svn commit: r353 - trunk/mapbender/http/javascripts/map.php
christoph at osgeo.org christoph at osgeo.org
Mon May 29 06:42:18 EDT 2006
Author: christoph
Date: 2006-05-29 10:42:18+0000
New Revision: 353
Added:
bugfix in mb_regButton_frame
Added: trunk/mapbender/http/javascripts/map.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/map.php?view=auto&rev=353
--- (empty file)
+++ trunk/mapbender/http/javascripts/map.php	2006-05-29 10:42:18+0000
@@ -0,0 +1,1385 @@
+<?php
+# $Id: map.php 169 2006-05-03 14:28:01Z uli $
+# http://www.mapbender.org/index.php/Map.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+ob_start();
+include('../../conf/mapbender.conf');
+session_start();
+header('Content-type: application/x-javascript');
+/*GLOBALS*/
+var ie = document.all?1:0;
+var n6 = document.getElementById&&!document.all?1:0;
+var n4 = document.layers?1:0;
+var mb_feature_count = 100;
+var mb_resolution = 28.35;
+var mb_mapObj = new Array();
+var mb_fiWin = null;
+var mb_panActive = false;
+var clickX;
+var clickY;
+var mb_start_x = 0;
+var mb_start_y = 0;
+var mb_end_x = 0;
+var mb_end_y = 0;
+var mb_offset_top = 0;
+var mb_offset_right = 0;
+var mb_offset_bottom = 0;
+var mb_offset_left = 0;
+var mb_log = null;
+var mb_MapRequestSubFunctions = new Array();
+var mb_MapRequestPreFunctions = new Array();
+var mb_FeatureInfoPreFunctions = new Array();
+var mb_PanSubElements = new Array();
+var mb_InitFunctions = new Array();
+var mb_MapObjectSubFunctions = new Array();
+var mb_GetScalePreFunctions = new Array();
+var mb_vendorSpecific = new Array();
+var mb_loadWmsSubFunctions = new Array();
+var mb_security_proxy = "http://wms1.ccgis.de/mapbender/tools/security_proxy.php?mb_ows_security_proxy=";
+<?php
+echo "var mb_nr = '".session_id()."';";
+echo "var mb_myLogin = '".$_SESSION["mb_login"]."';";
+echo "var mb_styleID = '".md5($_SESSION["mb_user_name"])."';";
+echo "var mb_myBBOX = '".$_SESSION["mb_myBBOX"]."';";
+echo "var owsproxy = '".OWSPROXY."';";
+var mb_trans = new Image;
+mb_trans.src = "../img/transparent.gif";
+/*END OF GLOBALS*/
+function init(){
+	for(var i=0; i<mb_InitFunctions.length; i++){
+		eval(mb_InitFunctions[i]);
+	for(var i=0; i<mb_mapObj.length; i++){
+		setMapRequest(mb_mapObj[i].frameName);
+/*registerFunctions*/
+function mb_registerInitFunctions(stringFunction){
+	mb_InitFunctions[mb_InitFunctions.length] = stringFunction;
+function mb_registerPanSubElement(elName){
+	var ind = mb_PanSubElements.length;
+	mb_PanSubElements[ind] = elName;
+function mb_registerPreFunctions(stringFunction){
+	mb_MapRequestPreFunctions[mb_MapRequestPreFunctions.length] = stringFunction;
+function mb_registerFeatureInfoPreFunctions(stringFunction){
+	mb_FeatureInfoPreFunctions[mb_FeatureInfoPreFunctions.length] = stringFunction;
+function mb_registerSubFunctions(stringFunction){
+	mb_MapRequestSubFunctions[mb_MapRequestSubFunctions.length] = stringFunction;
+function mb_registerMapObj(frameName, elementName,wms_index,width, height){
+	mb_mapObj[mb_mapObj.length] = new mb_mapObj_const(frameName, elementName, width, height, wms_index);
+function  mb_registerMapObjectSubFunctions(stringFunction){
+	mb_MapObjectSubFunctions[mb_MapObjectSubFunctions.length] = stringFunction;
+function  mb_registerGetScalePreFunctions(stringFunction){
+   mb_GetScalePreFunctions[mb_GetScalePreFunctions.length] = stringFunction;
+function mb_registerVendorSpecific(stringFunction){
+   mb_vendorSpecific[mb_vendorSpecific.length] = stringFunction;
+function mb_registerloadWmsSubFunctions(stringFunction){
+	mb_loadWmsSubFunctions[mb_loadWmsSubFunctions.length] = stringFunction;
+function mb_removeFunctionFromArray(arrayname,stringFunction){
+	var length = eval(arrayname+".length");
+	for(var i=0; i<length; i++){
+		if(eval(arrayname+"["+i+"]") == stringFunction){
+			var newArray1 = eval(arrayname+".slice(0, "+(i-1)+")");
+			var newArray2 = eval(arrayname+".slice("+(i+1)+", "+length+")");
+			eval(arrayname + " = newArray1.concat(newArray2)");
+			i--;
+			length--;
+function deleteWmsObject() {
+	wms = new Array();
+	wms_layer_count = 0;
+function mb_mapObj_const(frameName, elementName, width, height, wms_index){
+   this.width = width;
+   this.height = height;
+   this.frameName = frameName;
+   this.elementName = elementName;
+   this.layers = new Array();
+   this.styles = new Array();
