svn commit: r707 - trunk/mapbender/http/frames/login.php
uli at osgeo.org uli at osgeo.org
Thu Jul 27 09:01:45 EDT 2006
Author: uli
Date: 2006-07-27 13:01:45+0000
New Revision: 707
switch to encrypt passwords in md5
if there are unencrypted or mysql-password encrypted passwords
Modified: trunk/mapbender/http/frames/login.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/frames/login.php?view=diff&rev=707&p1=trunk/mapbender/http/frames/login.php&p2=trunk/mapbender/http/frames/login.php&r1=706&r2=707
--- trunk/mapbender/http/frames/login.php	(original)
+++ trunk/mapbender/http/frames/login.php	2006-07-27 13:01:45+0000
@@ -22,6 +22,7 @@
 db_select_db(DB,$con);
 function auth_user($name,$pw){
+	$setEncPw = false;
 	$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = $2";
 	$v = array($name,md5($pw));
 	$t = array('s','s');
@@ -29,27 +30,30 @@
 	if($row = db_fetch_array($res)){
 		return $row;
-	if(SYS_DBTYPE == 'pgsql'){
+	else if(SYS_DBTYPE == 'pgsql' && $setEncPw == true){
+		// 	unencrypted pw in postgres without md5-support?
+		$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = $2";
 		$v = array($name,$pw);
-		$res = db_prep_query($sql,$v,$t);
-		if($row = db_fetch_array($res)){
+		$t = array('s','s');
+		$resn = db_prep_query($sql,$v,$t);
+		if($rown = db_fetch_array($resn)){
 			$sqlu = "UPDATE mb_user SET mb_user_password = $1 WHERE mb_user_id = $2";
-			$vu = array(md5($pw),$row["mb_user_id"]);
+			$vu = array(md5($pw),$rown["mb_user_id"]);
 			$tu = array('s','i');
 			$rowu = db_prep_query($sqlu,$vu,$tu);
-			return $row;
+			return $rown;
-	else if(SYS_DBTYPE == 'mysql'){
+	else if(SYS_DBTYPE == 'mysql' && $setEncPw == true){
 		$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = password($2)";
-			return $row;
+			return $rown;
More information about the Mapbender_commits mailing list
