svn commit: r325 - trunk/mapbender/http/php/mod_editElements.php
uli at osgeo.org uli at osgeo.org
Fri May 19 11:53:24 EDT 2006
Author: uli
Date: 2006-05-19 15:53:24+0000
New Revision: 325
transactions modified
db_prep_query included
permission validation included
Modified: trunk/mapbender/http/php/mod_editElements.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_editElements.php?view=diff&rev=325&p1=trunk/mapbender/http/php/mod_editElements.php&p2=trunk/mapbender/http/php/mod_editElements.php&r1=324&r2=325
--- trunk/mapbender/http/php/mod_editElements.php	(original)
+++ trunk/mapbender/http/php/mod_editElements.php	2006-05-19 15:53:24+0000
@@ -19,12 +19,13 @@
 session_start();
 import_request_variables("PG");
-include("../php/mb_validateSession.php");
 require_once("../../conf/mapbender.conf");
-require_once("../classes/class_administration.php");
 $con = db_connect($DBSERVER,$OWNER,$PW);
 db_select_db(DB,$con);
+include("../php/mb_validatePermission.php");
+require_once("../classes/class_administration.php");
+$sParams = SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
+$self = $PHP_SELF . "?".$sParams;
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -134,25 +135,19 @@
 			if($modPerm == false){
 				$modPermAlert = true;
-	if(isset($e_js_file) && preg_match("/((\w+|\/)+.php)/i", $e_js_file, $matches)){
+		if(isset($e_js_file) && preg_match("/((\w+|\/)+.php)/i", $e_js_file, $matches)){
 			$modPerm = $mod->checkModulePermission($aGuis, $matches[1], "e_js_file");
-	if(isset($e_mb_mod) && preg_match("/((\w+|\/)+.php)/i", $e_mb_mod, $matches)){
+		if(isset($e_mb_mod) && preg_match("/((\w+|\/)+.php)/i", $e_mb_mod, $matches)){
 			$modPerm = $mod->checkModulePermission($aGuis, $matches[1], "e_mb_mod");
 		if(isset($e_src) && preg_match("/((\w+|\/)+.php)/i", $e_src, $matches)){
 			$modPerm = $mod->checkModulePermission($aGuis, $matches[1], "e_src");
@@ -160,7 +155,6 @@
 		if($modPermAlert == true){
 			unset($mySave);
 			echo "<script language='JavaScript'>";
@@ -171,87 +165,78 @@
 	# end permission-check -------------------------------------------------------------
-	$sql = array();
-if ($mySave == '1'){
-	$sql_vars = "SELECT * FROM gui_element_vars WHERE fkey_e_id = '".$e_id."' AND fkey_gui_id = '".$guiList1."'";
-	$res_vars = db_query($sql_vars);
-   	if(SYS_DBTYPE=='pgsql')
-	   	#$sql[0] = "SET AUTOCOMMIT=1";
-	  else
-	 		#$sql[0] = "SET AUTOCOMMIT=0";
-	   $sql[1] = "BEGIN";
-	   $sql[2] = "DELETE FROM gui_element WHERE e_id = '".$e_id."' AND fkey_gui_id = '".$guiList1."'";
-	   if($e_left == ''){$e_left = "NULL";}
-	   if($e_top == ''){$e_top = "NULL";}
-	   if($e_width < 1){$e_width = "NULL";}
-	   if($e_height < 1){$e_height = "NULL";}
-	   if($e_z_index < 1){$e_z_index = "NULL";}
-	   $sql[3] = "INSERT INTO gui_element(fkey_gui_id,e_id,e_pos,e_public,e_comment,e_element,e_src,e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,e_content,e_closetag,e_js_file,e_mb_mod,e_target,e_requires) ";
