin.layer.SortCategoryByFeaturesPlugIn took
0.00s
[INFO] 20:56:54.192 Loading Plugin
org.openjump.core.ui.plugin.layer.SortCategoryByNamePlugIn took 0.00s
[INFO] 20:56:54.194 Loading Plugin
org.openjump.core.ui.plugin.layer.SortCategoryRestorePlugIn took 0.00s
[INFO] 20:56:54.196 Loading Plugin
org.openjump.core.ui.plugin.layer.SortCategorySavePlugIn took 0.00s
[INFO] 20:56:54.200 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.RemoveSelectedCategoriesPlugIn
took 0.00s
[INFO] 20:56:54.203 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.imagery.AddImageLayerPlugIn
took 0.00s
[INFO] 20:56:54.207 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.imagery.ImageLayerManagerPlugIn
took 0.00s
[INFO] 20:56:54.217 Loading Plugin
de.latlon.deejump.plugin.style.DeeChangeStylesPlugIn took 0.01s
[INFO] 20:56:54.224 Loading Plugin
com.vividsolutions.jump.workbench.ui.style.CopyStylesPlugIn took 0.01s
[INFO] 20:56:54.230 Loading Plugin
com.vividsolutions.jump.workbench.ui.style.PasteStylesPlugIn took 0.01s
Warning: org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser: Property
'http://www.oracle.com/xml/jaxp/properties/entityExpansionLimit' is not
recognized.
Compiler warnings:
  WARNING:  'org.apache.xerces.jaxp.SAXParserImpl: Property
'http://javax.xml.XMLConstants/property/accessExternalDTD' is not
recognized.'
[INFO] 20:56:54.558 Loading Plugin
de.latlon.deejump.plugin.style.LayerStyle2SLDPlugIn took 0.33s
[INFO] 20:56:54.592 Loading Plugin
de.latlon.deejump.plugin.SaveLegendPlugIn took 0.03s
[INFO] 20:56:54.596 Loading Plugin
org.openjump.core.ui.plugin.style.ImportArcMapStylePlugIn took 0.00s
[INFO] 20:56:54.605 Loading Plugin
org.openjump.core.ui.plugin.style.ImportSLDPlugIn took 0.01s
[INFO] 20:56:54.608 Loading Plugin
org.openjump.core.ui.plugin.layer.ChangeSRIDPlugIn took 0.00s
[INFO] 20:56:54.618 Loading Plugin
org.openjump.core.ui.plugin.layer.ExportLayerableEnvelopeAsGeometryPlugIn took
0.01s
[INFO] 20:56:54.694 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.OptionsPlugIn took 0.07s
[INFO] 20:56:54.706 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.BeanShellPlugIn took 0.01s
[INFO] 20:56:54.714 Loading Plugin
org.openjump.core.ui.plugin.customize.BeanToolsPlugIn took 0.01s
[INFO] 20:56:54.720 Loading Plugin
org.openjump.core.ui.plugin.customize.PythonToolsPlugIn took 0.00s
[INFO] 20:56:54.724 Loading Plugin
org.openjump.core.ui.plugin.view.EasyButtonsPlugin took 0.00s
[INFO] 20:56:54.735 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.SpatialQueryPlugIn
took 0.01s
[INFO] 20:56:54.748 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.AttributeQueryPlugIn took
0.01s
[INFO] 20:56:54.753 Loading Plugin
org.openjump.core.ui.plugin.queries.SimpleQueryPlugIn took 0.00s
[INFO] 20:56:54.758 Loading Plugin
org.openjump.core.ui.plugin.queries.SearchAllAttributes took 0.00s
[INFO] 20:56:54.764 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.BufferPlugIn took
0.00s
[INFO] 20:56:54.769 Loading Plugin
org.openjump.core.ui.plugin.tools.MultiRingBufferSelectedPlugIn took
0.00s
[INFO] 20:56:54.774 Loading Plugin
org.openjump.core.ui.plugin.tools.PlumePlugIn took 0.00s
[INFO] 20:56:54.779 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.OffsetCurvePlugIn
took 0.00s
[INFO] 20:56:54.784 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.ConvexHullPlugIn
took 0.00s
[INFO] 20:56:54.787 Loading Plugin
org.openjump.core.ui.plugin.tools.ConvexHullPlugIn took 0.00s
[INFO] 20:56:54.792 Loading Plugin
org.openjump.core.ui.plugin.tools.UnionByAttributePlugIn took 0.00s
[INFO] 20:56:54.795 Loading Plugin
org.openjump.core.ui.plugin.tools.DissolvePlugIn took 0.00s
[INFO] 20:56:54.802 Loading Plugin
org.openjump.core.ui.plugin.tools.Dissolve2PlugIn took 0.01s
[INFO] 20:56:54.812 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.GeometryFunctionPlugIn
took 0.01s
[INFO] 20:56:54.814 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.OverlayPlugIn took
0.00s
[INFO] 20:56:54.817 Loading Plugin
