svn commit: r670 - trunk/mapbender/http/classes/class_wms.php
uli at osgeo.org uli at osgeo.org
Wed Jul 19 11:23:29 EDT 2006
Author: uli
Date: 2006-07-19 15:23:29+0000
New Revision: 670
layer update modified
update layer_styles included
update layer_epsg included
new function updateLayer
Modified: trunk/mapbender/http/classes/class_wms.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wms.php?view=diff&rev=670&p1=trunk/mapbender/http/classes/class_wms.php&p2=trunk/mapbender/http/classes/class_wms.php&r1=669&r2=670
--- trunk/mapbender/http/classes/class_wms.php	(original)
+++ trunk/mapbender/http/classes/class_wms.php	2006-07-19 15:23:29+0000
@@ -707,8 +707,60 @@
 	$this->insertLayerEPSG($i);
 	# TABLE layer_style for each layer
-	$this->insertLayerStyle($i);
+	$this->insertLayerStyle($i);
+function updateLayer($i,$myWMS){
+	$sql = "SELECT layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_name = $2";
+	$v = array($myWMS,$this->objLayer[$i]->layer_name);
+	$t = array('i','s');
+	$res = db_prep_query($sql,$v,$t);
+	if($row = db_fetch_array($res)){
+		$l_id = $row['layer_id'];
+	else{
+		db_rollback();
+		$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name);
+		return;
+	$sql = "UPDATE layer SET ";
+	$sql .= "layer_pos = $1, ";
+	$sql .= "layer_parent = $2, ";
+	$sql .= "layer_title = $3, ";
+	$sql .= "layer_queryable = $4, ";
+	$sql .= "layer_minscale = $5, ";
+	$sql .= "layer_maxscale = $6, ";
+	$sql .= "layer_dataurl = $7, ";
+	$sql .= "layer_metadataurl = $8 ";
+	$sql .= "WHERE layer_id = $9";
+	if($this->objLayer[$i]->layer_id != null){
+		$tmpPos =  $this->objLayer[$i]->layer_id;
+	else {
+		$tmpPos .= 0;
+	if($this->objLayer[$i]->layer_parent == '' && $this->objLayer[$i]->layer_parent != '0'){
+		$this->objLayer[$i]->layer_parent = '';
+	$v = array($tmpPos,$this->objLayer[$i]->layer_parent,
+			$this->objLayer[$i]->layer_title,
+			$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,
+			$this->objLayer[$i]->layer_maxscale,$this->objLayer[$i]->layer_dataurl_href,
+			$this->objLayer[$i]->layer_metadataurl, $l_id
+	$t = array('i','s','s','i','i','i','s','s','i');
+	if(!$res){
+		db_rollback();
+	# save the id of each layer: set param2 true
+	$this->objLayer[$i]->db_id = $l_id;
+	$this->insertLayerEPSG($i);
+	# TABLE layer_style for each layer
 function insertGuiLayer($i,$myWMS,$gui_id){
 	# table gui_layer
@@ -764,6 +816,9 @@
 function insertLayerEPSG($i){
+	$sql = "DELETE FROM layer_epsg WHERE fkey_layer_id = $1";
+	$v = array($this->objLayer[$i]->db_id);
+	$t = array('s');
 	for($j=0; $j<count($this->objLayer[$i]->layer_epsg);$j++){
 		$sql = "INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) ";
 		$sql .= "VALUES($1,$2,$3,$4,$5,$6)";
@@ -779,6 +834,10 @@
 function insertLayerStyle($i){
+	$sql = "DELETE FROM layer_style WHERE fkey_layer_id = $1";
+	$t = array('s');
 	for($j=0; $j<count($this->objLayer[$i]->layer_style);$j++){
 		$sql = "INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) ";
 		$sql .= "VALUES($1,$2,$3,$4,$5)";
@@ -882,6 +941,7 @@
 	for($i=0; $i<count($this->objLayer); $i++){
 		if(in_array($this->objLayer[$i]->layer_name,$exLayer)){
 			//echo "<br>update: ".$this->objLayer[$i]->layer_name;
+			$this->updateLayer($i,$myWMS);
 			for($j=0; $j<count($exGui); $j++){
 				$this->updateGuiLayer($i,$myWMS,$exGui[$j]);
@@ -924,6 +984,14 @@
 			$res1 = db_prep_query($sql1,$v,$t);
 			if(!$res1){db_rollback();}
+		if($this->objLayer[$i]->layer_queryable == 1){
+			$sql1 = "UPDATE gui_layer set gui_layer_queryable = 1 ";
+			$sql1 .= "WHERE fkey_layer_id = $1 and fkey_gui_id = $2";
+			$v = array($l_id,$gui_id);
+			$res1 = db_prep_query($sql1,$v,$t);
+			if(!$res1){db_rollback();}
 		if($row["gui_layer_minscale"] < $this->objLayer[$i]->layer_minscale){
 			$sql1 = "UPDATE gui_layer set gui_layer_minscale = $1 ";
 			$sql1 .= "WHERE fkey_layer_id = $2 and fkey_gui_id = $3";
More information about the Mapbender_commits mailing list
