[Lizmap-de] QGIS Server, Lizmap and Postgis
guenter at lizmap.de guenter at lizmap.de
Fr Mär 25 04:57:28 PDT 2022
Hi Etienne,
Thank you very much for the messages and help here.
It makes me, or rather us, very happy that we also get first-hand info here. There I gladly take a translation program.
Greetings
Günter
Von: Etienne Trimaille <etienne.trimaille at gmail.com>
Gesendet: Freitag, 25. März 2022 12:22
An: Wolfgang Meinolf <wmeinolf at bbv-deutschland.de>
Cc: guenter at lizmap.de; lizmap-de at lists.osgeo.org
Betreff: Re: [Lizmap-de] QGIS Server, Lizmap and Postgis
Installing Lizmap QGIS Server plugin is highly recommended for now. A few functions will not work without the Lizmap plugin such as :
- expressions in forms
- filter by polygon
- some ACL
List of features which need the server plugin : https://docs.lizmap.com/current/en/install/pre_requirements.html#lizmap-qgis-server-plugin
We will make it required for 3.6 (not displaying any maps) if the table "server information" is not shown correctly.
Sorry for speaking in English on the German channel, just wanna help ;-)
Le jeu. 24 mars 2022 à 17:44, Wolfgang Meinolf <wmeinolf at bbv-deutschland.de <mailto:wmeinolf at bbv-deutschland.de> > a écrit :
Thanks. On my VM testbed I see now this:
Is the installation of the Lizmap Plugin mandatory, recommended, or do I just need it for special purpose? Once I properly have Lizmap running I’ll try Postgresql stuff in testbed. Once al is fine in textbed I will upgrade my live system accordingly.
Von: Etienne Trimaille <etienne.trimaille at gmail.com <mailto:etienne.trimaille at gmail.com> >
Gesendet: Donnerstag, 24. März 2022 10:28
An: Wolfgang Meinolf <wmeinolf at bbv-deutschland.de <mailto:wmeinolf at bbv-deutschland.de> >
Cc: guenter at lizmap.de <mailto:guenter at lizmap.de> ; lizmap-de at lists.osgeo.org <mailto:lizmap-de at lists.osgeo.org>
Sorry, yes, it's only 3.5.
It's a new panel to check your QGIS Server settings and installed QGIS Server plugins.
As Günter asked, does a simple shapefile works in Lizmap without the use of PG ?
Le jeu. 24 mars 2022 à 09:54, Wolfgang Meinolf <wmeinolf at bbv-deutschland.de <mailto:wmeinolf at bbv-deutschland.de> > a écrit :
Hi Etienne,
thanks for your comment. I’m currently on 3.4.6 and QGIS server 3.16.xx on my live system. On my VM I have installed QGIS Server 3.24.x and 3.5.1 Lizmap. I plan to upgrade live system, once I identified the issue with Postgis Layers on my VM as all Portals I have internally and as Extranet work perfect as long as no DB Layer are included. Is “Server Information” translated “Lizmap-Konfiguration?
Or is it not available pre 3.5?
Ans thks for the info about the bugfix releases.
Gesendet: Donnerstag, 24. März 2022 09:03
Do you have the table "server information" working correctly ? (In the administration interface). It's the first thing to check before trying a project if you are 3.5.
FYI, we will release bugfix versions for 3.4 and 3.5 today.
On Wed, 23 Mar 2022, 21:34 Wolfgang Meinolf, <wmeinolf at bbv-deutschland.de <mailto:wmeinolf at bbv-deutschland.de> > wrote:
Hallo Günter,
danke für den Hinweis mit den anderen .conf Dateien. Das werde ich morgen mal probieren, obwohl ich da wenig Hoffnung habe. Heute habe ich eine neue VM aufgesetzt, die unserem Server entspricht.
Zu Deiner Frage: Ja, der Server läuft im Wirkeinsatz fantastisch. Gerade gestern habe ich ein neues Extranet Portal für eine Behörde, mit der wie zusammenarbeiten, aktiviert. In aller Regel habe ich pro Portal neben der .QGS eine GPKG, in der sich alle Layer befinden. Auch eine Mischung aus GPKG und SHP aus verschiedenen Verzeichnisästen funktioniert problemlos. Insofern glaube ich aktuell nicht, dass das Problem bei LIZMAP liegt. Vielmehr scheint der QGIS Server nicht in der Lage zu sein, Layer aus der ebenfalls auf dem Server laufenden Postgres/Postgis DB zu öffnen. Meine Suche konzentriert sich daher aktuell auf dieses Scenario.