+   this.querylayers = new Array();
+   this.geom = "";
+   this.gml = "";
+   if(wms_index != null){
+      this.wms = new Array();
+      this.wms[0] = wms[wms_index];
+      this.wms[0].mapURL = false;
+      var cnt_layers = 0;
+      var cnt_querylayers = 0;
+      var styles = "";
+      var layers = "";
+      var querylayers = "";
+      for(var ii=0; ii<this.wms[0].objLayer.length; ii++){
+         if(this.wms[0].objLayer[ii].gui_layer_visible == 1 && ii>0){
+            if(cnt_layers > 0){layers += ","; styles += ","; }
+            layers += this.wms[0].objLayer[ii].layer_name;
+            styles += "";
+            cnt_layers++;
+         if(this.wms[0].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
+            if(cnt_querylayers > 0){querylayers += ",";}
+            querylayers += this.wms[0].objLayer[ii].layer_name;
+            cnt_querylayers++;
+      this.layers[0] = layers;
+      this.styles[0] = styles;
+      this.querylayers[0] = querylayers;
+   else{
+	for(i=0; i<wms.length; i++){
+		this.wms[i] = wms[i];
+		this.wms[i].mapURL = false;
+      for(var i=0; i< this.wms.length; i++){
+         var styles = "";
+         var layers = "";
+         for(var ii=0; ii<this.wms[i].objLayer.length; ii++){
+            if(this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
+               layers += wms[i].objLayer[ii].layer_name;
+               styles += "";
+               cnt_layers++;
+            if(this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
+               querylayers += wms[i].objLayer[ii].layer_name;
+         this.layers[i] = layers;
+         this.styles[i] = styles;
+         this.querylayers[i] = querylayers;
+   this.epsg = wms[0].gui_wms_epsg;
+   this.extent = setExtent(this.width,this.height,this.epsg);
+   this.mapURL = new Array();
+   for(var i=0; i<mb_MapObjectSubFunctions.length; i++){
+      eval(mb_MapObjectSubFunctions[i]);
+function mb_moveWmsById (mapObj_ind, wms_id, toIndex) {
+	return mb_wmsMoveByIndex(mapObj_ind, getWMSIndexById(mapObj_ind, wms_id), toIndex);
+function mb_wmsMoveByIndex(mapObj_ind, fromIndex, toIndex) {
+	if (fromIndex != toIndex && fromIndex >= 0 && fromIndex < mb_mapObj[mapObj_ind].wms.length && toIndex >= 0 && toIndex < mb_mapObj[mapObj_ind].wms.length) {
+		var changed = false;
+		if (fromIndex > toIndex) {
+			for (var i = fromIndex; i > toIndex ; i--) {
+				var result = mb_swapWmsByIndex(mapObj_ind, i-1, i);
+				if (result == true) changed = true;
+		else {
+			for (var i = fromIndex; i < toIndex ; i++) {
+				var result = mb_swapWmsByIndex(mapObj_ind, i, i+1);
+		return changed;
+	else {
+		return false;
+function mb_swapWmsById(mapObj_ind, wms1_id, wms2_id) {
+	return mb_swapWmsByIndex(mapObj_ind, getWMSIndexById(mapObj_ind, wms1_id), getWMSIndexById(mapObj_ind, wms2_id));
+function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
+	if (indexA != indexB && indexA >= 0 && indexA < mb_mapObj[mapObj_ind].wms.length && indexB >= 0 && indexB < mb_mapObj[mapObj_ind].wms.length) {
+		var upper = new Object();
+		upper = mb_mapObj[mapObj_ind].wms[indexA];
+		mb_mapObj[mapObj_ind].wms[indexA] = mb_mapObj[mapObj_ind].wms[indexB];
+		mb_mapObj[mapObj_ind].wms[indexB] = upper;
+		var upperLayers = mb_mapObj[mapObj_ind].layers[indexA];
+		var upperStyles = mb_mapObj[mapObj_ind].styles[indexA];
+		var upperQuerylayers = mb_mapObj[mapObj_ind].querylayers[indexA];
+		mb_mapObj[mapObj_ind].layers[indexA] = mb_mapObj[mapObj_ind].layers[indexB];
+		mb_mapObj[mapObj_ind].styles[indexA] = mb_mapObj[mapObj_ind].styles[indexB];
+		mb_mapObj[mapObj_ind].querylayers[indexA] = mb_mapObj[mapObj_ind].querylayers[indexB];
+		mb_mapObj[mapObj_ind].layers[indexB] = upperLayers;
+		mb_mapObj[mapObj_ind].styles[indexB] = upperStyles;
+		mb_mapObj[mapObj_ind].querylayers[indexB] = upperQuerylayers;
+		return true;
+	else {
+		return false;
+function mb_moveUpWmsByIndex(mapObj_ind, index) {
+	if (index > 0 && index < wms.length) {
+		return mb_swapWmsByIndex(mapObj_ind, index-1, index);
+	else {
+		return false;
+function mb_moveDownWmsByIndex(mapObj_ind, index) {
+	if (index >= 0 && index < wms.length-1) {
+		return mb_swapWmsByIndex(mapObj_ind, index, index+1);
+	else {
+		return false;
+function mb_mapObjaddWMS(obj){
+	var styles = "";
+	var layers = "";
+	var ind = getMapObjIndexByName(obj);
+	//is the id valid?
