svn commit: r657 - trunk/mapbender/http/php/mod_monitorCapabilities_read_single.php
christoph at osgeo.org christoph at osgeo.org
Fri Jul 14 10:56:24 EDT 2006
Author: christoph
Date: 2006-07-14 14:56:24+0000
New Revision: 657
Added:
added new statistics plus detail view and enhanced visuals
Added: trunk/mapbender/http/php/mod_monitorCapabilities_read_single.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_monitorCapabilities_read_single.php?view=auto&rev=657
--- (empty file)
+++ trunk/mapbender/http/php/mod_monitorCapabilities_read_single.php	2006-07-14 14:56:24+0000
@@ -0,0 +1,102 @@
+<?php
+# $Id: mod_monitorCapabilities.php 371 2006-05-31 12:45:24Z christoph $
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#require_once("../php/mb_validateSession.php");
+require_once("../../conf/mapbender.conf");
+require_once("../classes/class_administration.php");
+session_start();
+import_request_variables("PG");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+</head>
+<body>
+<?php
+$admin = new administration();
+if ($_GET['wmsid']) {
+	$wms_id = intval($_GET['wmsid']);
+else {
+	echo "Invalid WMS ID.";
+	die;
+$sql = "SELECT upload_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
+$sql .= "WHERE fkey_wms_id = $1 AND NOT status = '-2' ORDER BY upload_id DESC";
+$v = array($wms_id);
+$t = array('i');
+$res = db_prep_query($sql,$v,$t);
+$cnt=0;
+while ($row = db_fetch_array($res)) {
+	$upload_id[$cnt] = db_result($res,$cnt,"upload_id");
+	$status[$cnt] = intval(db_result($res,$cnt,"status"));
+	$comment[$cnt] = db_result($res,$cnt,"status_comment");
+	$timestamp_begin = db_result($res,$cnt,"timestamp_begin");
+	$timestamp_end = db_result($res,$cnt,"timestamp_end");
+	$upload_url[$cnt] = db_result($res,$cnt,"upload_url");
+	if ($status[$cnt] == '0' || $status[$cnt] == '1') {
+		$response_time[$cnt] = strval($timestamp_end-$timestamp_begin) . " s";
+	else {
+		$response_time[$cnt] = "n/a";
+	$cnt++;
+$str = "<span style='font-size:30'>monitoring results</span><hr><br>\n";
+$str .= "<b>" . $wms_id . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id) . "<br><br><br>\n";
+$str .= "<table cellpadding=10 cellspacing=0 border=0>";
+$str .= "<tr bgcolor='#dddddd'><th align='left'>date</th><th align='left' colspan = 2>status</th><th align='center'>response time</th></tr>";
+for ($k=0; $k<count($upload_id); $k++) {
+	$img = "stop.bmp";
+	if ($status[$k]==0) $img = "wait.bmp";
+	elseif ($status[$k]==1) $img = "go.bmp";
+	if (fmod($k, 2) == 1) {
+		$str .= "\n\t\t<tr bgcolor='#e6e6e6'>";
+	else {
+		$str .= "\n\t\t<tr bgcolor='#f0f0f0'>";
+	$str .= "\n\t\t\t<td>".date("F j, Y, G:i:s", $upload_id[$k])."</td>";
+	$str .= "\n\t\t\t<td><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
+	$str .= "\n\t\t\t<td>" . $comment[$k] . "</td>";
+	$str .= "\n\t\t\t<td align='center'>" . $response_time[$k] . "</td>";
+#	$str .= "\n\t\t\t<td><a href='output_".$wms_id[$k]."_".$max.".txt' target=_blank>log</a></td>";
+$str .= "\n\t</table>\n\t";
+echo $str;
+</body></html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