Das kann ich mit der neuen VM deutlich besser testen als am Live System. Das Lizmap Log reflektiert vermutlich nur die Fehlermeldung des Servers. Ich werde berichten.
Gruß und schönen Abend
Wolfgang
Von: guenter at lizmap.de <mailto:guenter at lizmap.de>  <guenter at lizmap.de <mailto:guenter at lizmap.de> >
Gesendet: Mittwoch, 23. März 2022 19:11
An: Wolfgang Meinolf <wmeinolf at bbv-deutschland.de <mailto:wmeinolf at bbv-deutschland.de> >; lizmap-de at lists.osgeo.org <mailto:lizmap-de at lists.osgeo.org>
Betreff: AW: [Lizmap-de] QGIS Server, Lizmap and Postgis
Hallo Wolfgang,
zu den Log-Files kann ich ohne Recherche und testen (wozu leider die Zeit fehlt) auch nichts sagen.
Wenn eine QGIS-Server Variable wie
„FcgidInitialEnv QGIS_SERVER_IGNORE_BAD_LAYERS 1“
nicht berücksichtigt wird, so würde ich vermuten, dass sie an der falschen Stelle, in der falschen .conf-Datei gesetzt wird.
Ich muss mich mit den conf-Dateien der VirtualHosts in Apache auch noch mal genauer beschäftigen.
Aber ich habe die Variablen in der allgemeinen, ersten .conf-Datei „000-default.conf“ und in meinen jeweiligen Projekt-.conf-Dateien gesetzt. Das ist zwar doppelt aber funktioniert.
Ich  hatte schon mal zu einer Deinen ersten Mails gefragt:
Läuft denn der QGIS-Server mit einfachen, lokalen Datenquellen, also z.Bsp. einer Geopackage-DB oder notfalls auch mit SHAPE-Daten?
Gruß,   Günter
Von: Lizmap-de <lizmap-de-bounces at lists.osgeo.org <mailto:lizmap-de-bounces at lists.osgeo.org> > Im Auftrag von Wolfgang Meinolf
Gesendet: Dienstag, 22. März 2022 21:34
An: lizmap-de at lists.osgeo.org
Betreff: [Lizmap-de] QGIS Server, Lizmap and Postgis
Hallo zusammen,
ich forsche immer noch an meinem Server, warum ich mit den Postgis Layern nicht weiterkomme. Und warum einige Server Einstellungen wie z.B. „FcgidInitialEnv QGIS_SERVER_IGNORE_BAD_LAYERS 1“ ohne Wirkung sind.
Aktuell habe ich das folgende Problem, dass mein QGIS Server Log unter /var/log/qgis/qgisserver.log seine Funktion Ende Februar eingestellt hat und ich es nicht mehr zum Laufen bekomme. Lediglich die access und error Logs meiner Virtuellen Apache Site kann ich auswerten. Laut QGIS Dokumentation wird QGIS_SERVER_LOG_FILE ja seit 3.4 durch QGIS_SERVER_LOG_STDERR ersetzt und alle Daten nach stdout bzw. stderr geschrieben. Wie kann ich das sichtbar machen, oder in eine Datei umleiten, um es auszuwerten?
In Lizmap sehe ich folgende 4 Zeilen, jedesmal, wenn ich eine der Sites mit Postgis Layer aufrufe:
2022-03-22 20:24:36     84.136.144.157 error     GetCapabilities result code: 500
2022-03-22 20:24:36     84.136.144.157 error     An error has been raised when loading WMS GetCapabilities: HTTP Code 400
Angezeigt wird dabei statt des Portals Service non Disponible. Es ist zum verzweifeln. Ich bin kurz davor, den kompletten Server neu aufzusetzten, aber ohne Wissen der Ursache scheint mir das wenig sinnvoll.
Vielleicht gibt’s hier ja noch Ideen, wie und woran ich drehen kann.
Gruß und einen schönen Abend
Wolfgang Meinolf
Lizmap-de mailing list
Lizmap-de at lists.osgeo.org <mailto:Lizmap-de at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/lizmap-de
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20220325/49e11d83/attachment-0001.html>
Ein Dateianhang mit Binärdaten wurde abgetrennt...
Dateiname   : image003.jpg
Dateityp    : image/jpeg
Dateigröße  : 19034 bytes
Beschreibung: nicht verfügbar
URL         : <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20220325/49e11d83/attachment-0002.jpg>
Dateiname   : image004.jpg
Dateigröße  : 8508 bytes
URL         : <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20220325/49e11d83/attachment-0003.jpg>
Mehr Informationen über die Mailingliste Lizmap-de
