svn commit: r294 - trunk/mapbender/http/php/database-pgsql.php
uli at osgeo.org uli at osgeo.org
Tue May 16 03:01:22 EDT 2006
Author: uli
Date: 2006-05-16 07:01:22+0000
New Revision: 294
prepared statements included
exception for db_query must be removed later
Modified: trunk/mapbender/http/php/database-pgsql.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/database-pgsql.php?view=diff&rev=294&p1=trunk/mapbender/http/php/database-pgsql.php&p2=trunk/mapbender/http/php/database-pgsql.php&r1=293&r2=294
--- trunk/mapbender/http/php/database-pgsql.php	(original)
+++ trunk/mapbender/http/php/database-pgsql.php	2006-05-16 07:01:22+0000
@@ -125,17 +125,10 @@
 	$QUERY_COUNT++;
 	$ret = pg_exec($qstring);
-	#echo "SQL: ".$qstring;
-	/*if(!$ret){
-		echo db_error();
-		$handle = fopen("../tmp/sql.txt", "a");
-		fwrite($handle, $qstring." -- ".$_SERVER["SCRIPT_NAME"]."\n");
-		fclose($handle);
+	$e = new mb_exception("not ps:  ".$_SERVER['SCRIPT_FILENAME']." : ".$qstring);
 	if(!$ret){
-			$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
+		$e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
 	return $ret;
@@ -153,19 +146,32 @@
 		$types = array($types);
 	if(count($params) != count($types)){
-		$e = new mb_exception("array params and array types have a different count! Sql: ".$qstring);
+		$e = new mb_exception("array params and array types have a different count  in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring);
-	for ($i=0; $i<count($params); $i++){
-		$needle = "$".strval($i+1);
-		$tmp = '';
-		if($types[$i] == 's'){ $tmp .= "'"; }
-		$tmp .= $params[$i];
-		$posa = strpos($qstring, $needle);
-		$posb = strlen($needle);
-		$qstring = substr($qstring,0,$posa).$tmp.substr($qstring,($posa + $posb));
+	if(PREPAREDSTATEMENTS == false){
+		for ($i=0; $i<count($params); $i++){
+			$needle = "$".strval($i+1);
+			$tmp = '';
+			if($types[$i] == 's'){ $tmp .= "'"; }
+			$tmp .= $params[$i];
+			$posa = strpos($qstring, $needle);
+			$posb = strlen($needle);
+			$qstring = substr($qstring,0,$posa).$tmp.substr($qstring,($posa + $posb));
+		$r = db_query($qstring);
-	$r = db_query($qstring);
+	else{
+		$t = md5(microtime());
+		$result = pg_prepare($t, $qstring);
+		if(!$result){
+			$e = new mb_exception("Error while preparing statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
+		$r = pg_execute($t, $params);
+		if(!$r){
+			$e = new mb_exception("Error while executing prepared statement in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$qstring.", Error: ".db_error());
 	return $r;
@@ -377,7 +383,7 @@
  * Returns the last error from the database
 function db_error() {
-	return @pg_errormessage();
+	return @pg_result_error();
More information about the Mapbender_commits mailing list