+	for( var i=0; i<(wms.length-1); i++){
+		if(parseInt(wms[i].wms_id) >= parseInt(wms[wms.length-1].wms_id)){
+			wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id) + 1;
+	mb_mapObj[ind].wms[mb_mapObj[ind].wms.length] = wms[wms.length-1];
+	mb_mapObj[ind].layers[mb_mapObj[ind].layers.length] = layers;
+	mb_mapObj[ind].styles[mb_mapObj[ind].styles.length] = styles;
+	mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length] = querylayers;
+	for(var i=0; i<mb_loadWmsSubFunctions.length; i++){
+		eval(mb_loadWmsSubFunctions[i]);
+	return true;
+//CB
+function mb_mapObjaddWMSwithLayers(obj,layers,querylayers){
+	var styles = "";
+function mb_mapObjremoveWMS(objind,wmsind){
+	var wms_ID = null;
+	var new_wmsarray = new Array();
+	var new_layerarray = new Array();
+	var new_querylayerarray = new Array();
+	var new_stylesarray = new Array();
+	var new_mapURLarray = new Array();
+	for	(var i=0;i<mb_mapObj[objind].wms.length; i++){
+		if(i != wmsind){
+			new_wmsarray[new_wmsarray.length] = mb_mapObj[objind].wms[i];
+			new_layerarray[new_layerarray.length] = mb_mapObj[objind].layers[i];
+			new_querylayerarray[new_querylayerarray.length] = mb_mapObj[objind].querylayers[i];
+			new_stylesarray[new_stylesarray.length] = mb_mapObj[objind].styles[i];
+			new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i]
+		else {
+			wms_ID = mb_mapObj[objind].wms[i].wms_id;
+	mb_mapObj[objind].wms = new_wmsarray;
+	mb_mapObj[objind].layers = new_layerarray;
+	mb_mapObj[objind].querylayers = new_querylayerarray;
+	mb_mapObj[objind].styles = new_stylesarray;
+	mb_mapObj[objind].mapURL = new_mapURLarray;
+	var another_new_wmsarray = new Array();
+	for	(var i=0;i<wms.length; i++){
+		if(wms[i].wms_id != wms_ID){
+			another_new_wmsarray[another_new_wmsarray.length] = wms[i];
+	wms = another_new_wmsarray;
+function setExtent(width,height,epsg){
+   for(var i=0; i < wms[0].gui_epsg.length; i++){
+      if(wms[0].gui_epsg[i] == epsg){
+         var bbox_minx = parseFloat(wms[0].gui_minx[i]);
+         var bbox_miny = parseFloat(wms[0].gui_miny[i]);
+         var bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
+         var bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
+         var extenty = bbox_maxy - bbox_miny;
+         var extentx = bbox_maxx - bbox_minx;
+         var relation_px_x = width / height;
+         var relation_px_y = height / width;
+         var relation_bbox_x = extentx / extenty;
+         var centerx = bbox_minx + (extentx/2);
+         var centery = bbox_miny + (extenty/2);
+         if(relation_bbox_x <= relation_px_x){
+                bbox_minx = centerx - relation_px_x * extenty / 2;
+                bbox_maxx = centerx + relation_px_x * extenty / 2;
+         if(relation_bbox_x > relation_px_x){
+                bbox_miny = centery - relation_px_y * extentx / 2;
+                bbox_maxy = centery + relation_px_y * extentx / 2;
+        return bbox_minx  +","+ bbox_miny +","+ bbox_maxx  +","+ bbox_maxy;
+function setMapRequest(frameName){
+	var ts = mb_timestamp();
+	for(var i=0; i<mb_MapRequestPreFunctions.length; i++){
+		var ret = eval(mb_MapRequestPreFunctions[i]);
+		if(ret == false){
+			return true;
+		var newMapRequest = "";
+		if(mb_mapObj[i].frameName == frameName){
+			for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
+				if(mb_mapObj[i].wms[ii].gui_wms_visible > 0){
+					var myDivId = "div_" + ii;
+					var myMapId = "map_" + ii;
+					//disable Layer which are out of scale
+					var str_LayerStyles = mb_checkScale(frameName,i,ii);
+					if(mb_mapObj[i].layers[ii] != "" && str_LayerStyles[0] != ''){
+						var newMapURL = "";
+						newMapRequest += "<div id='"+myDivId+"' style='position:absolute; top:0px; left:0px; z-index:'"+ii+"'>";
+						newMapRequest += "<img id='"+myMapId+"' name='mapimage' src='";
+						newMapURL += mb_mapObj[i].wms[ii].wms_getmap;
+						newMapURL += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getmap);
+						if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){newMapURL += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=map&";}
+						if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){newMapURL += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetMap&SERVICE=WMS&";}
+						newMapURL += "LAYERS="+str_LayerStyles[0]+"&";
+						newMapURL += "STYLES="+str_LayerStyles[1]+"&";
+						newMapURL += "SRS="+mb_mapObj[i].epsg+"&";
+						newMapURL += "BBOX="+mb_mapObj[i].extent+"&";
+						newMapURL += "WIDTH="+mb_mapObj[i].width+"&";
+						newMapURL += "HEIGHT="+mb_mapObj[i].height+"&";
+						newMapURL += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
+						newMapURL += "BGCOLOR=0xffffff&";
+						if(mb_mapObj[i].wms[ii].gui_wms_mapformat.search(/gif/i)>-1 || mb_mapObj[i].wms[ii].gui_wms_mapformat.search(/png/i)>-1){
+							newMapURL += "TRANSPARENT=TRUE&";
+						newMapURL += "EXCEPTIONS="+mb_mapObj[i].wms[ii].gui_wms_exceptionformat;
+						// add vendor-specifics
+						for(var v=0; v<mb_vendorSpecific.length; v++){
+							newMapURL += "&" + eval(mb_vendorSpecific[v]);
+						// add Filter
+						if(mb_mapObj[i].wms[ii].wms_filter != ""){
+							var tmp = mb_mapObj[i].wms[ii].wms_filter +"?id="+ mb_styleID;
