svn commit: r753 - trunk/mapbender/http/php/mod_filteredWms_topic.php
christoph at osgeo.org
Fri Aug 11 07:25:12 EDT 2006
Author: christoph
Date: 2006-08-11 11:25:11+0000
New Revision: 753
Added:
sets relation between topic and wms
Added: trunk/mapbender/http/php/mod_filteredWms_topic.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_filteredWms_topic.php?view=auto&rev=753
--- (empty file)
+++ trunk/mapbender/http/php/mod_filteredWms_topic.php 2006-08-11 11:25:11+0000
@@ -0,0 +1,189 @@
+<?php
+# $Id: mod_filteredGui_group.php 235 2006-05-11 08:34:48Z uli $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require_once("../../conf/mapbender.conf");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+require_once("../php/mb_validatePermission.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Administration</title>
+<?php
+include '../include/dyn_css.php';
+<script language="JavaScript">
+function validate(wert){
+ if(document.forms[0]["selected_wms"].selectedIndex == -1){
+ document.getElementsByName("selected_wms")[0].style.backgroundColor = '#ff0000';
+ return;
+ }else{
+ if(wert == "remove"){
+ if(document.forms[0]["remove_topic[]"].selectedIndex == -1){
+ document.getElementsByName("remove_topic[]")[0].style.backgroundColor = '#ff0000';
+ return;
+ document.form1.remove.value = 'true';
+ document.form1.submit();
+ if(wert == "insert"){
+ if(document.forms[0]["selected_topic[]"].selectedIndex == -1){
+ document.getElementsByName("selected_topic[]")[0].style.backgroundColor = '#ff0000';
+ return;
+ document.form1.insert.value = 'true';
+</script>
+</head>
+<body>
+<?php
+require_once("../classes/class_administration.php");
+$fieldHeight = 20;
+$language_suffix = "en";
+//FIXME: there seems to be an error in dyn_css.php concerning php vars.
+if ($language == "'de'") {
+ $language_suffix = "de";
+$logged_user_name = $_SESSION["mb_user_name"];
+$logged_user_id = $_SESSION["mb_user_id"];
+$admin = new administration();
+$own_gui_id_array = $admin->getGuisByOwner($logged_user_id);
+$own_wms_id_array = $admin->getWmsByOwnGuis($own_gui_id_array);
+$cnt_wms = count($own_wms_id_array);
+/*handle remove, update and insert*****************************************************************/
+if($insert){
+ if(count($selected_topic) > 0){
+ for($i=0; $i<count($selected_topic); $i++){
+ $exists = false;
+ $sql_insert = "SELECT * FROM wms_md_topic_category WHERE fkey_wms_id = $1 and fkey_md_topic_category_id = $2";
+ $v = array($selected_wms,$selected_topic[$i]);
+ $t = array('i','i');
+ $res_insert = db_prep_query($sql_insert,$v,$t);
+ while(db_fetch_row($res_insert)){$exists = true;}
+ if($exists == false){
+ $sql_insert = "INSERT INTO wms_md_topic_category (fkey_wms_id, fkey_md_topic_category_id) VALUES($1, $2)";
+if($remove){
+ if(count($remove_topic)>0){
+ for($i=0; $i<count($remove_topic); $i++){
+ $sql_remove = "DELETE FROM wms_md_topic_category WHERE fkey_md_topic_category_id = $1 and fkey_wms_id = $2";
+ $v = array($remove_topic[$i],$selected_wms);
+ $t = array('i','s');
+ db_prep_query($sql_remove,$v,$t);
+/*get all topics from selected wms*****************************************************************/
+$sql_wms_topic = "SELECT t.md_topic_category_id, t.md_topic_category_code_".$language_suffix." ";
+$sql_wms_topic .= "FROM wms_md_topic_category as w, md_topic_category as t WHERE w.fkey_wms_id = $1 AND w.fkey_md_topic_category_id = t.md_topic_category_id ";
+$sql_wms_topic .= "ORDER BY t.md_topic_category_code_".$language_suffix;
+if(!$selected_wms){$v = array($own_wms_id_array[0]);}
+if($selected_wms){$v = array($selected_wms);}
+$t = array('s');
+$res_wms_topic = db_prep_query($sql_wms_topic,$v,$t);
+$cnt_wms_topic=0;;
+while($row = db_fetch_array($res_wms_topic)){
+ $topic_id_wms[$cnt_wms_topic] = $row["md_topic_category_id"];
+ $topic_name_wms[$cnt_wms_topic] = $row["md_topic_category_code_".$language_suffix];
+ $cnt_wms_topic++;
+/*get all topics **********************************************************************************/
+$sql_topic = "SELECT * FROM md_topic_category ORDER BY md_topic_category_code_" . $language_suffix;
+$res_topic = db_query($sql_topic);
+$cnt_topic = 0;
+while($row = db_fetch_array($res_topic)){
+ if (!in_array($row["md_topic_category_id"], $topic_id_wms)) {
+ $topic_id[$cnt_topic] = $row["md_topic_category_id"];
+ $topic_name[$cnt_topic] = $row["md_topic_category_code_".$language_suffix];
+ $cnt_topic++;
+/*INSERT HTML*/
+echo "<form name='form1' action='" . $self ."' method='post'>";
+/*insert wms in selectbox*************************************************************************/
+echo "<div class='text1'>WMS: </div>";
+echo "<select style='background:#ffffff' class='select1' name='selected_wms' onChange='submit()' size='10'>";
+for($i=0; $i<$cnt_wms; $i++){
+ echo "<option value='" . $own_wms_id_array[$i] . "' ";
+ if($selected_wms && $selected_wms == $own_wms_id_array[$i]){
+ echo "selected";
+ echo ">" . $admin->getWmsTitleByWmsId($own_wms_id_array[$i]) . "</option>";
+echo "</select>";
+/*insert all groups in selectbox*******************************************************************/
+echo "<div class='text2'>TOPICS:</div><br>";
+echo "<select style='background:#ffffff' class='select2' multiple='multiple' name='selected_topic[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_topic; $i++){
+ echo "<option value='" . $topic_id[$i] . "'>" . $topic_name[$i] . "</option>";
+echo "</select>";
+/*Button*******************************************************************************************/
+echo "<div class='button1'><input type='button' value='==>' onClick='validate(\"insert\")'></div>";
+echo "<input type='hidden' name='insert'>";
+echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
+echo "<input type='hidden' name='remove'>";
+/*insert wms_topic_dependence and container_group_dependence in selectbox**************************************************/
+echo "<div class='text3'>SELECTED TOPICS:</div>";
+echo "<select style='background:#ffffff' class='select3' multiple='multiple' name='remove_topic[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_wms_topic; $i++){
+ echo "<option value='" . $topic_id_wms[$i] . "'>" . $topic_name_wms[$i] . "</option>";
+echo "</select>";
+echo "</form>";
+<script type="text/javascript">
+document.forms[0].selected_wms.focus();
+</script>
+</body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
