svn commit: r298 - trunk/mapbender/http/php/mod_exportGUI.php
uli at osgeo.org uli at osgeo.org
Tue May 16 03:45:30 EDT 2006
Author: uli
Date: 2006-05-16 07:45:29+0000
New Revision: 298
db_prep_query included
verification of user permissions
Modified: trunk/mapbender/http/php/mod_exportGUI.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_exportGUI.php?view=diff&rev=298&p1=trunk/mapbender/http/php/mod_exportGUI.php&p2=trunk/mapbender/http/php/mod_exportGUI.php&r1=297&r2=298
--- trunk/mapbender/http/php/mod_exportGUI.php	(original)
+++ trunk/mapbender/http/php/mod_exportGUI.php	2006-05-16 07:45:29+0000
@@ -19,11 +19,11 @@
 session_start();
 import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
 require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
+require_once("../php/mb_validatePermission.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -69,20 +69,22 @@
 if($guiList){
 	$insert = "";
 	//gui
-	$sql_gui = "SELECT * FROM gui WHERE gui_name = '".$guiList."'";
-	$res_gui = db_query($sql_gui);
-	//echo $sql_gui."<BR>";
+	$sql_gui = "SELECT * FROM gui WHERE gui_name = $1 ";
+	$v = array($guiList);
+	$t = array('s');
+	$res_gui = db_prep_query($sql_gui,$v,$t);
-	echo "";
 	$i = 0;
 	while ($row = db_fetch_row($res_gui)){
 		$insert =  "INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ";
-		$insert.= "('".db_result($res_gui, 0, 0)."','".db_result($res_gui, 0, 1)."','".db_result($res_gui, 0, 2)."',".db_result($res_gui, 0, 3).");\n";
+		$insert.= "('".db_result($res_gui, 0, 0)."','".db_result($res_gui, 0, 1)."','".db_result($res_gui, 0, 2)."',".db_result($res_gui, 0, 3).")";
 	//gui_element
-	$sql_gel = "SELECT * from gui_element WHERE fkey_gui_id = '".$guiList."'";
-	$res_gel = db_query($sql_gel);
+	$sql_gel = "SELECT * from gui_element WHERE fkey_gui_id = $1 ";
+	$t = array('s');
+	$res_gel = db_prep_query($sql_gel,$v,$t);
 	$cnt_gel = 0;
 	while ($row = db_fetch_array($res_gel)){
@@ -113,8 +115,10 @@
-	$sql_gelvars = "SELECT * from gui_element_vars WHERE fkey_gui_id = '".$guiList."'";
-	$res_gelvars = db_query($sql_gelvars);
+	$sql_gelvars = "SELECT * from gui_element_vars WHERE fkey_gui_id = $1 ";
+	$t = array('s');
+	$res_gelvars = db_query($sql_gelvars,$v,$t);
 	$cnt_gelvars = 0;
 	while ($row = db_fetch_row($res_gelvars)){
@@ -156,17 +160,19 @@
 if(!$guiList){
+	$v = array();
+	$t = array();
 	$sql = "SELECT * FROM gui WHERE gui_id IN (";
 	for($i=0; $i<count($permguis); $i++){
 		if($i>0){ $sql .= ",";}
-		$sql .= "'".$permguis[$i]."'";
+		$sql .= "$".($i + 1);
+		array_push($v,$permguis[$i]);
+		array_push($t,'s');
 	$sql .= ") ORDER BY gui_name";
-	$res = db_query($sql);
+	$res = db_prep_query($sql,$v,$t);
 	$cnt = 0;
-	echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
+	echo "<form name='form1' action='" . $self ."' method='post'>";
 	echo "<select class='guiList' size='20' name='guiList' class='guiList' onchange='document.forms[0].submit()'>";
 	while($row = db_fetch_array($res)){
 		print_r($row);
More information about the Mapbender_commits mailing list