+							var temp = "&SLD=" + tmp+ "&";
+							newMapURL += temp;
+						if(mb_log){
+							var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
+						newMapRequest += newMapURL;
+						mb_mapObj[i].mapURL[ii] = newMapURL;
+						mb_mapObj[i].wms[ii].mapURL = newMapURL;
+						newMapRequest += "' width='"+mb_mapObj[i].width+"' height='"+mb_mapObj[i].height+"' border='0'></div>";
+					else{
+						mb_mapObj[i].mapURL[ii] = false;
+						mb_mapObj[i].wms[ii].mapURL = false;
+						newMapRequest += "<img id='"+myMapId+"' name='mapimage' src='" + mb_trans.src;
+						newMapRequest += "' width='"+mb_mapObj[i].width+"' height='"+mb_mapObj[i].height+"' border='0'>";
+						newMapRequest +="</div>";
+			//prompt("",newMapRequest);
+			writeTag(mb_mapObj[i].frameName,mb_mapObj[i].elementName,newMapRequest);
+	for(var i=0; i<mb_MapRequestSubFunctions.length; i++){
+		eval(mb_MapRequestSubFunctions[i]);
+function setSingleMapRequest(frameName,wms_id){
+		eval(mb_MapRequestPreFunctions[i]);
+				if(mb_mapObj[i].wms[ii].wms_id == wms_id){
+					// add Filter
+						//prompt("",tmp);;
+					//prompt("",newMapURL);
+					if(mb_mapObj[i].layers[ii] != "" && str_LayerStyles[0] != ""){
+					else{
+						newMapRequest = "<img id='"+myMapId+"' name='mapimage' src='" + mb_trans.src;
+					if(mb_log){
+					writeTag(mb_mapObj[i].frameName,myDivId,newMapRequest);
+function mb_restateLayers(frameName,wms_id){
+	//alert(frameName + " / " + wms_id);
+	var ind = getMapObjIndexByName(frameName);
+	for(var i=0; i<mb_mapObj[ind].wms.length; i++){
+		if(mb_mapObj[ind].wms[i].wms_id == wms_id){
+			var layers = "";
+			var styles = "";
+			for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
+					//alert(wms[i].objLayer[ii].layer_name);
+					styles += "";
+					cnt_layers++;
+				mb_mapObj[ind].layers[i] = layers;
+				mb_mapObj[ind].querylayers[i] = querylayers;
+				mb_mapObj[ind].styles[i] = styles;
+function mb_checkScale(frameName,mObj,wmsObj){
+	var thisLayer = mb_mapObj[mObj].layers[wmsObj].split(",");
+	var thisScale = mb_getScale(frameName);
+	var str_layer = "";
+	var str_styles = "";
+	var str_titles = "";
+	var str_legendurls = "";
+	var str_parent = "";
+	var cnt_layer = 0;
+	for(var i=0; i<mb_mapObj[mObj].wms[wmsObj].objLayer.length; i++){
+		var myLayername = mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_name;
+		var myMinscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_minscale;
+		var myMaxscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_maxscale;
+		for(var ii=0; ii<thisLayer.length; ii++){
+			var minscaleOK = false;
+			var maxscaleOK = false;
+			if(thisLayer[ii] == myLayername){
+				if(myMinscale == 0 || thisScale >= myMinscale){minscaleOK = true;}
+				if(myMaxscale == 0 || thisScale <= myMaxscale){maxscaleOK = true;}
+				if(maxscaleOK == true && minscaleOK == true ){
+					if(cnt_layer > 0){str_layer += ","; str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
+					str_layer += thisLayer[ii];
+					str_styles += "";
+					str_titles += mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_title;
+					str_parent += mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_parent;
+					if(mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_style.length>0){
+					 str_legendurls += mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_style[0]["legendurl"] ;
+					cnt_layer++;
+	var str_layerstyles = new Array();
+	str_layerstyles[0] = str_layer;
+	str_layerstyles[1] = str_styles;
+	str_layerstyles[2] = str_titles;
+	str_layerstyles[3] = str_legendurls;
+	str_layerstyles[4] = str_parent;
+	return str_layerstyles;
+function setFeatureInfoRequest(fName,x,y, path) {
+	for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
+		eval(mb_FeatureInfoPreFunctions[i]);
+	var cnt_fi = 0;
+		if(mb_mapObj[i].frameName == fName){
+				var newfeatureInfoRequest = "";
+				var requestParams = "";
+				var validation = false;
+				newfeatureInfoRequest += mb_mapObj[i].wms[ii].wms_getfeatureinfo;
+            	newfeatureInfoRequest += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);
+				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
+				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
+				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
+				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
+				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
+				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
+				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
+				requestParams += "STYLES="+mb_mapObj[i].styles[ii]+"&";
+				requestParams += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
+				requestParams += "INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";
+				requestParams += "EXCEPTIONS=application/vnd.ogc.se_xml&";
+				if(mb_feature_count > 0){
+					requestParams += "FEATURE_COUNT="+mb_feature_count+"&";
+				requestParams += "QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";
+				requestParams += "X=" + x  + "&";
+				requestParams += "Y=" + y;
+				if(mb_mapObj[i].querylayers[ii] != "" && mb_mapObj[i].layers[ii] != ""){
+					validation = true;
+				//add vendor-specific
+		            requestParams += "&" + eval(mb_vendorSpecific[v]);
+				if(mb_log && validation){
