svn commit: r600 - trunk/mapbender/http/javascripts
christoph at osgeo.org christoph at osgeo.org
Wed Jun 21 13:29:14 EDT 2006
Author: christoph
Date: 2006-06-21 17:29:13+0000
New Revision: 600
   trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
   trunk/mapbender/http/javascripts/wfs.js
   trunk/mapbender/http/javascripts/wfs_usemap.js
added usemap to wfs results
Modified: trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php?view=diff&rev=600&p1=trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php&p2=trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php&r1=599&r2=600
--- trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php	(original)
+++ trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php	2006-06-21 17:29:13+0000
@@ -177,15 +177,17 @@
 	mb_zF = mod_wfs_spatialRequest_target;
 function mod_selAreaExt_setValidClipping(coords){
-	mod_wfs_spatialRequest_geometry.addPoint(new Point(coords[0],coords[1]));
-	mod_wfs_spatialRequest_geometry.addPoint(new Point(coords[2],coords[3]));
-	if(mod_wfs_spatialRequest_geometry.count() == 2){
-		mod_getAreaExt_send();
-	else{
-		alert("Ausschnitt ungültig!")
-		mb_disableThisButton(activeButton.id);
+	if (mod_wfs_spatialRequest_geometry != null) {
+		mod_wfs_spatialRequest_geometry.addPoint(new Point(coords[0],coords[1]));
+		mod_wfs_spatialRequest_geometry.addPoint(new Point(coords[2],coords[3]));
+		if(mod_wfs_spatialRequest_geometry.count() == 2){
+			mod_getAreaExt_send();
+		else{
+			alert("Ausschnitt ungültig!")
+			mb_disableThisButton(activeButton.id);
Modified: trunk/mapbender/http/javascripts/wfs.js
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/wfs.js?view=diff&rev=600&p1=trunk/mapbender/http/javascripts/wfs.js&p2=trunk/mapbender/http/javascripts/wfs.js&r1=599&r2=600
--- trunk/mapbender/http/javascripts/wfs.js	(original)
+++ trunk/mapbender/http/javascripts/wfs.js	2006-06-21 17:29:13+0000
@@ -1,5 +1,6 @@
 <?php
 require_once("mod_geometryArray.js");
+require_once("wfs_usemap.js");
 var digiFrame = "digitize";
 var mb_wfs_fetched = new Array();
@@ -25,7 +26,10 @@
 var canvas = new Array();
 var canvasHasDrawing = new Array();
 var useCheckboxForHighlighting = true;
-var useUsemap = false;
+if (parseInt(useUsemap) == 1) {
+	mb_registerSubFunctions('mod_usemap("")');
 var wfsResultToDigitizeModule = false;
 if (isSetWfsResultToDigitize()) {
@@ -36,9 +40,6 @@
 	mb_registerSubFunctions('highlightGeometry()');
-if (useUsemap) {
-	mb_registerSubFunctions('mod_usemap("")');
 if (useExtentIsSet()) {
 	mb_registerSubFunctions("mb_setwfsrequest_extent()");
@@ -280,7 +281,7 @@
 	str += "</table>";
 	mb_wfs_objwin.innerHTML = str;
-	if (useUsemap) {
+	if (parseInt(useUsemap) == 1) {
 		mod_usemap(wfs_name);
Modified: trunk/mapbender/http/javascripts/wfs_usemap.js
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/wfs_usemap.js?view=diff&rev=600&p1=trunk/mapbender/http/javascripts/wfs_usemap.js&p2=trunk/mapbender/http/javascripts/wfs_usemap.js&r1=599&r2=600
--- trunk/mapbender/http/javascripts/wfs_usemap.js	(original)
+++ trunk/mapbender/http/javascripts/wfs_usemap.js	2006-06-21 17:29:13+0000
@@ -2,26 +2,25 @@
 // --- usemap (begin) --------------------------------------------------------------------------------------------
-function mod_usemap (wfs_name) {
