svn commit: r632 - trunk/mapbender/http/javascripts/mod_initWmc.php
christoph at osgeo.org christoph at osgeo.org
Tue Jun 27 05:03:05 EDT 2006
Author: christoph
Date: 2006-06-27 09:03:05+0000
New Revision: 632
fixed two bugs
now checking
- if wmc $_SESSION["mb_myWmc"] exists.
- if wmc $_SESSION["mb_myWmc"] belongs to user $_SESSION["mb_user_id"]
Modified: trunk/mapbender/http/javascripts/mod_initWmc.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_initWmc.php?view=diff&rev=632&p1=trunk/mapbender/http/javascripts/mod_initWmc.php&p2=trunk/mapbender/http/javascripts/mod_initWmc.php&r1=631&r2=632
--- trunk/mapbender/http/javascripts/mod_initWmc.php	(original)
+++ trunk/mapbender/http/javascripts/mod_initWmc.php	2006-06-27 09:03:05+0000
@@ -1,6 +1,7 @@
 <?php
 session_start();
 require_once("../classes/class_wmc.php");
+require_once("../classes/class_administration.php");
 $con = db_connect($DBSERVER,$OWNER,$PW);
 db_select_db(DB,$con);
@@ -17,23 +18,36 @@
 if($cnt > 1){
 	echo "alert('digitize_button: ID not unique!');";
-echo "var wmc_id = false;";
 $js = "function mod_initWMC_init() {";
-//echo "alert('".$_SESSION['mb_myWmc']."');";
-if ($_SESSION['mb_myWmc']) {
-	echo "wmc_id = '".$_SESSION['mb_myWmc']."';";
-	$wmc_id = $_SESSION['mb_myWmc'];
-	$wmc = new wmc();
-	$wmc->createObjFromWMC($wmc_id);
-	$js .= "deleteWmsObject();\n";
-	$js .= $wmc->createJsObjFromWMC("", $e_target[0]);
-	$js .= "var index = getMapObjIndexByName('" . $e_target[0] . "');\n";
-	$js .= "document.getElementById('".$e_target[0]."').style.width = mb_mapObj[index].width;\n";
-	$js .= "document.getElementById('".$e_target[0]."').style.height = mb_mapObj[index].height;\n";
-	$js .= "mb_execloadWmsSubFunctions();\n";
+$adm = new administration();
+$valid_wmcs = $adm->getWmcByOwner($_SESSION["mb_user_id"]);
+if ($adm->getWmcById($_SESSION['mb_myWmc']) != false) {
+	if (in_array($_SESSION['mb_myWmc'], $valid_wmcs)) {
+		echo "var wmc_id = false;";
+		echo "wmc_id = '".$_SESSION['mb_myWmc']."';";
+		$wmc = new wmc();
+		$wmc->createObjFromWMC($_SESSION['mb_myWmc']);
+		$js .= "deleteWmsObject();\n";
+		$js .= $wmc->createJsObjFromWMC("", $e_target[0]);
+		$js .= "var index = getMapObjIndexByName('" . $e_target[0] . "');\n";
+		$js .= "document.getElementById('".$e_target[0]."').style.width = mb_mapObj[index].width;\n";
+		$js .= "document.getElementById('".$e_target[0]."').style.height = mb_mapObj[index].height;\n";
+		$js .= "mb_execloadWmsSubFunctions();\n";
+	else {
+		$js .= "alert('".$adm->getUserNameByUserId($_SESSION["mb_user_id"])." is not allowed to access WMC ".$_SESSION['mb_myWmc'].". Default GUI will be loaded instead.');";
+else {
+	$js .= "alert('WMC id ".$_SESSION['mb_myWmc']." is not valid. Default GUI will be loaded instead.');";
 $js .= "}";
 echo $js;
 mb_registerInitFunctions("mod_initWMC()");
More information about the Mapbender_commits mailing list
