svn commit: r246 - trunk/mapbender/http/php/mod_group_filteredUser.php
uli at osgeo.org
uli at osgeo.org
Thu May 11 09:29:16 EDT 2006
Author: uli
Date: 2006-05-11 13:29:16+0000
New Revision: 246
db_prep_query included
verification of user permissions
Modified: trunk/mapbender/http/php/mod_group_filteredUser.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_group_filteredUser.php?view=diff&rev=246&p1=trunk/mapbender/http/php/mod_group_filteredUser.php&p2=trunk/mapbender/http/php/mod_group_filteredUser.php&r1=245&r2=246
--- trunk/mapbender/http/php/mod_group_filteredUser.php (original)
+++ trunk/mapbender/http/php/mod_group_filteredUser.php 2006-05-11 13:29:16+0000
@@ -18,13 +18,11 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
import_request_variables("PG");
-session_start();
-require_once("../php/mb_validateSession.php");
require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
+require_once("../php/mb_validatePermission.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
@@ -62,9 +60,6 @@
</head>
<body>
<?php
-require_once("../../conf/mapbender.conf");
-db_select_db(DB,$con);
$fieldHeight = 20;
@@ -78,17 +73,21 @@
$logged_user_name=$_SESSION["mb_user_name"];
$logged_user_id=$_SESSION["mb_user_id"];
-/*handle remove, update and insert**************************************************************************************/
+/*handle remove, update and insert*****************************************************************/
if($insert){
if(count($selected_user)>0){
for($i=0; $i<count($selected_user); $i++){
$exists = false;
- $sql_insert = "SELECT * from mb_user_mb_group where fkey_mb_group_id = '".$selected_group."' and fkey_mb_user_id = '".$selected_user[$i]."'";
- $res_insert = db_query($sql_insert);
+ $sql_insert = "SELECT * from mb_user_mb_group where fkey_mb_group_id = $1 and fkey_mb_user_id = $2";
+ $v = array($selected_group,$selected_user[$i]);
+ $t = array('i','i');
+ $res_insert = db_prep_query($sql_insert,$v,$t);
while(db_fetch_row($res_insert)){$exists = true;}
if($exists == false){
- $sql_insert = "INSERT INTO mb_user_mb_group(fkey_mb_group_id, fkey_mb_user_id) VALUES('$selected_group', '".$selected_user[$i]."');";
+ $sql_insert = "INSERT INTO mb_user_mb_group(fkey_mb_group_id, fkey_mb_user_id) VALUES($1, $2);";
@@ -96,14 +95,16 @@
if($remove){
if(count($remove_user)>0){
for($i=0; $i<count($remove_user); $i++){
- $sql_remove = "DELETE FROM mb_user_mb_group WHERE fkey_mb_user_id = '".$remove_user[$i]."' and fkey_mb_group_id = '$selected_group'";
- db_query($sql_remove);
+ $sql_remove = "DELETE FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 and fkey_mb_group_id = $2";
+ $v = array($remove_user[$i],$selected_group);
+ db_prep_query($sql_remove,$v,$t);
-/*get all group ********************************************************************************************/
+/*get all group **********************************************************************************/
$sql_group = "SELECT * FROM mb_group ORDER BY mb_group_name";
$res_group = db_query($sql_group);
while($row = db_fetch_array($res_group)){
@@ -112,37 +113,38 @@
$cnt_group++;
-/*get owner user **********************************************************************************************/
-$sql_user = "SELECT * FROM mb_user WHERE mb_user_owner=".$logged_user_id." ORDER BY mb_user_name";
-#$sql_user = "SELECT * FROM mb_user ORDER BY mb_user_name";
-$res_user = db_query($sql_user);
+/*get owner user **********************************************************************************/
+$sql_user = "SELECT * FROM mb_user WHERE mb_user_owner = $1 ORDER BY mb_user_name";
+$v = array($logged_user_id);
+$t = array('i');
+$res_user = db_prep_query($sql_user,$v,$t);
while($row = db_fetch_array($res_user)){
