svn commit: r217 - trunk/mapbender/http/classes/class_administration.php
uli at osgeo.org uli at osgeo.org
Wed May 10 08:13:30 EDT 2006
Author: uli
Date: 2006-05-10 12:13:29+0000
New Revision: 217
new function getModulPermission($userID,$guiID,$elementID)
Modified: trunk/mapbender/http/classes/class_administration.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_administration.php?view=diff&rev=217&p1=trunk/mapbender/http/classes/class_administration.php&p2=trunk/mapbender/http/classes/class_administration.php&r1=216&r2=217
--- trunk/mapbender/http/classes/class_administration.php	(original)
+++ trunk/mapbender/http/classes/class_administration.php	2006-05-10 12:13:29+0000
@@ -20,12 +20,7 @@
 require("phpmailer-1.72/class.phpmailer.php");
 class administration{
-	function __construct(){
- 		$con = db_connect(DBSERVER,OWNER,PW);
- 		db_select_db(DB,$con);
 	function isValidEmail($email) {
 		if(eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
             return true;
@@ -659,5 +654,23 @@
 			return $url;
+	function getModulPermission($userID,$guiID,$elementID){
+		$g = $this->getGuisByPermission($userID);
+		if(in_array($guiID,$g)){
+			$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 AND e_id = $2 ";
+			$v = array($guiID,$elementID);
+			$t = array('s','s');
+			$res = db_prep_query($sql,$v,$t);
+			if($row = db_fetch_array($res)){
+				return true;
+			else{
+				return false;
+		else{
+			return false;
\ No newline at end of file
More information about the Mapbender_commits mailing list