+function mod_usemap(wfs_name) {
 	if (wfs_name == "") {
 		usemap = "";
-	var ind = getMapObjIndexByName(mb_wfs_targets[0]);
-	var myImg = window.frames[mb_wfs_targets[0]].document.getElementById("um_img").style;
+	var ind = getMapObjIndexByName(mb_wfs_target);
+	var myImg = window.frames[mb_wfs_target].document.getElementById("um_img").style;
 	myImg.width = mb_mapObj[ind].width;
 	myImg.height = mb_mapObj[ind].height;
-	for (var i = 0 ; i < mb_wfs_fetch.length ; i ++) {
-		if (mb_wfs_fetch[i]['wfs_conf'] == wfs_name || wfs_name == "") {
+	for (var i = 0 ; i < mb_wfs_fetch.count() ; i ++) {
+		if (mb_wfs_fetch.get(i).wfs_conf == wfs_name || wfs_name == "") {
-			if (mb_wfs_fetch[i]['geomtype'] == geomTypePolygon) {
+			if (mb_wfs_fetch.get(i).geomtype == geomTypePolygon) {
 				usemap += mod_usemap_polygon(i);
-			else if (mb_wfs_fetch[i]['geomtype'] == geomTypePoint) {
+			else if (mb_wfs_fetch.get(i).geomtype == geomTypePoint) {
 				usemap += mod_usemap_circle(i);
-			else if (mb_wfs_fetch[i]['geomtype'] == geomTypeLine) {
+			else if (mb_wfs_fetch.get(i).geomtype == geomTypeLine) {
 				usemap += mod_usemap_line(i);
@@ -33,94 +32,76 @@
 	var str = "";
 	var coord = "";
-	for (var i = 0 ; i < mb_wfs_fetch[ind]['geometry'].length ; i ++) {
-		var xArray = mb_wfs_fetch[ind]['geometry'][i]['x'];
-		var yArray = mb_wfs_fetch[ind]['geometry'][i]['y'];
-		var title = getElementValueByName(mb_wfs_fetch, ind, "name") + " (Pt)";
-		var pos = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[0],yArray[0]);
-		coord += pos[0] + ", " + pos[1];
+	var title = "";
+	for (var i = 0 ; i < mb_wfs_fetch.get(ind).e.count(); i++) {
+		if (i>0) title += "&#10;";
+		title += mb_wfs_fetch.get(ind).e.getName(i) + ": " + mb_wfs_fetch.get(ind).e.getValue(i);
+	for (var i = 0 ; i < mb_wfs_fetch.get(ind).count() ; i ++) {
+		var p = mb_wfs_fetch.getPoint(ind, i, 0);
+		var pos = realToMap(mb_wfs_target,p);
+		coord += pos.x + ", " + pos.y;
-		str += "<AREA  onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
-		str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' shape='circle'  coords='";
+		str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
+		str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='circle'  coords='";
 		str += coord + ", " + mod_usemap_radius + "' href='#'>";
 	return str;
-function mod_usemap_line_calculate (xArray, yArray, j, orientation, cnt) {
+function mod_usemap_line_calculate (aGeometry, j, orientation, cnt) {
 	var coord = "";
-	var p1 = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[j],yArray[j]);
-	var p2 = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[j+orientation],yArray[j+orientation]);
+	var p1 = realToMap(mb_wfs_targets[0],aGeometry.get(j));
+	var p2 = realToMap(mb_wfs_targets[0],aGeometry.get(j+orientation));
-	var vec = new Array();
-	vec[0] = p2[0] - p1[0];
-	vec[1] = p2[1] - p1[1];
+	var vec = p2.minus(p1);
-	if (vec[0] != 0 || vec[1] != 0) {
-		n_vec = new Array();
-		if (vec[0] != 0) {
-			if (vec[0] > 0) {
-				n_vec[0] = (-vec[1])/vec[0];
-				n_vec[1] = -1;
-			else {
-				n_vec[0] = (vec[1])/vec[0];
-				n_vec[1] = 1;
+	if (vec.x != 0 || vec.y != 0) {
+		var n_vec;
+		if (vec.x != 0) {
+			if (vec.x > 0) n_vec = new Point((-vec.y)/vec.x, -1);
+			else n_vec = new Point(vec.y/vec.x, 1);