$user_id[$cnt_user] = $row["mb_user_id"];
$user_name[$cnt_user] = $row["mb_user_name"];
$cnt_user++;
-/*get only owner user from selected group******************************************************************************/
+/*get only owner user from selected group**********************************************************/
$sql_mb_user_mb_group = "SELECT mb_user.mb_user_id, mb_user.mb_user_name, mb_user_mb_group.fkey_mb_group_id FROM mb_user_mb_group ";
$sql_mb_user_mb_group .= "INNER JOIN mb_user ON mb_user_mb_group.fkey_mb_user_id = mb_user.mb_user_id ";
-$sql_mb_user_mb_group .= "WHERE mb_user_mb_group.fkey_mb_group_id= '";
-if(!$selected_group){$sql_mb_user_mb_group .= $group_id[0];}
-if($selected_group){$sql_mb_user_mb_group .= $selected_group;}
-$sql_mb_user_mb_group .= "' AND mb_user.mb_user_owner = '".$logged_user_id."'";
+$sql_mb_user_mb_group .= "WHERE mb_user_mb_group.fkey_mb_group_id = $1 ";
+if(!$selected_group){$v = array($group_id[0]);}
+if($selected_group){$v = array($selected_group);}
+$t = array('i');
+$sql_mb_user_mb_group .= " AND mb_user.mb_user_owner = $2 ";
+array_push($v,$logged_user_id);
+array_push($t,'i');
$sql_mb_user_mb_group .= " ORDER BY mb_user.mb_user_name";
-$res_mb_user_mb_group = db_query($sql_mb_user_mb_group);
+$res_mb_user_mb_group = db_prep_query($sql_mb_user_mb_group,$v,$t);
while($row = db_fetch_array($res_mb_user_mb_group)){
$user_id_group[$cnt_group_user] = $row["mb_user_id"];
$user_name_group[$cnt_group_user] = $row["mb_user_name"];
$cnt_group_user++;
/*INSERT HTML*/
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."&e_id_css=".$_REQUEST["e_id_css"]."' method='post'>";
+echo "<form name='form1' action='" . $self ."' method='post'>";
-/*insert projects in selectbox*************************************************************************************/
+/*insert projects in selectbox*********************************************************************/
echo "<div class='text1'>GROUP: </div>";
echo "<select style='background:#ffffff' class='select1' name='selected_group' onChange='submit()' size='10'>";
for($i=0; $i<$cnt_group; $i++){
@@ -154,15 +156,15 @@
echo "</select>";
-/*insert all profiles in selectbox**************************************************************************/
+/*insert all profiles in selectbox*****************************************************************/
echo "<div class='text2'>USER:</div>";
echo "<select style='background:#ffffff' class='select2' multiple='multiple' name='selected_user[]' size='$fieldHeight' >";
- for($i=0; $i<$cnt_user; $i++){
- echo "<option value='" . $user_id[$i] . "'>" . $user_name[$i] . "</option>";
+ for($i=0; $i<$cnt_user; $i++){
+ echo "<option value='" . $user_id[$i] . "'>" . $user_name[$i] . "</option>";
echo "</select>";
-/*Button****************************************************************************************************/
+/*Button*******************************************************************************************/
echo "<div class='button1'><input type='button' value='==>' onClick='validate(\"insert\")'></div>";
echo "<input type='hidden' name='insert'>";
@@ -170,7 +172,7 @@
echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
echo "<input type='hidden' name='remove'>";
-/*insert container_profile_dependence and container_group_dependence in selectbox**************************************************/
+/*insert container_profile_dependence and container_group_dependence in selectbox******************/
echo "<div class='text3'>SELECTED USER:</div>";
echo "<select style='background:#ffffff' class='select3' multiple='multiple' name='remove_user[]' size='$fieldHeight' >";
for($i=0; $i<$cnt_group_user; $i++){
More information about the Mapbender_commits
