svn commit: r339 - trunk/mapbender/http/php/mod_deleteWMS.php
uli at osgeo.org uli at osgeo.org
Wed May 24 07:44:09 EDT 2006
Author: uli
Date: 2006-05-24 11:44:08+0000
New Revision: 339
validation of permissions
prepared statements included
Modified: trunk/mapbender/http/php/mod_deleteWMS.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_deleteWMS.php?view=diff&rev=339&p1=trunk/mapbender/http/php/mod_deleteWMS.php&p2=trunk/mapbender/http/php/mod_deleteWMS.php&r1=338&r2=339
--- trunk/mapbender/http/php/mod_deleteWMS.php	(original)
+++ trunk/mapbender/http/php/mod_deleteWMS.php	2006-05-24 11:44:08+0000
@@ -19,11 +19,11 @@
 session_start();
 import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
 require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
+require_once("../php/mb_validatePermission.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -137,7 +137,7 @@
 	else
 		$text = $_POST["comment"];
-	echo "<form name='form3' action='" . $PHP_SELF . "?".SID."' method='post'>";
+	echo "<form name='form3' action='" . $self ."' method='post'>";
 	echo "<table><tr>";
 	echo "<td>Your name:</td>";
 	echo "<td><input type='text' name='from' size=50 value = '".$fromName."'></td>";
@@ -154,41 +154,49 @@
 	echo "</form>";
-else {
+else {
 	// delete WMS
-	if($del)
-	   $sql = "select * from gui_wms where fkey_wms_id = ".$wmsList;
-		 $res = db_query($sql);
-		 $cnt = 0;
+	if($del){
+		$sql = "select * from gui_wms where fkey_wms_id = $1 ";
+		$v = array($wmsList);
+		$t = array('i');
+		$res = db_prep_query($sql,$v,$t);
+		$cnt = 0;
 	 	 while($row = db_fetch_array($res))
 	  	 		 $sql = "UPDATE gui_wms set gui_wms_position = (gui_wms_position -1) ";
-	  			 $sql .= "WHERE fkey_gui_id = '".$row["fkey_gui_id"]."'";
-	  			 $sql .= " AND gui_wms_position > " . $row["gui_wms_position"] ;
+	  			 $sql .= "WHERE fkey_gui_id = $1 ";
+	  			 $sql .= " AND gui_wms_position > $2 ";
+	  			 $v = array($row["fkey_gui_id"],$row["gui_wms_position"]);
+	  			 $t = array('s','i');
+	  			 $res1 = db_prep_query($sql,$v,$t);
 	    		 $cnt++;
-	   $sql = "DELETE FROM wms WHERE wms_id = '".$wmsList."'";
+	   $sql = "DELETE FROM wms WHERE wms_id = $1";
+	   $t = array('i');
 	// display WMS List
 	$wms_id_own = $admin->getWmsByOwner($_SESSION["mb_user_id"]);
 	if (count($wms_id_own)>0){
+		$v = array();
+		$t = array();
 		$sql = "Select * from wms WHERE wms_id IN (";
 		for($i=0; $i<count($wms_id_own); $i++){
 		 if($i>0){ $sql .= ",";}
-		 $sql .= $wms_id_own[$i];
+		 $sql .= "$".($i+1);
+		 array_push($v,$wms_id_own[$i]);
+		 array_push($t,'i');
 		$sql .= ") ORDER BY wms_title";
 		$cnt = 0;
-		echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
+		echo "<form name='form1' action='" . $self ."' method='post'>";
 		echo "<select class='wmsList' size='20' name='wmsList' onchange='document.form1.wmsList.value = this.value;submit()'>";
@@ -215,8 +223,10 @@
 			echo "<p class = 'guiList'>";
 			// Show GUIs using chosen WMS
-			$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = '".$wmsList."'";
+			$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1";
+			$t = array('i');
 			echo "<b>Used in the following GUIs:</b><br><br>";
@@ -231,8 +241,10 @@
 			// Show GetCapabilities of chosen WMS
-			$sql = "SELECT wms_getcapabilities FROM wms WHERE wms_id = '".$wmsList."'";
+			$sql = "SELECT wms_getcapabilities FROM wms WHERE wms_id = $1";
+			$t = array('i');
 			echo "<br><br><b>GetCapabilities</b><br><br>";
@@ -244,8 +256,10 @@
 			// Show Abstract of Chosen WMS
-			$sql = "SELECT wms_abstract FROM wms WHERE wms_id = '".$wmsList."'";
+			$sql = "SELECT wms_abstract FROM wms WHERE wms_id = $1";
+			$t = array('i');
 			echo "<br><br><b>Abstract</b><br><br>";
@@ -317,7 +331,7 @@
 <input type='hidden' name='del'>
 </form>
 <?php
-echo "<form name='form2' action='" . $PHP_SELF . "?".SID."' method='post'>";
+echo "<form name='form2' action='" . $self ."' method='post'>";
 <input type='hidden' name='suggest' value='0'>
 <input type='hidden' name='wms_name' value=''>
More information about the Mapbender_commits mailing list