-	   $sql[3] .= "VALUES ('".$guiList1."','".$e_id."','".$e_pos."','".$e_public."','".db_escape_string($e_comment)."','".$e_element."','".$e_src."','".db_escape_string($e_attributes)."',".$e_left.",".$e_top.",".$e_width.",".$e_height.",".$e_z_index.",'".$e_more_styles."','".db_escape_string($e_content)."','".$e_closetag."','".$e_js_file."','".$e_mb_mod."','".$e_target."','".$e_requires."')";
+	if ($mySave == '1'){
+		$sql_vars = "SELECT * FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2";
+		$v = array($e_id,$guiList1);
+		$t = array('s','s');
+		$res_vars = db_prep_query($sql_vars,$v,$t);
+		db_begin();
+		$sql = "DELETE FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2 ";
+		$res = db_prep_query($sql,$v,$t);
+		if($e_left == ''){$e_left = NULL;}
+		if($e_top == ''){$e_top = NULL;}
+		if($e_width < 1){$e_width = NULL;}
+		if($e_height < 1){$e_height = NULL;}
+		if($e_z_index < 1){$e_z_index = NULL;}
+		$sql = "INSERT INTO gui_element(fkey_gui_id,e_id,e_pos,e_public,e_comment,e_element,e_src,";
+		$sql .= "e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,e_content,";
+		$sql .= "e_closetag,e_js_file,e_mb_mod,e_target,e_requires) ";
+		$sql .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20)";
+		$v = array($guiList1,$e_id,$e_pos,$e_public,$e_comment,$e_element,$e_src,$e_attributes,$e_left,$e_top,$e_width,$e_height,$e_z_index,$e_more_styles,$e_content,$e_closetag,$e_js_file,$e_mb_mod,$e_target,$e_requires);
+		$t = array('s','s','i','i','s','s','s','s','i','i','i','i','i','s','s','s','s','s','s','s');
+		if(!$res){
+			db_rollback();
 		//copy element vars
-		$sql[4] = "INSERT INTO gui_element_vars SELECT '".$guiList1."', '".$e_id."', var_name, var_value, context, var_type FROM gui_element_vars WHERE fkey_e_id = '".$e_id."' AND fkey_gui_id = '".$_POST["originGuiOfSelectedElement"]."';";
-   # mySave == 2 <=> just save GUI description
-   elseif ($mySave == '2') {
-	  else
-	   $sql[3] = "UPDATE gui SET gui_description = '". $guiDesc."' WHERE gui_id ='".$guiId."'";
-   if(count($sql) > 0){
-	    foreach ($sql as $mysql){
-      $res = db_query($mysql);
-      if(!$res){echo db_error();break;}
-   if($res){
-		$res = db_query( "COMMIT");
-        if($SYS_DBTYPE=='mysql'){
-        	$res = db_query( "SET AUTOCOMMIT=1");
-   else{
-      $res = db_query( "ROLLBACK");
-   if(isset($sql_vars)){//sicherstellen das keine Element_Vars gelöscht wurden
-   	 while($row =  db_fetch_array($res_vars)){
-     			$securesql = "INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) VALUES ('".$guiList1."','".$e_id."','".$row["var_name"]."','".$row["var_value"]."','".$row["context"]."','".$row["var_type"]."');";
-     			//echo $securesql."<BR>";
-     			$secureinsert = db_query($securesql);
+		$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2";
+		$v = array($e_id,$_POST["originGuiOfSelectedElement"]);
+		print_r($v);
+		$c = 0;
+		while($row = db_fetch_array($res)){
+			$sql = array();
+			$v = array();
+			$t = array();
+			$r = array();
+			$sql[$c] = "INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) ";
+			$sql[$c] .= "VALUES ($1,$2,$3,$4,$5,$6)";
+			$v[$c] = array($guiList1,$e_id,$row["var_name"],$row["var_value"],$row["context"],$row["var_type"]);
+			$t[$c] = array('s','s','s','s','s','s');
+			$r[$c] = db_prep_query($sql[$c],$v[$c],$t[$c]);
+			if(!$r){
+				db_rollback();
