svn commit: r702 - trunk/mapbender/http/php/mod_zoomCoords.php
astrid_emde at osgeo.org astrid_emde at osgeo.org
Wed Jul 26 10:01:58 EDT 2006
Author: astrid_emde
Date: 2006-07-26 14:01:58+0000
New Revision: 702
change: db connection is opened earlier
Modified: trunk/mapbender/http/php/mod_zoomCoords.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_zoomCoords.php?view=diff&rev=702&p1=trunk/mapbender/http/php/mod_zoomCoords.php&p2=trunk/mapbender/http/php/mod_zoomCoords.php&r1=701&r2=702
--- trunk/mapbender/http/php/mod_zoomCoords.php	(original)
+++ trunk/mapbender/http/php/mod_zoomCoords.php	2006-07-26 14:01:58+0000
@@ -34,6 +34,9 @@
 <title>Zoom to Coordinate</title>
 <?php
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
 include '../include/dyn_css.php';
 <style type="text/css">
@@ -84,8 +87,7 @@
 </style>
 <?php
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
 $sql = "SELECT e_target FROM gui_element WHERE e_id = 'zoomCoords' AND fkey_gui_id = $1 ";
 $v = array($_SESSION["mb_user_gui"]);
 $t = array('s');
@@ -106,15 +108,15 @@
 <script type="text/javascript">
 function zoomCoordinate(){
-	var coordx = document.form1.X.value;
-	var coordy = document.form1.Y.value;
-	coordx = coordx.replace(",",".");
-	coordy = coordy.replace(",",".");
-	var valid = true;
-	setPermanentMarker(coordx,coordy);
-	parent.mb_hideHighlight(target[0]);
-	parent.mb_hideHighlight(target[1]);
-	parent.zoom(target[0],true, 1.0,coordx,coordy);
+   var coordx = document.form1.X.value;
+   var coordy = document.form1.Y.value;
+   coordx = coordx.replace(",",".");
+   coordy = coordy.replace(",",".");
+   var valid = true;
+   setPermanentMarker(coordx,coordy);
+   parent.mb_hideHighlight(target[0]);
+   parent.mb_hideHighlight(target[1]);
+   parent.zoom(target[0],true, 1.0,coordx,coordy);
 function highlight(x, y){
@@ -147,7 +149,7 @@
 <?php
 # needs intl'!
 	echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
-	echo "<span class='labelx'>Länge:</span>";
+	echo "<span class='labelx'>L&auml;nge:</span>";
 	echo "<span class='labely'>Breite:</span>";
 	echo "<input class='textx' type='text' name='X'>";
 	echo "<input class='texty' type='text' name='Y'>";
More information about the Mapbender_commits mailing list