 		else {
-			if (vec[1] > 0) {
-				n_vec[0] = 1;
-				n_vec[1] = 0;
-			else {
-				n_vec[0] = -1;
-				n_vec[1] = 0;
+			if (vec.y > 0) n_vec = new Point(1,0);
+			else n_vec = new Point(-1,0);
+		n_vec = n_vec.times(mod_usemap_line_tolerance).dividedBy(n_vec.dist(new Point(0,0)))
-		n_vec_length = Math.sqrt(Math.pow(n_vec[0], 2) + Math.pow(n_vec[1], 2));
-		n_vec[0] = (n_vec[0]*mod_usemap_line_tolerance)/n_vec_length;
-		n_vec[1] = (n_vec[1]*mod_usemap_line_tolerance)/n_vec_length;
-		lp = new Array();
-		lp[0] = p1[0] + n_vec[0];
-		lp[1] = p1[1] - n_vec[1];
+		lp = new Point(p1.x + n_vec.x, p1.y - n_vec.y);
-		if (cnt > 0) {
-			coord += ", ";
-		coord += parseInt(lp[0]) + ", " + parseInt(lp[1]);
-		coord += ", " + parseInt(lp[0]+vec[0]) + ", " + parseInt(lp[1]+vec[1]);
+		if (cnt > 0) coord += ", ";
+		coord += parseInt(lp.x) + ", " + parseInt(lp.y);
+		coord += ", " + parseInt(lp.x+vec.x) + ", " + parseInt(lp.y+vec.y);
 	return coord;
 function mod_usemap_line(ind){
 	var str = "";
+	var title = "";
 		var coord = "";
 		var cnt = 0;
-		xArray = new Array();
-		xArray = mb_wfs_fetch[ind]['geometry'][i]['x'];
-		yArray = new Array();
-		yArray = mb_wfs_fetch[ind]['geometry'][i]['y'];
-		for (var j = 0 ; j < xArray.length - 1  ; j ++) {
-			var result = mod_usemap_line_calculate(xArray, yArray, j, 1, cnt);
+		for (var j = 0 ; j < mb_wfs_fetch.getGeometry(ind,i).count() - 1  ; j ++) {
+			var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, 1, cnt);
 			if (result != "") {
 				coord += result;
 				cnt++;
-		for (var j = (xArray.length - 1) ; j > 0 ; j--) {
-			var result = mod_usemap_line_calculate(xArray, yArray, j, -1, cnt);
+		for (var j = (mb_wfs_fetch.getGeometry(ind,i).count() - 1) ; j > 0 ; j--) {
+			var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, -1, cnt);
 			if (result != "") {
 				coord += result;
 				cnt++;
@@ -128,19 +109,19 @@
 		if (coord != "") {
-			str += "<AREA ";
-			str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
-			str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' ";
+			str += "<AREA title='"+title+"'";
+			str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
+			str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' ";
 			str += "shape='poly'  coords='";
 			str += coord + "' href='#'>";
 		else {
 			//display circle
+			var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,0));
+			str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
@@ -151,21 +132,23 @@
 function mod_usemap_polygon(ind){
 	var str = "";
 	var coord = "";
-		var title = getElementValueByName(mb_wfs_fetch, ind, "name") + " (Py)";
-		for (var j = 1 ; j < xArray.length ; j ++) {
-			pos = makeRealWorld2mapPos(mb_wfs_targets[0],xArray[j],yArray[j]);
-			coord += ", " + pos[0] + ", " + pos[1];
+	var title = "";
+		var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, 0));
+		for (var j = 1 ; j < mb_wfs_fetch.getGeometry(ind,i).count() ; j ++) {
+			pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, j));
+			coord += ", " + pos.x + ", " + pos.y;
-		str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch["+ind+"])' shape='poly'  coords='";
+		str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='poly'  coords='";
More information about the Mapbender_commits mailing list