+					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
+				if(document.getElementById("FeatureInfoRedirect") && validation){
+					newfeatureInfoRequest += requestParams;
+					if(path){
+						window.frames["FeatureInfoRedirect"].document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
+					else{
+						window.frames["FeatureInfoRedirect"].document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
+					cnt_fi++;
+				else if(path && validation){
+					window.open(path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
+					cnt_fi++;
+				else if(validation){
+					window.open(newfeatureInfoRequest, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
+					cnt_fi++;
+   	if(cnt_fi == 0){alert("Please select a layer! \n Bitte wählen Sie eine Ebene zur Abfrage aus!");}
+function writeTag(frameName, elName, tagSource) {
+  if(frameName && frameName != ""){
+     window.frames[frameName].document.getElementById(elName).innerHTML = tagSource;
+  else if(!frameName || frameName == ""){
+       document.getElementById(elName).innerHTML = tagSource;
+function zoom(frameName,in_, factor,x,y) {
+  var x = parseFloat(x);
+  var y = parseFloat(y);
+  var arrayBBox = mb_mapObj[ind].extent.split(",");
+  var xtentx = parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]);
+  var xtenty =  parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]);
+  var centerx = parseFloat(arrayBBox[0]) + xtentx/2;
+  var centery = parseFloat(arrayBBox[1]) + xtenty/2;
+  var factor = parseFloat(factor);
+  if(x){
+   centerx = x;
+   centery = y;
+  if (!in_) {factor = 1 / factor;}
+  var new_xtentx = xtentx / factor;
+  var new_xtenty = xtenty / factor;
+  var minx = centerx - new_xtentx / 2;
+  var miny = centery - new_xtenty / 2;
+  var maxx = centerx + new_xtentx / 2;
+  var maxy = centery + new_xtenty / 2;
+  mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
+  setMapRequest(frameName);
+function mb_panMap(frameName,dir){
+   var minx = parseFloat(arrayBBox[0]);
+   var miny = parseFloat(arrayBBox[1]);
+   var maxx = parseFloat(arrayBBox[2]);
+   var maxy = parseFloat(arrayBBox[3]);
+   if(dir == "NW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "N"){miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "NE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
+   if(dir == "W"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2);}
+   if(dir == "E"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2);}
+   if(dir == "SW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+   if(dir == "S"){miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+   if(dir == "SE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
+function handleSelectedLayer(frameName,wms_title,layerName,type,status){
+	//alert(frameName + " , " +wms_title + " , " +layerName + " , " +type + " , " +status);
+   //type = {visible || querylayer] status = {0 || 1}
+         var myMapObj = i;
+             if(mb_mapObj[i].wms[ii].wms_title == wms_title){ //ii is true
+                var myWMS = ii;
+                if(type == "visible"){var arrayLayer = mb_mapObj[i].layers[ii].split(",");}
+                if(type == "querylayer"){var arrayLayer = mb_mapObj[i].querylayers[ii].split(",");}
+                for(var iii=1; iii<mb_mapObj[i].wms[ii].objLayer.length; iii++){
+                   var layer_name = mb_mapObj[i].wms[ii].objLayer[iii].layer_name;
+	              	if(layer_name == layerName && status == 1 && mb_mapObj[i].wms[ii].objLayer[iii].layer_queryable == 1){
+                         if(cnt_layer > 0){str_layer += ",";}
+                         str_layer += layer_name;
+                         cnt_layer++;
+                   else if(type == "visible"){
+                   	if(layer_name == layerName && status == 1){
+                         cnt_layer++;
+                   for(var iiii=0; iiii<arrayLayer.length; iiii++){
+                      if(layer_name == arrayLayer[iiii] && layer_name != layerName){
+                         cnt_layer++;
+      mb_mapObj[myMapObj].layers[myWMS] = str_layer;
+      var array_str_layer = str_layer.split(",");
+      for(var cnt=0; cnt<array_str_layer.length; cnt++){
+         if(cnt > 0){str_styles += ",";}
+         str_styles += "";
+      mb_mapObj[myMapObj].styles[myWMS] = str_styles;
+   if(type == "querylayer"){mb_mapObj[myMapObj].querylayers[myWMS] = str_layer;}
+   if(type == 'visible'){
+      setSingleMapRequest(frameName,wms_title);
+function handleSelectedLayer_array(mapObj, array_wms, array_layer, type, status){
+	//alert(mapObj+" / "+array_wms[0]+" / "+ array_layer[0]+" / "+ type+" / "+ status);
+	var ind = getMapObjIndexByName(mapObj);
+	for(var j=0; j<array_wms.length; j++){
+			if(mb_mapObj[ind].wms[i].wms_id == array_wms[j]){
+				var check = false;
+					if(wms[i].wms_id == array_wms[j] && wms[i].objLayer[ii].layer_name == array_layer[j]){
+							wms[i].objLayer[ii].gui_layer_visible = parseInt(status);
+							check = true;
+                        if(type == "querylayer" && (wms[i].objLayer[ii].gui_layer_queryable == "1" || wms[i].objLayer[ii].gui_layer_queryable == 1)){
+							wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status);
+                mb_restateLayers(mapObj, array_wms[j]);
