svn commit: r313 - trunk/mapbender/http/php/mod_wfsLayerObj_conf.php
uli at osgeo.org uli at osgeo.org
Tue May 16 08:17:03 EDT 2006
Author: uli
Date: 2006-05-16 12:17:03+0000
New Revision: 313
db_prep_query included
Modified: trunk/mapbender/http/php/mod_wfsLayerObj_conf.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_wfsLayerObj_conf.php?view=diff&rev=313&p1=trunk/mapbender/http/php/mod_wfsLayerObj_conf.php&p2=trunk/mapbender/http/php/mod_wfsLayerObj_conf.php&r1=312&r2=313
--- trunk/mapbender/http/php/mod_wfsLayerObj_conf.php	(original)
+++ trunk/mapbender/http/php/mod_wfsLayerObj_conf.php	2006-05-16 12:17:03+0000
@@ -64,18 +64,21 @@
 <form method='POST' onsubmit='return validate()'>
 <?php
-if(isset($_REQUEST["save"])){
-        $sql = "UPDATE gui_layer SET gui_layer_wfs_featuretype = '".$_REQUEST["wfs_conf"]."' ";
-        $sql .= "WHERE fkey_gui_id='".$_REQUEST["gui"]."' AND fkey_layer_id=".$_REQUEST["layer"];
-        $res = db_query($sql);
+if(isset($_REQUEST["save"])){
+        $sql = "UPDATE gui_layer SET gui_layer_wfs_featuretype = $1 ";
+        $sql .= "WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
+        $v = array($_REQUEST["wfs_conf"],$_REQUEST["gui"],$_REQUEST["layer"]);
+		$t = array('s','s','i');
+		$res = db_prep_query($sql,$v,$t);
         echo "layer is connected with wfs_conf: ".$_REQUEST["wfs_conf"];
 else if(isset($_REQUEST["del"])){
         $sql = "UPDATE gui_layer SET gui_layer_wfs_featuretype = '' ";
+        $sql .= "WHERE fkey_gui_id = $1 AND fkey_layer_id = $2";
+        $v = array($_REQUEST["gui"],$_REQUEST["layer"]);
+		$t = array('s','i');
         echo "layer connection removed";
 echo "<input type='hidden' name='gui' value='".$_REQUEST["gui"]."'>";
@@ -100,18 +103,6 @@
 echo "<br><input type='submit' name='save' value='save'><br>";
 echo "<input name='del' type='submit' value='delete'>";
-/* save wfs_conf properties */
-/* end save wfs_conf properties */
-/* end configure elements */
 </form>
 </body>
\ No newline at end of file
More information about the Mapbender_commits mailing list