org.openjump.core.ui.plugin.tools.IntersectPolygonLayersPlugIn took
0.00s
[INFO] 20:56:54.819 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.SpatialJoinPlugIn
took 0.00s
[INFO] 20:56:54.821 Loading Plugin
org.openjump.core.ui.plugin.tools.JoinAttributesSpatiallyPlugIn took
0.00s
[INFO] 20:56:54.824 Loading Plugin
org.openjump.core.ui.plugin.tools.analysis.twolayers.CalculateDistancesPlugIn
took 0.00s
[INFO] 20:56:54.828 Loading Plugin
org.openjump.core.ui.plugin.tools.statistics.CreateScatterPlotPlugIn
took 0.00s
[INFO] 20:56:54.830 Loading Plugin
org.openjump.core.ui.plugin.tools.statistics.CreateBarPlotPlugIn took
0.00s
[INFO] 20:56:54.832 Loading Plugin
org.openjump.core.ui.plugin.tools.statistics.CreateHistogramPlugIn took
0.00s
[INFO] 20:56:54.834 Loading Plugin
org.openjump.core.ui.plugin.tools.statistics.ClassifyAttributesPlugIn
took 0.00s
[INFO] 20:56:54.836 Loading Plugin
org.openjump.core.ui.plugin.tools.statistics.CalcVarianceAndMeanPerClassPlugIn
took 0.00s
[INFO] 20:56:54.838 Loading Plugin
org.openjump.core.ui.plugin.tools.statistics.StatisticOverViewPlugIn
took 0.00s
[INFO] 20:56:54.840 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.LayerStatisticsPlugIn took
0.00s
[INFO] 20:56:54.842 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.FeatureStatisticsPlugIn
took 0.00s
[INFO] 20:56:54.845 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.test.RandomTrianglesPlugIn
took 0.00s
[INFO] 20:56:54.846 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.test.RandomArrowsPlugIn
took 0.00s
[INFO] 20:56:54.850 Loading Plugin
org.openjump.core.ui.plugin.tools.generate.CreateGridPlugIn took 0.00s
[INFO] 20:56:54.856 Loading Plugin
org.openjump.core.ui.plugin.tools.TriangulationPlugIn took 0.01s
[INFO] 20:56:54.860 Loading Plugin
org.openjump.core.ui.plugin.tools.VoronoiDiagramPlugIn took 0.00s
[INFO] 20:56:54.863 Loading Plugin
org.openjump.core.ui.plugin.tools.generate.PointLayerFromAttributeTablePlugIn
took 0.00s
[INFO] 20:56:54.868 Loading Plugin
org.openjump.core.ui.plugin.tools.generate.LinearReferencingOnLayerPlugIn took
0.00s
[INFO] 20:56:54.872 Loading Plugin
org.openjump.core.ui.plugin.tools.generate.LinearReferencingOnSelectionPlugIn
took 0.00s
[INFO] 20:56:54.884 Loading Plugin
com.vividsolutions.jump.workbench.ui.warp.WarpingPlugIn took 0.01s
[INFO] 20:56:54.888 Loading Plugin
com.vividsolutions.jump.workbench.ui.warp.AffineTransformPlugIn took
0.00s
[INFO] 20:56:54.892 Loading Plugin
com.vividsolutions.jump.plugin.edit.AffineTransformationPlugIn took
0.00s
[INFO] 20:56:54.897 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.ValidateSelectedLayersPlugIn took
0.00s
[INFO] 20:56:54.900 Loading Plugin
com.vividsolutions.jump.plugin.qa.DiffGeometryPlugIn took 0.00s
[INFO] 20:56:54.902 Loading Plugin
org.openjump.core.ui.plugin.tools.DeleteEmptyGeometriesPlugIn took 0.00s
[INFO] 20:56:54.905 Loading Plugin
org.openjump.core.ui.plugin.tools.DeleteDuplicateGeometriesPlugIn took
0.00s
[INFO] 20:56:54.909 Loading Plugin
org.openjump.core.ui.plugin.tools.MakeValidPlugIn took 0.00s
[INFO] 20:56:54.913 Loading Plugin
org.openjump.core.ui.plugin.tools.RemoveSpikePlugIn took 0.00s
[INFO] 20:56:54.916 Loading Plugin
org.openjump.core.ui.plugin.tools.geometrychange.ExtractPointsPlugIn
took 0.00s
[INFO] 20:56:54.918 Loading Plugin
org.openjump.core.ui.plugin.tools.geometrychange.ExtractCommonBoundaryBetweenPolysPlugIn took
0.00s
[INFO] 20:56:54.921 Loading Plugin
com.vividsolutions.jump.plugin.edit.ExtractSegmentsPlugIn took 0.00s
[INFO] 20:56:54.924 Loading Plugin
com.vividsolutions.jump.plugin.edit.PolygonizerPlugIn took 0.00s
[INFO] 20:56:54.928 Loading Plugin
org.openjump.core.ui.plugin.tools.PlanarGraphPlugIn took 0.00s
[INFO] 20:56:54.978 Loading Plugin de.soldin.jumpcore.geomconv.GCPlugin
took 0.05s
[INFO] 20:56:54.980 Loading Plugin
org.openjump.core.ui.plugin.tools.EraseLayerAWithLayerBPlugIn took 0.00s
[INFO] 20:56:54.982 Loading Plugin
com.vividsolutions.jump.plugin.edit.LineNoderPlugIn took 0.00s