+			$c++;
+		db_commit();
+	# mySave == 2 <=> just save GUI description
+	elseif ($mySave == '2') {
+		$sql = "UPDATE gui SET gui_description = $1 WHERE gui_id = $2";
+		$v = array($guiDesc,$guiId);
-   #echo $sql;
-      if(!$res){break;}
 if(isset($myDelete) && $myDelete == '1'){
-   $sql = "DELETE FROM gui_element WHERE e_id = '".$e_id."' AND fkey_gui_id = '".$guiList1."'";
-   $res = db_query($sql);
-   $e_id = ""; $e_pos = ""; $e_public = ""; $e_comment = ""; $e_element = "";
-   $e_src = ""; $e_attributes = ""; $e_left = ""; $e_top = ""; $e_width = ""; $e_height = ""; $e_z_index = "";
-   $e_more_styles = ""; $e_content = ""; $e_closetag = ""; $e_js_file = ""; $e_mb_mod = ""; $e_target = ""; $e_requires = "";
+	$sql = "DELETE FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+	$e_id = ""; $e_pos = ""; $e_public = ""; $e_comment = ""; $e_element = "";
+	$e_src = ""; $e_attributes = ""; $e_left = ""; $e_top = ""; $e_width = ""; $e_height = ""; $e_z_index = "";
+	$e_more_styles = ""; $e_content = ""; $e_closetag = ""; $e_js_file = ""; $e_mb_mod = ""; $e_target = ""; $e_requires = "";
 if(isset($myShow) && $myShow == '1'){
    $_SESSION["mb_user_myGui"] = $guiList1;
@@ -260,52 +245,60 @@
    echo "</script>";
 if(isset($all) && $all == '1'){
-   $sql = "SELECT * FROM gui_element WHERE fkey_gui_id = '".$guiList2."'";
-   $cnt = 0;
-   while($row = db_fetch_array($res)){
-      $sql_del = "DELETE FROM gui_element WHERE fkey_gui_id = '".$guiList1."' AND e_id = '".$row["e_id"]."'";
-      $res_del = db_query($sql_del);
-      if($row["e_left"] == ""){$myleft = 'NULL';} else{$myleft = $row["e_left"];}
-      if($row["e_top"] == ""){$mytop = 'NULL';} else{$mytop = $row["e_top"];}
-      if($row["e_width"] == ""){$mywidth = 'NULL';} else{$mywidth = $row["e_width"];}
-      if($row["e_height"] == ""){$myheight = 'NULL';} else{$myheight = $row["e_height"];}
-      if($row["e_z_index"] == ""){$my_z_index = 'NULL';} else{$my_z_index = $row["e_z_index"];}
-      $sql_ins = "INSERT INTO gui_element(fkey_gui_id,e_id,e_pos,e_public,e_comment,e_element,e_src,e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,e_content,e_closetag,e_js_file,e_mb_mod,e_target,e_requires) ";
-      $sql_ins .= "VALUES ('".$guiList1."','".$row["e_id"]."','".$row["e_pos"]."','".$row["e_public"]."','".db_escape_string($row["e_comment"])."','".$row["e_element"]."','".$row["e_src"]."','".db_escape_string($row["e_attributes"])."',".$myleft.",";
-      $sql_ins .= $mytop.",".$mywidth.",".$myheight.",".$my_z_index.",'".$row["e_more_styles"]."','".db_escape_string($row["e_content"])."','".$row["e_closetag"]."','".$row["e_js_file"]."','".$row["e_mb_mod"]."','".$row["e_target"]."','".$row["e_requires"]."')";
-      $res_ins = db_query($sql_ins);
-      if(!$res_ins){echo db_error($con); }
-      $cnt++;
-   $sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = '".$guiList2."'";
-   	$cnt = 0;
-      $sql_ins2 = "INSERT INTO gui_element_vars(fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) ";
-      $sql_ins2 .= "VALUES ('".$guiList1."','".$row["fkey_e_id"]."','".$row["var_name"]."','".db_escape_string($row["var_value"])."','".db_escape_string($row["context"])."','".$row["var_type"]."')";
