svn commit: r757 - trunk/mapbender/http/x_geoportal/gaz.php
uli at osgeo.org
uli at osgeo.org
Thu Aug 24 10:51:06 EDT 2006
Author: uli
Date: 2006-08-24 14:51:06+0000
New Revision: 757
Added:
under construction
without sense at that time
Added: trunk/mapbender/http/x_geoportal/gaz.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/x_geoportal/gaz.php?view=auto&rev=757
--- (empty file)
+++ trunk/mapbender/http/x_geoportal/gaz.php 2006-08-24 14:51:06+0000
@@ -0,0 +1,191 @@
+<?php
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once("../../conf/mapbender.conf");
+require_once("../classes/class_administration.php");
+require_once("../classes/class_mb_exception.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+echo $_SERVER["argv"][1];
+$admin = new administration();
+$user = "";
+$gui = "";
+$cl = 0;
+// retrieve username and gui_id
+if ($_REQUEST['user']) {
+ $cl = 0;
+ //browser
+ echo "browser";
+ $user = $_REQUEST['user'];
+ $gui = $_REQUEST['gui'];
+elseif ($_SERVER["argv"][1]) {
+ $cl = 1;
+ //command line
+ $p1 = $_SERVER["argv"][1];
+ $p2 = $_SERVER["argv"][2];
+ if (substr($p1, 0,5) == "user:") {
+ $user = substr($p1, 5);
+ if (substr($p2, 0,4) == "gui:") {
+ $gui = substr($p2, 4);
+else {
+ echo "Please specify a username!\n";die();
+$userid = $admin->getUserIdByUserName($user);
+if ($userid) {
+ $ownguis = $admin->getGuisByOwner($userid);
+ if ($gui) {
+ if (!$admin->guiExists($gui)) {
+ echo "GUI " . $gui . " doesn't exist.\n"; die();
+ elseif (in_array($gui, $ownguis)) {
+ $ownguis = array($gui);
+ else {
+ echo "User " . $user . " is not owner of GUI " . $gui . ".\n"; die();
+else {
+ echo $user . " is not a valid username.\n"; die();
+$wms_id_own = $admin->getWmsByOwnGuis($ownguis);
+// initialise monitoring processes
+echo "Starting monitoring cycle...\n\n";
+if ($cl == 0) echo "<br/><br/>";
+echo "WMS services are requested for availability.\n";
+if ($cl == 0) echo "<br/>";
+echo "Capabilities documents are requested and all changes synchronized with the database cache.\n\n";
+$time = strval(time()-2);
+for ($k=0; $k<count($wms_id_own); $k++) {
+ $sql = "SELECT wms_upload_url FROM wms WHERE wms_id = $1";
+ $v = array($wms_id_own[$k]);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ $someArray = db_fetch_row($res);
+ $url = $someArray[0];
+ if (!$upload_url || $upload_url == "") {
+ $sql = "SELECT wms_version, wms_getcapabilities FROM wms WHERE wms_id = $1";
+ $t = array('i');
+ $version = $someArray[0];
+ $capabilities = $someArray[1];
+ if ($version == "1.0.0" ) {
+ $url = $capabilities . "REQUEST=capabilities&WMTVER=1.0.0";
+ else {
+ $url = $capabilities . "REQUEST=GetCapabilities&SERVICE=wms&VERSION=" . $version;
+ $sql = "INSERT INTO mb_monitor (upload_id, fkey_wms_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated) ";
+ $sql .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8)";
+ $v = array($time,$wms_id_own[$k],"-2","Monitoring is still in progress...", time(),time(),$url,"0");
+ $t = array('s', 'i', 's', 's', 's', 's', 's', 's');
+ if (intval(AUTO_UPDATE)) {
+ $exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 1 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
+ else {
+ $exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 0 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
+ exec($exec);
+echo "Monitoring Cycle completed (total: " . count($wms_id_own) . " wms).\n\n";
+set_time_limit(2*TIME_LIMIT);
+// wait until all monitoring processes are finished
+echo "please wait " . TIME_LIMIT . " seconds for the monitoring to finish...\n\n";
+sleep(TIME_LIMIT);
+$sql = "SELECT fkey_wms_id, status, status_comment, timestamp_begin, timestamp_end, upload_url FROM mb_monitor WHERE upload_id = $1";
+$v = array($time);
+$t = array('i');
+$res = db_prep_query($sql,$v,$t);
+$cnt=0;
+while ($row = db_fetch_array($res)) {
+ $status[$cnt] = intval(db_result($res,$cnt,"status"));
+ $wms_id[$cnt] = db_result($res,$cnt,"fkey_wms_id");
+ $comment[$cnt] = db_result($res,$cnt,"status_comment");
+ $upload_url[$cnt] = db_result($res,$cnt,"upload_url");
+ $timestamp_begin[$cnt] = db_result($res,0,"timestamp_begin");
+ $timestamp_end[$cnt] = db_result($res,0,"timestamp_end");
+ $cnt++;
+$body = "";
+for ($i=0; $i<$cnt; $i++) {
+ // if monitoring is still in progress and time limit has expired, update database
+ if ($status[$i] == -2 && intval(time())-intval($timestamp_begin[$i]) > intval(TIME_LIMIT)) {
+ $comment[$i] = "Monitoring process timed out.";
+ $status[$i] = -1;
+ $new_sql = "UPDATE mb_monitor SET status = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
+ $new_v = array((intval($upload_id[$i])+intval(TIME_LIMIT)), $wms_id[$i], $time);
+ $new_t = array('s', 'i', 's');
+ $new_res = db_prep_query($new_sql,$new_v,$new_t);
+ // compose mail message
+ echo $wms_id[$i] . ": status " . $status[$i] . "\n";
+ if ($cl == 0) echo "<br/><br/>";
+ if ($status[$i] == -1) {
+ $body .= $admin->getWmsTitleByWmsId($wms_id[$i]) . " (" . $wms_id[$i] . "): " . $comment[$i] . "\n\n";
+// Send an email to the user
+if ($body) {
+ $error_msg = "";
+ if ($admin->getEmailByUserId($userid)) {
+ $admin->sendEmail(MAILADMIN, MAILADMINNAME, $admin->getEmailByUserId($userid), $user, "WMS monitor report " . date("F j, Y, G:i:s", $time), utf8_decode($body), &$error_msg);
+ else {
+ $error_msg = "Email address of user '" . $admin->getUserNameByUserId($userid) . "' unknown!\n";
+ if ($error_msg) {
+ echo "\n ERROR: " . $error_msg;
More information about the Mapbender_commits