[INFO] 20:56:54.997 Loading Plugin
com.vividsolutions.jump.plugin.edit.NoderPlugIn took 0.01s
[INFO] 20:56:55.001 Loading Plugin
com.vividsolutions.jump.plugin.edit.PrecisionReducerPlugIn took 0.00s
[INFO] 20:56:55.004 Loading Plugin
org.openjump.core.ui.plugin.tools.analysis.onelayer.IntersectPolygonsOneLayerPlugIn took
0.00s
[INFO] 20:56:55.008 Loading Plugin
org.openjump.core.ui.plugin.tools.JoinWithArcPlugIn took 0.00s
[INFO] 20:56:55.012 Loading Plugin
org.openjump.core.ui.plugin.tools.BlendLineStringsPlugIn took 0.00s
[INFO] 20:56:55.014 Loading Plugin
org.openjump.core.ui.plugin.tools.MergeTwoSelectedPolygonsPlugIn took
0.00s
[INFO] 20:56:55.017 Loading Plugin
org.openjump.core.ui.plugin.tools.analysis.onelayer.MergeSelectedPolygonsWithNeighbourPlugIn took
0.00s
[INFO] 20:56:55.021 Loading Plugin
org.openjump.core.ui.plugin.tools.SplitPolygonPlugIn took 0.00s
[INFO] 20:56:55.030 Loading Plugin
org.openjump.core.ui.plugin.tools.ReplaceValuePlugIn took 0.01s
[INFO] 20:56:55.036 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.analysis.CalculateAreasAndLengthsPlugIn took
0.00s
[INFO] 20:56:55.043 Loading Plugin
org.openjump.core.ui.plugin.tools.AutoAssignAttributePlugIn took 0.01s
[INFO] 20:56:55.046 Loading Plugin
org.openjump.core.ui.plugin.tools.GenerateRandomNumberPlugIn took 0.00s
[INFO] 20:56:55.051 Loading Plugin
org.openjump.core.ui.plugin.tools.GenerateRandomStringPlugIn took 0.00s
[INFO] 20:56:55.055 Loading Plugin
de.fho.jump.pirol.plugins.EditAttributeByFormula.EditAttributeByFormulaPlugIn
took 0.00s
[INFO] 20:56:55.059 Loading Plugin
org.openjump.core.ui.plugin.tools.AddGeometryAttributesPlugIn took 0.00s
[INFO] 20:56:55.062 Loading Plugin
org.openjump.core.ui.plugin.tools.Add3DGeometryAttributesPlugIn took
0.00s
[INFO] 20:56:55.064 Loading Plugin
org.openjump.core.ui.plugin.tools.JoinTableFromExistingLayerPlugIn took
0.00s
[INFO] 20:56:55.068 Loading Plugin
org.openjump.core.ui.plugin.tools.UpdateWithJoinPlugIn took 0.00s
[INFO] 20:56:55.088 Loading Plugin
org.openjump.core.ui.plugin.tools.JoinTablePlugIn took 0.02s
[INFO] 20:56:55.095 Loading Plugin
org.openjump.core.ui.plugin.tools.BeanshellAttributeCalculatorPlugIn
took 0.01s
[INFO] 20:56:55.098 Loading Plugin
org.openjump.core.ui.plugin.tools.SimplifyWithJTSAlgorithmPlugIn took
0.00s
[INFO] 20:56:55.100 Loading Plugin
org.openjump.core.ui.plugin.tools.ReducePointsISAPlugIn took 0.00s
[INFO] 20:56:55.103 Loading Plugin
org.openjump.core.ui.plugin.tools.generalization.SimplifyPolygonCoveragePlugIn
took 0.00s
[INFO] 20:56:55.121 Loading Plugin
org.openjump.core.ui.plugin.tools.MeasureM_FPlugIn took 0.02s
[INFO] 20:56:55.127 Loading Plugin
org.openjump.core.ui.plugin.raster.CreateLatticeFromSelectedImageLayerPlugIn
took 0.00s
[INFO] 20:56:55.129 Loading Plugin
org.openjump.core.ui.plugin.raster.CreatePolygonGridFromSelectedImageLayerPlugIn took
0.00s
[INFO] 20:56:55.137 Loading Plugin
org.openjump.core.ui.plugin.raster.statistics.DEMStatisticsPlugIn took
0.01s
[INFO] 20:56:55.144 Loading Plugin
org.openjump.core.ui.plugin.raster.nodata.ChangeNoDataValuePlugIn took
0.01s
[INFO] 20:56:55.148 Loading Plugin
org.openjump.core.ui.plugin.raster.nodata.ChangeValueToNoDataPlugIn
took 0.00s
[INFO] 20:56:55.151 Loading Plugin
org.openjump.core.ui.plugin.raster.nodata.ChangeRangeValuesToNoDataPlugIn took
0.00s
[INFO] 20:56:55.155 Loading Plugin
org.openjump.core.ui.plugin.raster.color.RasterColorEditorPlugIn took
0.00s
[INFO] 20:56:55.161 Loading Plugin
org.openjump.core.ui.plugin.raster.ProfileGraphPlugIn took 0.00s
[INFO] 20:56:55.164 Loading Plugin
org.openjump.core.ui.plugin.raster.RasterQueryPlugIn took 0.00s
[INFO] 20:56:55.167 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.OutputWindowPlugIn took
0.00s
[INFO] 20:56:55.169 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.GenerateLogPlugIn took 0.00s
[INFO] 20:56:55.176 Loading Plugin
org.openjump.core.ui.plugin.window.ArrangeViewsPlugIn took 0.01s