-      $res_ins2 = db_query($sql_ins2);
-      if(!$res_ins2){echo db_error($connect); }
-      $cnt++;
+	$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1";
+	$v = array($guiList2);
+	$t = array('s');
+	$cnt = 0;
+	db_begin();
+		$sql_del = "DELETE FROM gui_element WHERE fkey_gui_id = $1 AND e_id = $2";
+		$v = array($guiList1,$row["e_id"]);
+		$res_del = db_prep_query($sql_del,$v,$t);
+		if($row["e_left"] == ""){$myleft = NULL;} else{$myleft = $row["e_left"];}
+		if($row["e_top"] == ""){$mytop = NULL;} else{$mytop = $row["e_top"];}
+		if($row["e_width"] == ""){$mywidth = NULL;} else{$mywidth = $row["e_width"];}
+		if($row["e_height"] == ""){$myheight = NULL;} else{$myheight = $row["e_height"];}
+		if($row["e_z_index"] == ""){$my_z_index = NULL;} else{$my_z_index = $row["e_z_index"];}
+		$sql_ins = "INSERT INTO gui_element(fkey_gui_id,e_id,e_pos,e_public,e_comment,e_element,e_src,e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,e_content,e_closetag,e_js_file,e_mb_mod,e_target,e_requires) ";
+		$sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20)";
+		$v = array($guiList1,$row["e_id"],$row["e_pos"],$row["e_public"],$row["e_comment"],$row["e_element"],$row["e_src"],$row["e_attributes"],$myleft,$mytop,$mywidth,$myheight,$my_z_index,$row["e_more_styles"],$row["e_content"],$row["e_closetag"],$row["e_js_file"],$row["e_mb_mod"],$row["e_target"],$row["e_requires"]);
+		$res_ins = db_prep_query($sql_ins,$v,$t);
+		if(!$res_ins){db_rollback(); }
+		$cnt++;
+	$sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1";
+	$t = array('s');
+	$cnt = 0;
+		$sql_ins2 = "INSERT INTO gui_element_vars(fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) ";
+		$sql_ins2 .= "VALUES ($1,$2,$3,$4,$5,$6)";
+		$v = array($guiList1,$row["fkey_e_id"],$row["var_name"],$row["var_value"],$row["context"],$row["var_type"]);
+		$t = array('s','s','s','s','s','s');
+		$res_ins2 = db_prep_query($sql_ins2,$v,$t);
+		if(!$res_ins2){db_rollback(); }
+		$cnt++;
+	db_commit();
 # end
 echo "<script language='javascript'>";
 echo "var guiIDs = new Array();";
 if(isset($guiList1)){
-   $sql = "SELECT e_id FROM gui_element WHERE  fkey_gui_id = '".$guiList1."'";
-   $cnt = 0;
-      echo  "guiIDs[".$cnt."] = '".$row["e_id"]."'; ";
-      $cnt++;
+	$sql = "SELECT e_id FROM gui_element WHERE  fkey_gui_id = $1";
+	$v = array($guiList1);
+	$t = array('s');
+	$cnt = 0;
+		echo  "guiIDs[".$cnt."] = '".$row["e_id"]."'; ";
+		$cnt++;
 echo "</script>";
@@ -390,15 +383,21 @@
 $admin = new administration();
 $ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"]);
 $permguis = $admin->getGuisByPermission($_SESSION["mb_user_id"]);
-echo "<form name='form1' action='" . $_SERVER['PHP_SELF'] . "?".SID."' method='post'>\n";
+echo "<form name='form1' action='" . $self ."' method='post'>\n";
 if(count($ownguis)>0){
+	$v = array();
+	$t = array();
+	$c = 1;
 	$sql = "SELECT * from gui WHERE gui.gui_id IN(";
 	for($i=0; $i<count($ownguis); $i++){
 		if($i>0){ $sql .= ",";}
-		$sql .= "'".$ownguis[$i]."'";
+		$sql .= "$".$c;
+		array_push($v,$ownguis[$i]);
+		array_push($t,'s');
+		$c++;