+                //alert('restate');
+                * hier noch checken, welche wms sich geändert haben und disctinct eine singleRequest aufrufen:
+                if(check == true){
+                    if(mb_mapObj[ind].wms[i].gui_wms_visible == 1){
+						setSingleMapRequest(mapObj,wms[i].wms_id);
+                        //alert('sSMR');
+function makeClickPos2RealWorldPos(frameName, myClickX, myClickY) {
+	var width = parseInt(mb_mapObj[ind].width);
+	var height = parseInt(mb_mapObj[ind].height);
+	var minX = parseFloat(arrayBBox[0]);
+	var minY = parseFloat(arrayBBox[1]);
+	var maxX = parseFloat(arrayBBox[2]);
+	var maxY = parseFloat(arrayBBox[3]);
+	var deltaX = (maxX - minX)/width;
+	var deltaY = (maxY - minY)/height;
+	if(deltaX > 0){
+		var roundx = 1/Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
+	else{
+		var roundx =  Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
+	if(deltaY > 0){
+		var roundy = 1/Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
+	else{
+		var roundy =  Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
+	var xtentx = maxX - minX;
+	var xtenty =  maxY - minY;
+	var posX = parseFloat(minX + (myClickX / width) * xtentx);
+	var posY = parseFloat(maxY - (myClickY / height) * xtenty);
+	posX = Math.round(posX * roundx)/roundx;
+	posY = Math.round(posY * roundy)/roundy;
+	return new Array(posX, posY);
+function makeRealWorld2mapPos(frameName,rw_posx, rw_posy){
+   var width = mb_mapObj[ind].width;
+   var height = mb_mapObj[ind].height;
+   pixPos_x = Math.round(parseFloat(((rw_posx - minX)/xtentx)*width));
+   pixPos_y = Math.round(parseFloat(((maxY - rw_posy)/xtenty)*height));
+   return new Array(pixPos_x, pixPos_y);
+function mb_arrangeElement(frameName, elName, left, top) {
+   if(frameName != ""){
+      window.frames[frameName].document.getElementById(elName).style.top = top;
+      window.frames[frameName].document.getElementById(elName).style.left = left;
+   else{
+      document.getElementById(elName).style.top = top;
+      document.getElementById(elName).style.left = left;
+/****************BUTTON HANDLING*************************/
+var mb_button = new Array();
+function mb_regButton_frame(wii, frameName, param){
+	var ind = mb_button.length;
+	mb_button[ind] = new mb_conButton(wii, ind);
+	if (frameName == null) {
+		if (param == null) {
+			eval(wii+"("+ind+")");
+		else {
+			eval(wii+"("+ind+", "+param+")");
+	else if (param == null) {
+		eval("window.frames['" + frameName + "']."+wii+"("+ind+")");
+	else {
+		eval("window.frames['" + frameName + "']."+wii+"("+ind+", "+param+")");
+	mb_button[ind].prev = mb_button[ind].src;
+	mb_button[ind].src = mb_button[ind].img_over;
+	mb_button[ind].onmouseover = new Function("mb_button_over("+ind+")");
+	mb_button[ind].onmouseout = new Function("mb_button_out("+ind+")");
+	mb_button[ind].onclick = new Function("mb_button_click("+ind+")");
+	if (frameName==null) {
+		mb_button[ind].frameName = "";
+	else {
+		mb_button[ind].frameName = frameName;
+function mb_regButton(wii){
+	mb_regButton_frame(wii, null, null);
+function mb_conButton(wii, ind){
+   this.wii = wii;
+   return true;
+function mb_button_over(ind){
+   if(mb_button[ind].status == 0){
+function mb_button_out(ind){
+   mb_button[ind].src = mb_button[ind].prev;
+function mb_button_click(ind){
+   var mbStatus = mb_button[ind].status;
+   if(mbStatus == 0){
+      mb_disableButton(mb_button[ind].elName);
+      mb_button[ind].prev = mb_button[ind].img_on;
+      mb_button[ind].src = mb_button[ind].img_on;
+      mb_button[ind].status = 1;
+      if (mb_button[ind].frameName != "") {
+          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).go();
+      else {
+	      document.getElementById(mb_button[ind].elName).go();
+   else{
+      mb_button[ind].prev = mb_button[ind].img_off;
+      mb_button[ind].src = mb_button[ind].img_off;
+      mb_button[ind].status = 0;
+          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).stop();
+      else {
+	      document.getElementById(mb_button[ind].elName).stop();
+function mb_disableButton(elName){
+   for(var i=0; i<mb_button.length; i++){
+      if(mb_button[i].elName != elName && mb_button[i].status == 1){
+            mb_button[i].status = 0;
+		      if (mb_button[i].frameName != "") {
+    	        window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
+	            window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).stop();
+		      else {
+    	        document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
+	            document.getElementById(mb_button[i].elName).stop();
+            return true;
+function mb_disableThisButton(elName){
+      if(mb_button[i].elName == elName && mb_button[i].status == 1){
+//      		alert(mb_button[i].elName);
+		      else {
+            return true;
+/***********************Drag & Drop***********************/
+function mb_getMousePos(e,fName){
+if(fName){
+     if(ie){
+        clickX = window.frames[fName].event.clientX;
+        clickY = window.frames[fName].event.clientY;
+     else{
+        clickX = e.pageX;
+        clickY = e.pageY;
+  else{
+       if(ie){
+        clickX = event.clientX;
+        clickY = event.clientY;