[INFO] 20:56:55.179 Loading Plugin
org.openjump.core.ui.plugin.window.MosaicInternalFramesPlugIn took 0.00s
[INFO] 20:56:55.182 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.CloneWindowPlugIn took 0.00s
[INFO] 20:56:55.186 Loading Plugin
org.openjump.core.ui.plugin.window.SynchronizationPlugIn took 0.00s
[INFO] 20:56:55.189 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.ShortcutKeysPlugIn took
0.00s
[INFO] 20:56:55.191 Loading Plugin
org.openjump.core.ui.plugin.help.SearchCommandPlugIn took 0.00s
[INFO] 20:56:55.193 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.AboutPlugIn took 0.00s
[INFO] 20:56:55.197 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.category.SetCategoryVisibilityPlugIn
took 0.00s
[INFO] 20:56:55.199 Loading Plugin
com.vividsolutions.jump.workbench.datasource.LoadDatasetPlugIn took
0.00s
[INFO] 20:56:55.204 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.datastore.AddDatastoreLayerPlugIn
took 0.00s
[INFO] 20:56:55.207 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.category.MoveCategoryToTop took
0.00s
[INFO] 20:56:55.211 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.category.MoveCategoryOneUp took
0.00s
[INFO] 20:56:55.214 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.category.MoveCategoryOneDown took
0.00s
[INFO] 20:56:55.217 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.category.MoveCategoryToBottom
took 0.00s
[INFO] 20:56:55.223 Loading Plugin
org.openjump.core.ui.plugin.layer.ToggleVisibilityPlugIn took 0.01s
[INFO] 20:56:55.226 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.EditablePlugIn took 0.00s
[INFO] 20:56:55.229 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.SelectablePlugIn took 0.00s
[INFO] 20:56:55.232 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.DeleteAllFeaturesPlugIn
took 0.00s
[INFO] 20:56:55.235 Loading Plugin
com.vividsolutions.jump.workbench.ui.zoom.ZoomToLayerPlugIn took 0.00s
[INFO] 20:56:55.242 Loading Plugin
org.openjump.core.ui.plugin.layer.NewLayerPropertiesPlugIn took 0.01s
[INFO] 20:56:55.245 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.ViewAttributesPlugIn took
0.00s
[INFO] 20:56:55.260 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.ViewSchemaPlugIn took 0.01s
[INFO] 20:56:55.264 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.CopySchemaPlugIn took 0.00s
[INFO] 20:56:55.266 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.PasteSchemaPlugIn took 0.00s
[INFO] 20:56:55.271 Loading Plugin
org.openjump.core.ui.plugin.datastore.EditDataStoreQueryPlugIn took
0.00s
[INFO] 20:56:55.274 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.datastore.RefreshDataStoreLayerPlugin took
0.00s
[INFO] 20:56:55.276 Loading Plugin
org.openjump.core.ui.plugin.layer.LayerPropertiesPlugIn took 0.00s
[INFO] 20:56:55.279 Loading Plugin
org.openjump.core.ui.plugin.datastore.RefreshDataStoreQueryPlugIn took
0.00s
[INFO] 20:56:55.285 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.MoveLayerablePlugIn$MoveLayerableUpPlugIn took
0.00s
[INFO] 20:56:55.290 Loading Plugin
org.openjump.core.ui.plugin.layer.MoveSelectedLayersPlugIn took 0.00s
[INFO] 20:56:55.294 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.MoveLayerablePlugIn$MoveLayerableDownPlugIn took
0.00s
[INFO] 20:56:55.297 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.wms.EditWMSQueryPlugIn took
0.00s
[INFO] 20:56:55.302 Loading Plugin
org.openjump.core.ui.plugin.wms.WMSStylePlugIn took 0.00s
[INFO] 20:56:55.305 Loading Plugin
org.openjump.core.ui.plugin.wms.WMSLegendPlugIn took 0.00s
[INFO] 20:56:55.311 Loading Plugin
org.openjump.core.ui.plugin.raster.RasterImageLayerPropertiesPlugIn
took 0.00s
[INFO] 20:56:55.315 Loading Plugin
org.openjump.core.ui.plugin.layer.pirolraster.ChangeRasterImagePropertiesPlugIn took
0.00s
[INFO] 20:56:55.319 Loading Plugin
org.openjump.core.ui.plugin.layer.pirolraster.ExtractSelectedPartOfImage took
0.00s
[INFO] 20:56:55.322 Loading Plugin
org.openjump.core.ui.plugin.layer.pirolraster.SaveRasterImageAsImagePlugIn
