[Live-demo] [Qgis-user] OSGeo Live with VM doesn't work
Angelos Tzotsos gcpp.kalxas at gmail.com
Sun Mar 26 09:49:25 PDT 2017
You are welcome.
On 03/26/2017 07:07 PM, Salvatore Oliveto wrote:
> thank you, it was necessary to enable the virtualization options in the
> bios, now it works!
> Dott. Geol. Salvatore Oliveto
> [image: Follow me] <http://it.linkedin.com/in/salvatoreoliveto/>
> G.I.S. e Sistemi Informativi Territoriali
> TERRALAB srl - Servizi Avanzati per l'Osservazione della Terra
> URL: www.terralab.eu
> Linkedin: linkedin.terralab.eu
> Facebook: facebook.terralab.eu
> Email: salvatore.oliveto at terralab.eu
> PEC: terralabsrl at pec.it
> Mobile: +39 333.9473545
> _____________________________________
> Informativa Privacy - Ai sensi del D. Lgs n. 196/2003 (Codice Privacy) si
> precisa che le informazioni contenute in questo messaggio sono riservate e
> ad uso esclusivo del destinatario. Qualora il messaggio in parola Le fosse
> pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non
> inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie.
> Privacy Information - This message, for the D. Lgs n. 196/2003 (Privacy
> Code), may contain confidential and/or privileged information. If you are
> not the addressee or authorized to receive this for the addressee, you must
> not use, copy, disclose or take any action based on this message or any
> information herein. If you have received this message in error, please
> advise the sender immediately by reply e-mail and delete this message.
> Thank you for your cooperation.
> 2017-03-26 1:43 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>> Hi,
>> Please set the VM as 64bit Ubuntu, not 32bit
>> Best,
>> Angelos
>> On 03/25/2017 04:49 PM, Salvatore Oliveto wrote:
>>> hi, I use Win 10 64 Bit, with osgeolive 10.0, see the attached file...
>>> I can use osgeolive with usb drive, but not with VM
>>> tell me if you need other informations
>>> thank yoy
>>> must
>>> 2017-03-25 12:59 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>>> Hi,
>>>> Can you please provide some more info on this issue?
>>>> e.g. system architecture, OSGeo-Live version, virtualization platform
>>>> etc.
>>>> Cheers,
>>>> Angelos
>>>> On 03/25/2017 12:10 PM, Salvatore Oliveto wrote:
>>>> Hi, I followed the procedure for installing osgeolive with VMhttps://
>>>> live.osgeo.org/it/quickstart/virtualization_quickstart.html, but
>>>> when I start the VM with osgeolive remains black screen and Linux doesn't
>>>> start
>>>> thank you
>>>> _______________________________________________
>>>> Qgis-user mailing listQgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Angelos Tzotsos, PhD
>>>> Charter Member
>>>> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
>> Charter Member
Charter Member
More information about the Live-demo mailing list