 	$sql .= ") order by gui_id;";
 	$count=0;
 		$gui_id_own[$count]=$row["gui_id"];
@@ -407,14 +406,19 @@
 		$count++;
+	$v = array();
+	$t = array();
+	$c = 1;
 	for($i=0; $i<count($permguis); $i++){
-		$sql .= "'".$permguis[$i]."'";
+		$sql .= "$".$c;
+		array_push($v,$permguis[$i]);
+		$c++;
 	$count=0;
 		$gui_id_perm[$count]= $row["gui_id"];
@@ -493,8 +497,10 @@
 			echo "<div class='guiList2_header'>Templates</div>\n";
 			$isTemplate = true;
-		$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = '".$guiList2."' ORDER BY e_id";
+		$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 ORDER BY e_id";
+		$t = array('s');
 		$cnt = 0;
 		echo "<div class='myElements'>\n<table ";
@@ -516,7 +522,7 @@
 			//echo "</td>\n<td class='myTable'>". $row["e_id"]. "</td><td class='myTable'>" .$row["e_comment"]."</td>";
 			echo "</td>\n";
 			echo "<td class='myTable'>";
-	 		echo "<a href=\"mod_editElementVars.php?".SID."&fkey_gui_id=".$guiList2."&fkey_e_id=".$row["e_id"]."\">";
+	 		echo "<a href=\"mod_editElementVars.php?".$sParams."&fkey_gui_id=".$guiList2."&fkey_e_id=".$row["e_id"]."\">";
 	 		echo $row["e_id"];
 			echo "</a>\n</td>\n";
 			echo "<td class='myTable'>".$row["e_comment"]."</td>";
@@ -528,63 +534,66 @@
 	#Formular:
 	echo "<table class='myForm'>\n";
 		//echo "<tr><td>" . $_POST["originGuiOfSelectedElement"] . "</td></tr>";
-	if(isset($myElement)){
+if(isset($myElement)){
-	   $sql = "SELECT * FROM gui_element WHERE fkey_gui_id = '".$guiList2."' AND e_id = '".$myElement."'";
-	   if($row = db_fetch_array($res)){
-	      echo "<tr><td>ID: </td><td><input type='text' class='textfield' name='e_id' value='".$row["e_id"]."'></td></tr>\n";
-	      echo "<tr><td>Position: </td><td><input type='text' class='textfield' name='e_pos' value='".$row["e_pos"]."'></td></tr>\n";
-	      echo "<tr><td>ON/OFF: </td><td><input type='text' class='textfield' name='e_public' value='".$row["e_public"]."'></td></tr>\n";
-	      echo "<tr><td>Comment: </td><td><textarea cols='32' rows='5'  name='e_comment' >".stripslashes($row["e_comment"])."</textarea></td></tr>\n";
-	      echo "<tr><td>HTML-TAG: </td><td><input type='text' class='textfield' name='e_element' value='".$row["e_element"]."'></td></tr>\n";
-	      echo "<tr><td>SRC: </td><td><input type='text' class='textfield' name='e_src' value='".$row["e_src"]."'></td></tr>\n";
-	      echo "<tr><td>Attributes: </td><td><textarea cols='32' rows='5'  name='e_attributes' >".stripslashes($row["e_attributes"])."</textarea></td></tr>\n";
-	      echo "<tr><td>Left: </td><td><input type='text' class='textfield' name='e_left' value='".$row["e_left"]."'></td></tr>\n";
-	      echo "<tr><td>Top: </td><td><input type='text' class='textfield' name='e_top' value='".$row["e_top"]."'></td></tr>\n";
-	      echo "<tr><td>Width: </td><td><input type='text' class='textfield' name='e_width' value='".$row["e_width"]."'></td></tr>\n";
-	      echo "<tr><td>Height: </td><td><input type='text' class='textfield' name='e_height' value='".$row["e_height"]."'></td></tr>\n";
-	      echo "<tr><td>Z-INDEX: </td><td><input type='text' class='textfield' name='e_z_index' value='".$row["e_z_index"]."'></td></tr>\n";
