[OSGeoLive] Presentation.
Cameron Shorter cameron.shorter at gmail.com
Tue Feb 27 11:08:09 PST 2018
Hi Bob,
As it seems you have noticed, the front page of the slide deck [1] says:
/Press "s" for slide notes, ESC to zoom out, SPACE / arrow keys to
navigate./
It is possible you have been pressing upper case "S" (which doesn't
work) instead of lower case "s" (which should work).
What should happen is another browser window will open up. If your
browser has been configured to prevent the opening of popups, then that
might be the problem you are experiencing. Maybe see if you have an
error message saying that a window is being blocked from being opened,
or check your settings, or try a different browser.
Hope that helps, Cameron
[1] https://live.osgeo.org/en/presentation/index.html#/
On 28/2/18 5:07 am, Basques, Bob (CI-StPaul) wrote:
> All (or Cameron),
> I’m givong the OSGeoLive presentation next week and I have a localized
> copy of the Reveal.js presentation, but I can’t seem to figure out how
> to easily get the presenter notes.
> This is actually the first time I’ve even worried about, since the
> presentation itself just works as a localized set of file, but I
> figured I would try to get the Notes working too.
> I want to run from a USB  (HTML) folder.  Again I have the
> presentation just fine, jus tlooking for hints on an easy way to get
> the NOTE working.  I tried a couple of Link changes in the main file,
> but I didn’t see anything obvious that the “S” option activates in the
> HTML.  Still looking.
> Thanks
> all
> bobb
> "Whenever you find yourself on the side of the majority, it is time to
> pause and reflect.”
> -  Mark Twain
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Technology Demystifier, Learnosity
Open Technologies Consultant
M +61 (0) 419 142 254
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20180228/f3c09b9f/attachment-0001.html>
More information about the Live-demo mailing list