+     else{
+        clickX = e.pageX;
+        clickY = e.pageY;
+  var pos = new Array(clickX,clickY);
+  return pos;
+// function for object-identification
+function getMapObjIndexByName(frameName){
+			return i;
+function mb_getLayerTitleByName(map_index, wms_index, myLayer_name){
+	for(var i=0; i<mb_mapObj[map_index].wms[wms_index].objLayer.length; i++){
+		if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name == myLayer_name){
+			return mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_title;
+function getWMSIDByTitle(frameName,wms_title){
+   for(var i=0; i< mb_mapObj[ind].wms.length; i++){
+      if(mb_mapObj[ind].wms[i].wms_title == wms_title){
+         //return i;
+         return mb_mapObj[ind].wms[i].wms_id;
+function getWMSIndexByTitle(frameName,wms_title){
+         return i;
+function getWMSIndexById(frameName,wms_id){
+         return i;
+//scale
+function mb_getScale(frameName) {
+   for(var i=0; i<mb_GetScalePreFunctions.length; i++){
+		var myScale = eval(mb_GetScalePreFunctions[i]);
+   if(myScale){
+      var Y_str = myScale;
+   else{
+      var scaleY = (xtenty / mb_mapObj[ind].height) *(mb_resolution * 100);
+      var Y_str = Math.round(scaleY);
+   return Y_str;
+function mb_repaintScale(frameName, x, y, scale){
+   if(x == null && y == null){
+      x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
+      y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
+   var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
+   var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
+   var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
+   var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
+   mb_repaint(frameName,minx, miny, maxx, maxy);
+function mb_repaint(frameName,minx,miny,maxx,maxy){
+function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
+  var extenty = maxy - miny;
+  var extentx = maxx - minx;
+  var relation_px_x = mb_mapObj[ind].width / mb_mapObj[ind].height;
+  var relation_px_y = mb_mapObj[ind].height / mb_mapObj[ind].width;
+  var centerx = minx + (extentx/2);
+  var centery = miny + (extenty/2);
+    minx = centerx - relation_px_x * extenty / 2;
+    maxx = centerx + relation_px_x * extenty / 2;
+    miny = centery - relation_px_y * extentx / 2;
+    maxy = centery + relation_px_y * extentx / 2;
+  mb_mapObj[ind].extent = minx  +","+ miny +","+ maxx  +","+ maxy;
+function mb_showHighlight(frameName,x,y){
+   var pos = makeRealWorld2mapPos(frameName,x, y);
+   mb_arrangeElement(frameName,"highlight",pos[0]-7, pos[1]-7);
+   window.frames[frameName].document.getElementById("highlight").style.visibility = 'visible';
+function mb_hideHighlight(frameName){
+   mb_arrangeElement(frameName,"highlight",-20, -20);
+   window.frames[frameName].document.getElementById("highlight").style.visibility = 'hidden';
+function mb_permanentHighlight(frameName,x,y){
+   mb_arrangeElement(frameName,"permanent",pos[0]-7, pos[1]-7);
+   window.frames[frameName].document.getElementById("permanent").style.visibility = 'visible';
+// framename, commaseparated coordinates, commaseparated rgb values (color)
+//new: coords is array!
+function mb_markResult(frameName,geom,col){
+	var x = "";
+	var y = "";
+	var tmp = new Array();
+	for(var i=0; i<geom.length; i++){
+		if(i>0){
+			x += ":";
+			y += ":";
+		tmp = geom[i].split(",");
+		for(var ii=0; ii<tmp.length; ii+=2){
+			var pos = makeRealWorld2mapPos(frameName,tmp[ii], tmp[ii+1]);
+			if(ii>0){
+				x += ",";
+				y += ",";
+			x += pos[0];
+			y += pos[1];
+	var source = "<img src='../extensions/markResult.php?x=" + x + "&y=" + y + "&width=" + mb_mapObj[ind].width + "&height=" + mb_mapObj[ind].height + "&color="+col+"'>";
+	//prompt("",source);
+	writeTag(frameName,"markResult",source);
+function mb_disableResult(frameName){
+   writeTag(frameName,"markResult","");
+function Numsort(a,b){
+	return a-b;
+* Object (Array)
+* this.id
+* this.type
+* this.x = new Array();
+* this.y = new Array();
+* this.label
+* this.epsg
+function mb_registerGML(frameName,obj){
+	mb_mapObj[ind].geom = obj;
+//deprecated!
+function mb_obj2gml(frameName){
+	var geom = mb_mapObj[ind].geom;
+	var layerName = "MyLayer";
+	var str = "&lt;?xml version=&quot;1.0&quot; encoding=&quot;ISO-8859-1&quot;?&gt;<wfs:FeatureCollection ";
+	str += "xmlns='http://www.ttt.org/myns' ";
+	str += "xmlns:myns='http://www.opengis.net/' ";
+	str += "xmlns:wfs='http://www.opengis.net/wfs/' ";
+	str += "xmlns:gml='http://www.opengis.net/gml/' ";
+	str += "xmlns:ogc='http://www.opengis.net/ogc/' ";
+	str += "xmlns:xsi='http://www.w3.org/' ";
+	str += "xsi:schemaLocation='http://www.opengis.net/wfs ../wfs/1.0.0/WFS-basic.xsd                         http://www.ttt.org/myns http://localhost/cgi-bin/mapserv44?'>";
+	str += "<gml:boundedBy>";
+		str += "<gml:Box srsName='"+geom[0].epsg.substr(0,4).toLowerCase()+geom[0].epsg.substr(4,geom[0].epsg.length)+"'>";
+			str += "<gml:coordinates>";
+				str += "-1.000000,-1.000000 -1.000000,-1.000000";
+			str += "</gml:coordinates>";
+		str += "</gml:Box>";
+	str += "</gml:boundedBy>";
+	var myType = "";
+	for(var i=0; i<geom.length;i++){
+		if(geom[i].type == "text"){ myType = "point";}
+		if(geom[i].type == "line"){ myType = "lineString";}
