svn commit: r634 - trunk/mapbender/http/javascripts/mod_initWmc.php
christoph at osgeo.org christoph at osgeo.org
Tue Jun 27 06:44:26 EDT 2006
Author: christoph
Date: 2006-06-27 10:44:26+0000
New Revision: 634
fixed 1 small bug
Modified: trunk/mapbender/http/javascripts/mod_initWmc.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_initWmc.php?view=diff&rev=634&p1=trunk/mapbender/http/javascripts/mod_initWmc.php&p2=trunk/mapbender/http/javascripts/mod_initWmc.php&r1=633&r2=634
--- trunk/mapbender/http/javascripts/mod_initWmc.php	(original)
+++ trunk/mapbender/http/javascripts/mod_initWmc.php	2006-06-27 10:44:26+0000
@@ -22,27 +22,29 @@
 $js = "function mod_initWMC_init() {";
 $adm = new administration();
-if ($adm->getWmcById($_SESSION['mb_myWmc']) != false) {
-	$valid_wmcs = $adm->getWmcByOwner($_SESSION["mb_user_id"]);
-	if (in_array($_SESSION['mb_myWmc'], $valid_wmcs)) {
-		echo "var wmc_id = false;";
-		echo "wmc_id = '".$_SESSION['mb_myWmc']."';";
-		$wmc = new wmc();
-		$wmc->createObjFromWMC($_SESSION['mb_myWmc']);
-		$js .= "deleteWmsObject();\n";
-		$js .= $wmc->createJsObjFromWMC("", $e_target[0]);
-		$js .= "var index = getMapObjIndexByName('" . $e_target[0] . "');\n";
-		$js .= "document.getElementById('".$e_target[0]."').style.width = mb_mapObj[index].width;\n";
-		$js .= "document.getElementById('".$e_target[0]."').style.height = mb_mapObj[index].height;\n";
-		$js .= "mb_execloadWmsSubFunctions();\n";
+if ($_SESSION['mb_myWmc']) {
+	if ($adm->getWmcById($_SESSION['mb_myWmc']) != false) {
+		$valid_wmcs = $adm->getWmcByOwner($_SESSION["mb_user_id"]);
+		if (in_array($_SESSION['mb_myWmc'], $valid_wmcs)) {
+			echo "var wmc_id = false;";
+			echo "wmc_id = '".$_SESSION['mb_myWmc']."';";
+			$wmc = new wmc();
+			$wmc->createObjFromWMC($_SESSION['mb_myWmc']);
+			$js .= "deleteWmsObject();\n";
+			$js .= $wmc->createJsObjFromWMC("", $e_target[0]);
+			$js .= "var index = getMapObjIndexByName('" . $e_target[0] . "');\n";
+			$js .= "document.getElementById('".$e_target[0]."').style.width = mb_mapObj[index].width;\n";
+			$js .= "document.getElementById('".$e_target[0]."').style.height = mb_mapObj[index].height;\n";
+			$js .= "mb_execloadWmsSubFunctions();\n";
+		else {
+			$js .= "alert('".$adm->getUserNameByUserId($_SESSION["mb_user_id"])." is not allowed to access WMC ".$_SESSION['mb_myWmc'].". Default GUI will be loaded instead.');";
 	else {
-		$js .= "alert('".$adm->getUserNameByUserId($_SESSION["mb_user_id"])." is not allowed to access WMC ".$_SESSION['mb_myWmc'].". Default GUI will be loaded instead.');";
+		$js .= "alert('WMC id ".$_SESSION['mb_myWmc']." is not valid. Default GUI will be loaded instead.');";
-else {
-	$js .= "alert('WMC id ".$_SESSION['mb_myWmc']." is not valid. Default GUI will be loaded instead.');";
 $js .= "}";
 echo $js;
More information about the Mapbender_commits mailing list