took 0.00s
[INFO] 20:56:55.325 Loading Plugin
org.openjump.core.ui.plugin.layer.pirolraster.ZoomToRasterImagePlugIn
took 0.00s
[INFO] 20:56:55.327 Loading Plugin
org.openjump.core.ui.plugin.layer.pirolraster.WarpImageToFencePlugIn
took 0.00s
[INFO] 20:56:55.330 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.PasteItemsAtPlugIn took 0.00s
[INFO] 20:56:55.334 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.ZoomInPlugIn took 0.00s
[INFO] 20:56:55.337 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.ZoomOutPlugIn took 0.00s
[INFO] 20:56:55.340 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.CenterZoomPlugIn took 0.00s
[INFO] 20:56:55.342 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.DuplicateItemPlugIn took 0.00s
[INFO] 20:56:55.348 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.CombineSelectedFeaturesPlugIn took
0.01s
[INFO] 20:56:55.353 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.MergeSelectedFeaturesPlugIn took
0.00s
[INFO] 20:56:55.359 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.ExplodeSelectedFeaturesPlugIn took
0.01s
[INFO] 20:56:55.361 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.ReverseOrientationPlugIn took
0.00s
[INFO] 20:56:55.363 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.NodeFeaturesPlugIn took 0.00s
[INFO] 20:56:55.365 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.NodeLinesPlugIn took 0.00s
[INFO] 20:56:55.367 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.NodePolygonsPlugIn took 0.00s
[INFO] 20:56:55.369 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.SplitFeaturesPlugIn took 0.00s
[INFO] 20:56:55.371 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.SplitLinesNodePolygonsPlugIn took
0.00s
[INFO] 20:56:55.374 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.SplitPolygonsNodeLinesPlugIn took
0.00s
[INFO] 20:56:55.377 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.RotatePlugIn took 0.00s
[INFO] 20:56:55.379 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.MoveAlongAnglePlugIn took 0.00s
[INFO] 20:56:55.382 Loading Plugin
org.openjump.core.ui.plugin.mousemenu.EditSelectedSidePlugIn took 0.00s
[INFO] 20:56:55.384 Loading Plugin
com.vividsolutions.jump.workbench.ui.plugin.clipboard.CopyThisCoordinatePlugIn
took 0.00s
[INFO] 20:56:55.398 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.DrawConstrainedPolygonPlugIn
took 0.01s
[INFO] 20:56:55.400 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.DrawConstrainedLineStringPlugIn
took 0.00s
[INFO] 20:56:55.401 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.DrawConstrainedCirclePlugIn
took 0.00s
[INFO] 20:56:55.403 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.DrawConstrainedArcPlugIn took
0.00s
[INFO] 20:56:55.404 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.ConstrainedMoveVertexPlugIn
took 0.00s
[INFO] 20:56:55.406 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.SelectOneItemPlugIn took 0.00s
[INFO] 20:56:55.407 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.DrawCircleWithGivenRadiusPlugIn
took 0.00s
[INFO] 20:56:55.409 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.NoteToolPlugIn took 0.00s
[INFO] 20:56:55.410 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.CutPolygonSIGLEPlugIn took 0.00s
[INFO] 20:56:55.411 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.CutFeaturesPlugIn took 0.00s
[INFO] 20:56:55.413 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.AutoCompletePolygonPlugIn took
0.00s
[INFO] 20:56:55.414 Loading Plugin
org.openjump.core.ui.plugin.edittoolbox.FillPolygonPlugIn took 0.00s
[INFO] 20:56:55.424 Loading Plugin
org.openjump.core.ui.plugin.view.ViewOptionsPlugIn took 0.01s
[INFO] 20:56:55.428 Loading Plugin
org.openjump.core.ui.plugin.datastore.transaction.DataStoreTransactionManagerPlugIn took
0.00s
[INFO] 20:56:55.432 Scanning ./lib/ext/SkyPrinterPlugIn-1.0.1.jar took 0.00s
[INFO] 20:56:55.433 Scanning ./lib/ext/PirolCsv.jar took 0.00s