-	      echo "<tr><td>Styles: </td><td><input type='text' class='textfield' name='e_more_styles' value='".$row["e_more_styles"]."'></td></tr>\n";
-	      echo "<tr><td>Content: </td><td><textarea cols='32' rows='4'  name='e_content' >".stripslashes($row["e_content"])."</textarea></td></tr>\n";
-	      echo "<tr><td>Close-TAG: </td><td><input type='text' class='textfield' name='e_closetag' value='".$row["e_closetag"]."'></td></tr>\n";
-	      echo "<tr><td>JavaScript: </td><td><input type='text' class='textfield' name='e_js_file' value='".$row["e_js_file"]."'></td></tr>\n";
-	      echo "<tr><td>Modul: </td><td><input type='text' class='textfield' name='e_mb_mod' value='".$row["e_mb_mod"]."'></td></tr>\n";
-	      echo "<tr><td>Target: </td><td><input type='text' class='textfield' name='e_target' value='".$row["e_target"]."'></td></tr>\n";
-	      echo "<tr><td>Requires: </td><td><input type='text' class='textfield' name='e_requires' value='".$row["e_requires"]."'></td></tr>\n";
-	   echo "</table>";
-	else if(isset($guiList1)){
-	      echo "<tr><td>ID: </td><td><input type='text' class='textfield' name='e_id' value='".$e_id."'></td></tr>\n";
-	      echo "<tr><td>Position: </td><td><input type='text' class='textfield' name='e_pos' value='".$e_pos."'></td></tr>\n";
-	      echo "<tr><td>ON/OFF: </td><td><input type='text' class='textfield' name='e_public' value='".$e_public."'></td></tr>\n";
-	      echo "<tr><td>Comment: </td><td><textarea cols='32' rows='5'  name='e_comment' >".stripslashes($e_comment)."</textarea></td></tr>\n";
-	      echo "<tr><td>HTML-TAG: </td><td><input type='text' class='textfield' name='e_element' value='".$e_element."'></td></tr>\n";
-	      echo "<tr><td>SRC: </td><td><input type='text' class='textfield' name='e_src' value='".$e_src."'></td></tr>\n";
-	      echo "<tr><td>Attributes: </td><td><textarea cols='32' rows='5'  name='e_attributes' >".stripslashes($e_attributes)."</textarea></td></tr>\n";
-	      echo "<tr><td>Left: </td><td><input type='text' class='textfield' name='e_left' value='".$e_left."'></td></tr>\n";
-	      echo "<tr><td>Top: </td><td><input type='text' class='textfield' name='e_top' value='".$e_top."'></td></tr>\n";
-	      echo "<tr><td>Width: </td><td><input type='text' class='textfield' name='e_width' value='".$e_width."'></td></tr>\n";
-	      echo "<tr><td>Height: </td><td><input type='text' class='textfield' name='e_height' value='".$e_height."'></td></tr>\n";
-	      echo "<tr><td>Z-INDEX: </td><td><input type='text' class='textfield' name='e_z_index' value='".$e_z_index."'></td></tr>\n";
-	      echo "<tr><td>Styles: </td><td><input type='text' class='textfield' name='e_more_styles' value='".$e_more_styles."'></td></tr>\n";
-	      echo "<tr><td>Content: </td><td><textarea cols='32' rows='4'  name='e_content' >".stripslashes($e_content)."</textarea></td></tr>\n";
-	      echo "<tr><td>Close-TAG: </td><td><input type='text' class='textfield' name='e_closetag' value='".$e_closetag."'></td></tr>\n";
-	      echo "<tr><td>JavaScript: </td><td><input type='text' class='textfield' name='e_js_file' value='".$e_js_file."'></td></tr>\n";