+		if(geom[i].type == "polygon"){ myType = "polygon";}
+		var sortx = geom[i].x;
+		var sorty = geom[i].y;
+		//sortx.sort(Numsort);
+		//sorty.sort(Numsort);
+		str += "<gml:featureMember>";
+			str += "<"+layerName+">";
+					str += "<gml:Box srsName=&quot;"+geom[i].epsg.substr(0,4).toLowerCase()+geom[i].epsg.substr(4,geom[i].epsg.length)+"&quot;>";
+							str += sortx[0]+"," + sorty[0] + " " + sortx[sortx.length-1] + "," + sorty[sorty.length-1];
+				str += "<gml:"+myType+"Property>";
+					str += "<gml:"+myType.charAt(0).toUpperCase()+myType.substr(1,myType.length);
+					str += " srsName=&quot;"+geom[i].epsg.substr(0,4).toLowerCase()+geom[i].epsg.substr(4,geom[i].epsg.length)+"&quot;>";
+						if(geom[i].type == "polygon"){ str += "<gml:outerBoundaryIs><gml:LinearRing>";}
+						for(var j=0; j<geom[i].x.length; j++){
+							str += geom[i].x[j] + "," + geom[i].y[j] + " ";
+							//alert(geom[i].x[j] + "," + geom[i].y[j]);
+						if(geom[i].type == "polygon"){ str += "</gml:LinearRing></gml:outerBoundaryIs>";}
+					str += "</gml:"+myType.charAt(0).toUpperCase()+myType.substr(1,myType.length)+">";
+				str += "</gml:"+myType+"Property>";
+				str += "<id>"+i+"</id>";
+			if(geom[i].label != false){
+				str += "<label>"+geom[i].label+"</label>";
+			str += "</"+layerName+">";
+		str += "</gml:featureMember>";
+	str += "</wfs:FeatureCollection>";
+	return str;
+	document.sendData.target = "_blank";
+	document.sendData.action = "../classes/class_gml2obj.php";
+	document.sendData.data.value = str;
+	document.sendData.submit();
+function mb_timestamp(){
+	var d = new Date();
+	var ts = Math.round(Date.parse(d)/1000);
+	return ts;
+function mb_getlayerposbyname(objInd,wmsInd,lname){
+	var t = mb_mapObj[objInd].wms[wmsInd];
+	for(var i=0; i < t.objLayer.length; i++){
+		if(t.objLayer[i].layer_name == lname){
+			return t.objLayer[i].layer_pos;
+function mb_getLayerObjByName(fname,wms_id,layer_name){
+	var ind = getMapObjIndexByName(fname);
+	var wmsInd = getWMSIndexById(fname,wms_id);
+	var t = mb_mapObj[ind].wms[wmsInd];
+		if(t.objLayer[i].layer_name == layer_name){
+			return t.objLayer[i];
+function mb_getchildsbyname(objInd,wmsInd,lname){
+	var pos = mb_getlayerposbyname(objInd, wmsInd,lname);
+	var l = new Array();
+	l["name"] = new Array();
+	l["title"] = new Array();
+	l["legendurl"] = new Array();
+		if(t.objLayer[i].layer_parent == pos){
+			l["name"][l["name"].length] = t.objLayer[i].layer_name;
+			l["title"][l["title"].length] = t.objLayer[i].layer_title;
+			if(t.objLayer[i].layer_style.length>0){
+				l["legendurl"][l["legendurl"].length] = t.objLayer[i].layer_style[0]["legendurl"] ;
+			}else{
+				l["legendurl"][l["legendurl"].length] = 0 ;
+	if(l["name"].length > 0){
+		return l;
+	else{
+		return false;
+ checks if a tag <tagname> with id <id> exists in frame <framename>.
+ if yes, the node is returned
+ if no, the node is created with attributes <attributes> and returned
+ if a node with id <id> exists but the tagname is not <tagname>, false is returned.
+function mb_checkTag(frameName, tagName, elementId, appendAtTagName, attributes){
+	var oldElement;
+	var newElement;
+	// for both frames and no frames...
+		oldElement = window.frames[frameName].document.getElementById(elementId);
+		oldElement = document.getElementById(elementId);
+	// ... check if an element with elementId exists.
+	if (oldElement == null) {
+		// if no element with elementId exists, a new one is created and appended to appendAtTagName
+		newElement = window.frames[frameName].document.createElement(tagName);
+			newElement = window.frames[frameName].document.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);
+	else {
+		// if element id is already taken, check if tag name are identical
+		// if yes, the desired element already exists, and is returned
+		// if not, another element with the desired id exists, false is returned
+		if (oldElement.nodeName.toLowerCase() == tagName.toLowerCase()) {
+			for (var i=0; i<attributes.length; i++) {
+				oldElement.setAttribute(attributes[i][0], attributes[i][1]);
+			return oldElement;
+		else {
+			return false;
+	// set element id
+	var newElementAttributeNode = document.createAttribute("id");
+	newElementAttributeNode.value = elementId;
+	newElement.setAttributeNode(newElementAttributeNode);
+		newElement.setAttribute(attributes[i][0], attributes[i][1]);
+	return newElement;
+function mb_execloadWmsSubFunctions(){
+function mb_getConjunctionCharacter(onlineresource){
+	if(onlineresource.indexOf("?") > -1){
+		if(onlineresource.charAt(onlineresource.length-1) == "?"){
+			nextvalue = "";
+		}else if(onlineresource.charAt(onlineresource.length-1) == "&"){
+			nextvalue = "";
+		}else{
+			nextvalue = "&";
+	if(onlineresource.indexOf("?") == -1){
+		nextvalue = "?";
+	return nextvalue;
+<?php
+include("../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$mb_sql = "SELECT e_js_file FROM gui_element WHERE  e_public = 1 AND fkey_gui_id = '".$_REQUEST["gui_id"]."' ORDER BY e_pos";
+$mb_res = db_query($mb_sql);
+//$mb_cnt = 0;
+while($row_js = db_fetch_array($mb_res)){
+   if($row_js["e_js_file"] != ""){
+      include($row_js["e_js_file"]);
More information about the Mapbender_commits mailing list