[INFO] 20:56:55.435 Scanning ./lib/ext/graph-toolbox-0.4.1.jar took 0.00s
[INFO] 20:56:55.437 Scanning ./lib/ext/driver-dxf-0.8.1.jar took 0.00s
[INFO] 20:56:55.439 Scanning ./lib/ext/JumpPrinter.jar took 0.00s
[INFO] 20:56:55.446 Scanning ./lib/ext/ojsextante_binding_dec2016c.jar
took 0.01s
[INFO] 20:56:55.447 Scanning ./lib/ext/ojmapcoloring-0.5.jar took 0.00s
[INFO] 20:56:55.448 Scanning ./lib/ext/pbaseClasses.jar took 0.00s
[INFO] 20:56:55.450 Scanning ./lib/ext/bsheditor4jump-0.2.4.jar took 0.00s
[INFO] 20:56:55.452 Scanning ./lib/ext/ViewManager-0.3.4.jar took 0.00s
[INFO] 20:56:55.461 Scanning ./lib/ext/kml-driver-0.2.4.jar took 0.01s
[INFO] 20:56:55.463 Scanning ./lib/ext/JumpChart.jar took 0.00s
[INFO] 20:56:55.464 Scanning ./lib/ext/CTSPlugIn-0.1.3.jar took 0.00s
[INFO] 20:56:55.466 Scanning ./lib/ext/VertexSymbols.jar took 0.00s
[INFO] 20:56:55.469 Scanning ./lib/ext/matching-0.7.5.jar took 0.00s
[INFO] 20:56:55.471 Scanning ./lib/ext/MeasureToolbox_12.jar took 0.00s
[INFO] 20:56:55.473 Scanning ./lib/ext/topology-0.9.1.jar took 0.00s
./lib/ext/TableLayout-bin-jdk1.5-2007-04-21.jar took 0.00s
[INFO] 20:56:55.475 Scanning ./lib/ext/SetAttributes-0.7.1.jar took 0.00s
[INFO] 20:56:55.476 Scanning ./lib/ext/jumpdbquery.jar took 0.00s
[INFO] 20:56:55.481 Scanning ./lib/ext/itext-2.1.7.jar took 0.00s
[INFO] 20:56:55.483 Scanning ./lib/ext/oj_osm_reader_v1-0-4.jar took 0.00s
[INFO] 20:56:55.485 Scanning ./lib/ext/ColorChooser-0.8.jar took 0.00s
[INFO] 20:56:55.501 Scanning ./lib/ext/xbean-2.2.0.jar took 0.02s
[INFO] 20:56:55.503 Scanning ./lib/ext/aggregation-0.2.10.jar took 0.00s
[INFO] 20:56:55.504 Scanning ./lib/ext/utils-0.1-20111127.jar took 0.00s
[INFO] 20:56:55.509 Scanning ./lib/ext/csv-driver-1.0.0.jar took 0.00s
[INFO] 20:56:55.511 Scanning ./lib/ext/ConcaveHull-0.2.jar took 0.00s
[INFO] 20:56:55.512 Scanning ./lib/ext/JumpFillPattern.jar took 0.00s
[INFO] 20:56:55.515 Scanning ./lib/ext/CadTools-0.2.jar took 0.00s
[INFO] 20:56:55.515 Finding all OJ extensions took 0.09s
[INFO] 20:56:55.542 Loading Config SkyPrinterPlugin 1.0 took 0.02s
[INFO] 20:56:55.570 Loading Config Graph Extension (Michaël Michaud)
0.4.1 (2017-02-03) took 0.03s
[INFO] 20:56:55.617 Loading Config DXF driver 0.8.0 took 0.05s
[WARN] 20:56:55.761 No translation for key
'com.cadplan.jump.PrinterPlugIn' in bundle 'language/jump'.
[WARN] 20:56:55.762 Can't find resource for bundle
java.util.PropertyResourceBundle, key com.cadplan.jump.PrinterPlugIn no
default value, the resource key is used: PrinterPlugIn
[INFO] 20:56:55.763 Loading Config Printer (com.cadplan.jump)  took 0.14s
es.unex.sextante.gui.exceptions.ModelIOException
    at
es.unex.sextante.gui.modeler.ModelAlgorithmIO.open(ModelAlgorithmIO.java:283)
    at
es.unex.sextante.gui.modeler.ModelAlgorithmIO.loadModelsAsAlgorithms(ModelAlgorithmIO.java:582)
    at
es.unex.sextante.gui.modeler.ModelerAlgorithmProvider.initialize(ModelerAlgorithmProvider.java:71)
    at es.unex.sextante.gui.core.SextanteGUI._initialize(SextanteGUI.java:288)
    at es.unex.sextante.gui.core.SextanteGUI.initialize(SextanteGUI.java:271)
    at
es.unex.sextante.openjump.extensions.SextanteExtension.configure(SextanteExtension.java:94)
    at
com.vividsolutions.jump.workbench.plugin.PlugInManager.loadConfigurations(PlugInManager.java:212)
    at
com.vividsolutions.jump.workbench.plugin.PlugInManager.load(PlugInManager.java:192)
    at
com.vividsolutions.jump.workbench.JUMPWorkbench.main(JUMPWorkbench.java:457)
    at
    at
    at
    at
    at
    at
    at
    at
    at
[INFO] 20:56:56.692 Loading Config Sextante 1.0 OpenJUMP binding
2016-12-27 took 0.93s
[INFO] 20:56:56.699 Loading Config Five Color
(org.freevoice.mapcoloring)  took 0.01s
[INFO] 20:56:56.700 Loading Config BeanShell Script Editor 0.2.4
(2012-01-17) took 0.00s
[INFO] 20:56:56.949 Loading Config View Manager Extension (Michaël
Michaud) 0.3.4 (2016-10-24) took 0.25s
[WARN] 20:56:56.950 No translation for key 'driver-name' in bundle
'language/jump'.