-	      echo "<tr><td>Module: </td><td><input type='text' class='textfield' name='e_mb_mod' value='".$e_mb_mod."'></td></tr>\n";
-	      echo "<tr><td>Target: </td><td><input type='text' class='textfield' name='e_target' value='".$e_target."'></td></tr>\n";
-	      echo "<tr><td>Requires: </td><td><input type='text' class='textfield' name='e_requires' value='".$e_requires."'></td></tr>\n";
-	echo "</table>\n";
-	echo "<input type='hidden' name='originGuiOfSelectedElement' value='" . $_POST["originGuiOfSelectedElement"] . "'>";
-	echo "<input type='hidden' name='myDelete'>";
-	echo "<input type='hidden' name='mySave'>";
-	echo "<input type='hidden' name='myShow'>";
-	echo "<input type='hidden' name='all'>";
-	echo "</form>";
-}else{
+	$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = '".$guiList2."' AND e_id = '".$myElement."'";
+	$v = array();
+	$t = array();
+	if($row = db_fetch_array($res)){
+		echo "<tr><td>ID: </td><td><input type='text' class='textfield' name='e_id' value='".$row["e_id"]."'></td></tr>\n";
+		echo "<tr><td>Position: </td><td><input type='text' class='textfield' name='e_pos' value='".$row["e_pos"]."'></td></tr>\n";
+		echo "<tr><td>ON/OFF: </td><td><input type='text' class='textfield' name='e_public' value='".$row["e_public"]."'></td></tr>\n";
+		echo "<tr><td>Comment: </td><td><textarea cols='32' rows='5'  name='e_comment' >".stripslashes($row["e_comment"])."</textarea></td></tr>\n";
+		echo "<tr><td>HTML-TAG: </td><td><input type='text' class='textfield' name='e_element' value='".$row["e_element"]."'></td></tr>\n";
+		echo "<tr><td>SRC: </td><td><input type='text' class='textfield' name='e_src' value='".$row["e_src"]."'></td></tr>\n";
+		echo "<tr><td>Attributes: </td><td><textarea cols='32' rows='5'  name='e_attributes' >".stripslashes($row["e_attributes"])."</textarea></td></tr>\n";
+		echo "<tr><td>Left: </td><td><input type='text' class='textfield' name='e_left' value='".$row["e_left"]."'></td></tr>\n";
+		echo "<tr><td>Top: </td><td><input type='text' class='textfield' name='e_top' value='".$row["e_top"]."'></td></tr>\n";
+		echo "<tr><td>Width: </td><td><input type='text' class='textfield' name='e_width' value='".$row["e_width"]."'></td></tr>\n";
+		echo "<tr><td>Height: </td><td><input type='text' class='textfield' name='e_height' value='".$row["e_height"]."'></td></tr>\n";
+		echo "<tr><td>Z-INDEX: </td><td><input type='text' class='textfield' name='e_z_index' value='".$row["e_z_index"]."'></td></tr>\n";
+		echo "<tr><td>Styles: </td><td><input type='text' class='textfield' name='e_more_styles' value='".$row["e_more_styles"]."'></td></tr>\n";
+		echo "<tr><td>Content: </td><td><textarea cols='32' rows='4'  name='e_content' >".stripslashes($row["e_content"])."</textarea></td></tr>\n";
+		echo "<tr><td>Close-TAG: </td><td><input type='text' class='textfield' name='e_closetag' value='".$row["e_closetag"]."'></td></tr>\n";
+		echo "<tr><td>JavaScript: </td><td><input type='text' class='textfield' name='e_js_file' value='".$row["e_js_file"]."'></td></tr>\n";
+		echo "<tr><td>Modul: </td><td><input type='text' class='textfield' name='e_mb_mod' value='".$row["e_mb_mod"]."'></td></tr>\n";
