svn commit: r536 - trunk/mapbender/http/tools/mapbender_setup.php
marko at osgeo.org marko at osgeo.org
Mon Jun 19 13:47:57 EDT 2006
Author: marko
Date: 2006-06-19 17:47:57+0000
New Revision: 536
mb.conf md5 check deleted
Modified: trunk/mapbender/http/tools/mapbender_setup.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/tools/mapbender_setup.php?view=diff&rev=536&p1=trunk/mapbender/http/tools/mapbender_setup.php&p2=trunk/mapbender/http/tools/mapbender_setup.php&r1=535&r2=536
--- trunk/mapbender/http/tools/mapbender_setup.php	(original)
+++ trunk/mapbender/http/tools/mapbender_setup.php	2006-06-19 17:47:57+0000
@@ -1,5 +1,5 @@
 <?php
- # $Id:$
+ # $Id$
  # Copyright (C) 2002 CCGIS
  # Created on 18.05.2006/10:03:40
@@ -215,14 +215,11 @@
 # DB Owner
 	if (OWNER !="<owner>" && OWNER != "") $check .="<tr><td>DB-Owner</td><td>X</td><td><font color=#00D000>" . OWNER . "</font><font color='#0000FF'> (is this your DB-Owner)</font></td></tr>";
 	else $check .="<tr><td>DB-Owner</td><td></td><td><font color=#FF0000>" . OWNER . " is not defined</font></td></tr>";
-# MD5 check
-	if (MD5 =="true") $check .="<tr><td>MD-check</td><td>X</td><td><font color=#00D000>" . MD5 . "</font></td></tr>";
-	else $check .="<tr><td>MD-check</td><td></td><td><font color=#FF0000>" . MD5 . " =>MD5 is disabled. Think about using MD5!</font></td></tr>";
 # PREPAREDSTATEMENTS
 	if (defined('PREPAREDSTATEMENTS')){
 		if (PREPAREDSTATEMENTS == true){
 			if (phpversion()<'5.1.0') $check.="<tr><td width=\"25%\">PREPAREDSTATEMENTS-<br>compatibility</td><td width=\"10\"></td><td><font color=\"#ff0000\">PREPAREDSTATEMENTS = true and php version " . phpversion() . " is incompatible<br>set PREPAREDSTATEMENTS to false or update php to >=5.1</td></tr>";
-			else $check .="<tr><td width=\"25%\">PREPAREDSTATEMENTS-<br>compatibility</td><td width=\"10\"><font color=#00D000>V</font></td><td><font color=#00D000>true and php " . phpversion() . " should work</td><tr/>";
+			else $check .="<tr><td width=\"25%\">PREPAREDSTATEMENTS-<br>compatibility</td><td width=\"10\">X</td><td><font color=#00D000>true and php " . phpversion() . " should work</td><tr/>";
 		else{
 			if (phpversion()<'5.1.0') $check .="<tr><td width=\"25%\">PREPAREDSTATEMENTS-<br>compatibility</td><td width=\"10\">X</td><td><font color=#00D000>false and php " . phpversion() . " should work </font><font color='#0000FF'> (but think about upgrading to php 5.1)</td><tr/>";
More information about the Mapbender_commits mailing list