[WARN] 20:56:56.950 Can't find resource for bundle
java.util.PropertyResourceBundle, key driver-name no default value, the
resource key is used: driver-name
[WARN] 20:56:56.951 No translation for key 'driver-version' in bundle
'language/jump'.
[WARN] 20:56:56.951 Can't find resource for bundle
java.util.PropertyResourceBundle, key driver-version no default value,
the resource key is used: driver-version
[WARN] 20:56:56.951 No translation for key 'driver-date' in bundle
'language/jump'.
[WARN] 20:56:56.952 Can't find resource for bundle
java.util.PropertyResourceBundle, key driver-date no default value, the
resource key is used: driver-date
[WARN] 20:56:56.953 No translation for key 'map-projection' in bundle
'language/jump'.
[WARN] 20:56:56.954 Can't find resource for bundle
java.util.PropertyResourceBundle, key map-projection no default value,
the resource key is used: map-projection
[WARN] 20:56:56.954 No translation for key 'choose-map-projection' in
java.util.PropertyResourceBundle, key choose-map-projection no default
value, the resource key is used: choose-map-projection
[WARN] 20:56:56.955 No translation for key 'lat-long' in bundle
'language/jump'.
[WARN] 20:56:56.955 Can't find resource for bundle
java.util.PropertyResourceBundle, key lat-long no default value, the
resource key is used: lat-long
[WARN] 20:56:56.955 No translation for key 'missing-projection-file' in
java.util.PropertyResourceBundle, key missing-projection-file no
default value, the resource key is used: missing-projection-file
[WARN] 20:56:56.973 Can't find resource for bundle
[INFO] 20:56:56.974 Loading Config driver-name driver-version
(driver-date) took 0.02s
[WARN] 20:56:56.985 No translation for key
'com.cadplan.jump.JumpChartPlugIn' in bundle 'language/jump'.
[WARN] 20:56:56.985 Can't find resource for bundle
java.util.PropertyResourceBundle, key com.cadplan.jump.JumpChartPlugIn
no default value, the resource key is used: JumpChartPlugIn
[INFO] 20:56:56.986 Loading Config Jump Chart (com.cadplan.jump)  took 0.01s
[INFO] 20:56:57.000 Loading Config CTS Extension (Michaël Michaud)
0.1.3 (2017-01-21) took 0.01s
[WARN] 20:56:57.009 No translation for key
'com.cadplan.jump.VertexNotePlugin' in bundle 'language/jump'.
[WARN] 20:56:57.009 Can't find resource for bundle
java.util.PropertyResourceBundle, key com.cadplan.jump.VertexNotePlugin
no default value, the resource key is used: VertexNotePlugin
[INFO] 20:56:57.010 Loading Config Vertex Note (com.cadplan.jump)  took 0.01s
[WARN] 20:56:57.012 No translation for key
'com.cadplan.jump.VertexSymbolsPlugIn' in bundle 'language/jump'.
[WARN] 20:56:57.013 Can't find resource for bundle
com.cadplan.jump.VertexSymbolsPlugIn no default value, the resource key
is used: VertexSymbolsPlugIn
[INFO] 20:56:57.018 Loading Config Vertex Symbols (com.cadplan.jump)
took 0.01s
[INFO] 20:56:57.080 Loading Config Matching Extension (Michaël
Michaud) 0.7.5 (2017-03-26) took 0.06s
[INFO] 20:56:57.099 Loading Config Measure Extension for
OpenJUMP(Giuseppe Aruta - http://sourceforge.net/projects/opensit/ -
giuseppe_aruta at yahoo.it) 1.0 (2015-01-09) took 0.02s
[INFO] 20:56:57.126 Loading Config Topology Extension (Michaël
Michaud) 0.9.1 (2016-06-18) took 0.03s
[INFO] 20:56:57.137 Loading Config Set Attribute Values Extension
(Michaël Michaud) 0.7.0 (2015-06-13) took 0.01s
[INFO] 20:56:57.148 Loading Config Jump Db Query
(org.freevoice.jumpdbqueryextension)  took 0.01s
[INFO] 20:56:57.150 Loading Config OSM Driver 1.0.1 (2013-08-03) took 0.00s
[INFO] 20:56:58.173 Loading Config Feature Color Chooser PlugIn
(Giuseppe Aruta - adapted from SkyJUMP
sourceforge.net/projects/skyjump/) 0.8 (2016-12-04) took 1.02s
[INFO] 20:56:58.230 Loading Config Aggregation PlugIn (Michaël
Michaud) 0.2.10 (2017-01-03) took 0.05s
[INFO] 20:56:58.262 Loading Config CSV Driver 1.0.0 (2017-02-09) took 0.03s
[INFO] 20:56:58.277 Loading Config Concave Hull Extension 0.2
(2014-11-25) took 0.01s
[INFO] 20:56:58.409 Loading Config Fill Pattern (com.cadplan.jump)  took 0.13s
[WARN] 20:56:58.421 No translation for key
'org.openjump.core.ui.plugins.Advanced-edit-tools' in bundle
'org/openjump/advancedtools/language/cadtoolbox'.