+		echo "<tr><td>Target: </td><td><input type='text' class='textfield' name='e_target' value='".$row["e_target"]."'></td></tr>\n";
+		echo "<tr><td>Requires: </td><td><input type='text' class='textfield' name='e_requires' value='".$row["e_requires"]."'></td></tr>\n";
+	echo "</table>";
+else if(isset($guiList1)){
+	echo "<tr><td>ID: </td><td><input type='text' class='textfield' name='e_id' value='".$e_id."'></td></tr>\n";
+	echo "<tr><td>Position: </td><td><input type='text' class='textfield' name='e_pos' value='".$e_pos."'></td></tr>\n";
+	echo "<tr><td>ON/OFF: </td><td><input type='text' class='textfield' name='e_public' value='".$e_public."'></td></tr>\n";
+	echo "<tr><td>Comment: </td><td><textarea cols='32' rows='5'  name='e_comment' >".stripslashes($e_comment)."</textarea></td></tr>\n";
+	echo "<tr><td>HTML-TAG: </td><td><input type='text' class='textfield' name='e_element' value='".$e_element."'></td></tr>\n";
+	echo "<tr><td>SRC: </td><td><input type='text' class='textfield' name='e_src' value='".$e_src."'></td></tr>\n";
+	echo "<tr><td>Attributes: </td><td><textarea cols='32' rows='5'  name='e_attributes' >".stripslashes($e_attributes)."</textarea></td></tr>\n";
+	echo "<tr><td>Left: </td><td><input type='text' class='textfield' name='e_left' value='".$e_left."'></td></tr>\n";
+	echo "<tr><td>Top: </td><td><input type='text' class='textfield' name='e_top' value='".$e_top."'></td></tr>\n";
+	echo "<tr><td>Width: </td><td><input type='text' class='textfield' name='e_width' value='".$e_width."'></td></tr>\n";
+	echo "<tr><td>Height: </td><td><input type='text' class='textfield' name='e_height' value='".$e_height."'></td></tr>\n";
+	echo "<tr><td>Z-INDEX: </td><td><input type='text' class='textfield' name='e_z_index' value='".$e_z_index."'></td></tr>\n";
+	echo "<tr><td>Styles: </td><td><input type='text' class='textfield' name='e_more_styles' value='".$e_more_styles."'></td></tr>\n";
+	echo "<tr><td>Content: </td><td><textarea cols='32' rows='4'  name='e_content' >".stripslashes($e_content)."</textarea></td></tr>\n";
+	echo "<tr><td>Close-TAG: </td><td><input type='text' class='textfield' name='e_closetag' value='".$e_closetag."'></td></tr>\n";
+	echo "<tr><td>JavaScript: </td><td><input type='text' class='textfield' name='e_js_file' value='".$e_js_file."'></td></tr>\n";
+	echo "<tr><td>Module: </td><td><input type='text' class='textfield' name='e_mb_mod' value='".$e_mb_mod."'></td></tr>\n";
+	echo "<tr><td>Target: </td><td><input type='text' class='textfield' name='e_target' value='".$e_target."'></td></tr>\n";
+	echo "<tr><td>Requires: </td><td><input type='text' class='textfield' name='e_requires' value='".$e_requires."'></td></tr>\n";
+echo "</table>\n";
+echo "<input type='hidden' name='originGuiOfSelectedElement' value='" . $_POST["originGuiOfSelectedElement"] . "'>";
+echo "<input type='hidden' name='myDelete'>";
+echo "<input type='hidden' name='mySave'>";
+echo "<input type='hidden' name='myShow'>";
+echo "<input type='hidden' name='all'>";
+echo "</form>";
+else{
 	echo "There are no guis available for this user. Please create a gui first.";
More information about the Mapbender_commits mailing list
