svn commit: r376 - trunk/mapbender/http/classes/class_wms.php
uli at osgeo.org uli at osgeo.org
Thu Jun 1 08:43:18 EDT 2006
Author: uli
Date: 2006-06-01 12:43:18+0000
New Revision: 376
bug fixed: parent layer value
Modified: trunk/mapbender/http/classes/class_wms.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wms.php?view=diff&rev=376&p1=trunk/mapbender/http/classes/class_wms.php&p2=trunk/mapbender/http/classes/class_wms.php&r1=375&r2=376
--- trunk/mapbender/http/classes/class_wms.php	(original)
+++ trunk/mapbender/http/classes/class_wms.php	2006-06-01 12:43:18+0000
@@ -689,9 +689,12 @@
 	else {
 		$tmpPos .= 0;
-	if(empty($this->objLayer[$i]->layer_parent)){
-		$this->objLayer[$i]->layer_parent = '""';
+	echo $this->objLayer[$i]->layer_name. " x ".$this->objLayer[$i]->layer_parent."<br>";
+	if($this->objLayer[$i]->layer_parent == '' && $this->objLayer[$i]->layer_parent != '0'){
+		$this->objLayer[$i]->layer_parent = '';
 	$v = array($myWMS,$tmpPos,$this->objLayer[$i]->layer_parent,$this->objLayer[$i]->layer_name,
 			$this->objLayer[$i]->layer_title,
 			$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,
@@ -701,7 +704,7 @@
 	$res = db_prep_query($sql,$v,$t);
 	if(!$res){
 		db_rollback();
 	# save the id of each layer: set param2 true
 	$this->objLayer[$i]->db_id = db_insert_id($con, 'layer','layer_id');
More information about the Mapbender_commits mailing list