[WARN] 20:56:58.421 Can't find resource for bundle
org.openjump.core.ui.plugins.Advanced-edit-tools no default value, the
resource key is used: Advanced-edit-tools
[WARN] 20:56:58.433 No translation for key
'org.openjump.core.ui.config.CADToolsOptionsPanel.EditingOptions' in
bundle 'org/openjump/advancedtools/language/cadtoolbox'.
[WARN] 20:56:58.433 Can't find resource for bundle
org.openjump.core.ui.config.CADToolsOptionsPanel.EditingOptions no
default value, the resource key is used: EditingOptions
[WARN] 20:56:58.434 No translation for key
'org.openjump.core.ui.config.CADToolsOptionsPanel.EditingOptions.show-panel'
in bundle 'org/openjump/advancedtools/language/cadtoolbox'.
[WARN] 20:56:58.434 Can't find resource for bundle
org.openjump.core.ui.config.CADToolsOptionsPanel.EditingOptions.show-panel no
default value, the resource key is used: show-panel
[INFO] 20:56:58.446 Loading Config Cad Tools (Giuseppe Aruta - a
collection of tools adapted from Kosmo 3.0, SkyJUMP and new tools) 0.2
(2017-3-28) took 0.04s
[WARN] 20:56:58.454 Datastore 'Oracle Spatial Datastore Extension'
disabled: Missing dependency jars ojdbc6.jar
[INFO] 20:56:58.454 Loading Config Oracle Spatial Datastore Extension
rev.5434(13.04.2017) took 0.01s
[INFO] 20:56:58.458 Loading Config MariaDB/MySQL Spatial Datastore
Extension rev.5434(13.04.2017) took 0.00s
[INFO] 20:56:58.461 Loading Config MySQL Spatial Datastore Extension
[INFO] 20:56:58.463 Loading Config Spatialite Datastore Extension
[WARN] 20:56:58.466 Datastore 'H2GIS Datastore Extension' disabled:
Missing dependency jars h2-<version>.jar
[INFO] 20:56:58.467 Loading Config H2GIS Datastore Extension
[INFO] 20:56:58.470 Loading Config Postgis Datastore Extension
[INFO] 20:56:58.494 Loading Config WFS(-T) 1.0/1.1 Extension (Lat/Lon)
1.2 rev.5434(13.04.2017) took 0.02s
[INFO] 20:56:58.506 Loading Config Raster Styles
(org.openjump.core.rasterimage.styler)  took 0.01s
[INFO] 20:56:58.507 Loading all OJ extensions took 2.99s
[INFO] 20:56:58.590 ECW/JP2 loader class com.ermapper.ecw.JNCSRenderer
not installed.
[INFO] 20:56:58.591 ECW/JP2 SDK loader will be unavailable.
[INFO] 20:56:58.634 mrsidgeodecode not installed. - mrsidgeodecode not in path
Jun 28, 2017 8:56:58 PM
it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
INFO: GDAL Native Library loaded (version: 2.2.0)
it.geosolutions.imageio.plugins.turbojpeg.TurboJpegUtilities
loadTurboJpeg
WARNING: Failed to load the TurboJpeg native libs. This is not a
problem, but the TurboJpeg encoder won't be available:
java.lang.UnsatisfiedLinkError: no turbojpeg in java.library.path
Jun 28, 2017 8:56:58 PM it.geosolutions.util.KakaduUtilities loadKakadu
WARNING: Failed to load the Kakadu native libs. This is not a problem
unless you need to use the Kakadu plugin: it won't be enabled.
java.lang.UnsatisfiedLinkError: no kdu_jni in java.library.path
Jun 28, 2017 8:56:59 PM
it.geosolutions.imageio.gdalframework.GDALUtilities isDriverAvailable
WARNING: Failed to get the specified GDAL Driver: DOQ1
Cause: java.lang.UnsatisfiedLinkError:
org.gdal.gdal.gdalJNI.SWIGDriverUpcast(J)J
This is not a problem unless you need to use the specified GDAL plugin.
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: GTiff
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: JPEG
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: AAIGrid
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: DTED
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: ESAT
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: RST
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: DOQ2
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: EHdr
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: AIG
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: NITF
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: HFA
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: ENVI
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: BSB
It won't be enabled
WARNING: Failed to get the specified GDAL Driver: JP2OpenJPEG
It won't be enabled
[INFO] 20:56:59.216 OJ start took 8.51s alltogether.
[INFO] 20:56:59.849 Activating Select Features Tool
[INFO] 20:56:59.851 Activating Select Features Tool
[INFO] 20:56:59.853 Activating Select Features Tool
[INFO] 20:56:59.859 Task added : Project 1
[INFO] 20:57:00.096 Activating Select Features Tool
More information about the Live-demo mailing list
