svn commit: r356 - trunk/mapbender/http/javascripts/mod_digitize_tab.php
christoph at osgeo.org christoph at osgeo.org
Mon May 29 10:19:37 EDT 2006
Author: christoph
Date: 2006-05-29 14:19:37+0000
New Revision: 356
new, see wiki for details
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_digitize_tab.php?view=diff&rev=356&p1=trunk/mapbender/http/javascripts/mod_digitize_tab.php&p2=trunk/mapbender/http/javascripts/mod_digitize_tab.php&r1=355&r2=356
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	(original)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2006-05-29 14:19:37+0000
@@ -1,3 +1,4 @@
+<?php
 # $Id$
 # http://www.mapbender.org/index.php/mod_digitize_tab.php
 # Copyright (C) 2002 CCGIS
@@ -16,7 +17,6 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-<?php
 session_start();
 import_request_variables("PG");
 require_once("../php/mb_validateSession.php");
@@ -59,773 +59,566 @@
 	echo "<script language='JavaScript'>";
 	echo "var mod_digitize_target = '".$e_target[0]."';";
 	echo "var mod_digitize_frame = '".$e_target[1]."';";
+	require_once("mod_geometryArray.js");
-//var mod_digitize_status = 0;
-//public
-var mod_digitize_color1 = "white";
-var mod_digitize_color2 = "black";
-var mod_digitize_font = "Arial, Helvetica, sans-serif";
-var mod_digitize_fontsize = "9px";
-var mod_digitize_basepoint = "#8a2be2";
-var mod_digitize_linepoint = "#ff00ff";
-var mod_digitize_bg = "";
-var mod_digitize_elName = "digitize";
-var mod_digitize_frameName = "";
 var wfsWindow;
-var snappingCoordinates = new Array();
-var snappingTolerance = 12;
-var snappedMember = -1;
-var snappedGeometry = -1;
-var snappedPoint = -1;
-var snapped = false;
-// canvas contains circles around snapping target
-var canvas = new Array();
+var dwin = null;
 var wfs_conf = new Array();
-var D = new Array();
-var activeButton = null; // contains id of active button
-var isOn = true;
+var d = new GeometryArray();
 var mod_digitize_width;
 var mod_digitize_height;
-var mod_digitize_Dist = new Array();
-var mod_digitize_TotalDist = new Array();
-var mod_digitizeSubFunctions = new Array();
 var mod_digitizeEvent = false;
-//currently selected basepoint
-var basepointObject = false;
-// stores the number of geometries in the geometry list
-var numberOfGeometries = 0;
-//indices of the geometry associated with a certain basepoint
-var basepointMemberIndex = false;
-var basepointGeometryIndex = false;
-var basepointPointIndex = false;
+try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
-//when a basepoint is being dragged, the coordinates are stored
-var basepointDragActive = false;
-var basepointDragStartX = false;
-var basepointDragStartY = false;
-var basepointDragEndX = false;
-var basepointDragEndY = false;
-//indices of the geometry that is currently built
-var currentMemberIndex = -1;
-var currentGeometryIndex = -1;
+// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
-function registerFunctions(){
-	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].setStyleForTargetFrame()");
-	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].checkTag()");
-	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
+function appendGeometry(obj) {
+	executeDigitizePreFunctions();
+	d.appendMember(obj);
+	executeDigitizeSubFunctions();
-function checkTag(){
-	var attributes = new Array();
-	attributes[0] = new Array();
-	attributes[0][0] = "style";
-	attributes[0][1] = "position:absolute; top:0px; left:0px; z-index:26; font-size:10px";
-	node = parent.mb_checkTag(mod_digitize_target, "div", "digitize", "body", attributes);
-	if (node == false) {
-		alert("Fatal error: Element id 'digitize' is already taken!");
+function mod_digitize_go(e){
+	parent.mb_registerGML(mod_digitize_target,d);
-function setStyleForTargetFrame(){
-	var cssLink = parent.window.frames[mod_digitize_target].document.createElement("link");
-	cssLink.setAttribute("href", cssUrl);
-	cssLink.setAttribute("type", "text/css");
-	cssLink.setAttribute("rel", "stylesheet");
-	var cssTmp = parent.window.frames[mod_digitize_target].document.getElementsByTagName("head")[0];
-	cssTmp.appendChild(cssLink);
+	// ie workaround
+	if (e == undefined) {
+		e = parent.frames[mod_digitize_target].event;
+	if (e) {
+		// track mouse position
+		parent.mb_getMousePos(e, mod_digitize_target);
+		var currentPos = new Point(parent.clickX, parent.clickY);
+		s.check(currentPos);
+	else {
+		s.clean();
+	var el = parent.frames[mod_digitize_target].document;
+	el.onmousedown = mod_digitize_start;
-function const_D(id,type){
-	this.id = id;
-	this.type = type;
-	this.x = new Array();
-	this.y = new Array();
-	this.label = "";
-	var ind = parent.getMapObjIndexByName(mod_digitize_target);
-	this.epsg = parent.mb_mapObj[ind].epsg;
-	this.units = "";
-	this.dist = new Array();
-	this.totaldist = new Array();
-	this.complete = false;
+function mod_digitize_timeout(){
+	//parent.document.getElementById(mod_digitize_elName).style.visibility = 'hidden';
+	el.onmousedown = null;
+	el.onmouseup = null;
+	el.onmousemove = null;
-function displayButtons(){
-	if (parseInt(buttonPoint)==1){
-		var tagContent = "<img name=\""+buttonPointId+"\" onmouseover=\"registerButton('initButtonPoint')\" id=\""+buttonPointId+"\" title=\""+buttonPointTitleUp+"\" src=\""+buttonPointSrcUp+"\">";
-			parent.writeTag(mod_digitize_elName,"divButtonPoint",tagContent);
-	if (parseInt(buttonLine)==1){
-		var tagContent = "<img name=\""+buttonLineId+"\" onmouseover=\"registerButton('initButtonLine')\" id=\""+buttonLineId+"\" title=\""+buttonLineTitleUp+"\" src=\""+buttonLineSrcUp+"\">";
-		parent.writeTag(mod_digitize_elName,"divButtonLine",tagContent);
+function mod_digitize_start(e){
+	// check if a proper geometry is selected
+	if (d.getGeometry(-1,-1).complete == true || d.count() == 0){
+		if (mod_digitizeEvent != false) {
+			alert("No geometry selected!");
+		return false;
-	if (parseInt(buttonPolygon)==1){
-		var tagContent = "<img name=\""+buttonPolygonId+"\" onmouseover=\"registerButton('initButtonPolygon')\" id=\""+buttonPolygonId+"\" title=\""+buttonPolygonTitleUp+"\" src=\""+buttonPolygonSrcUp+"\">";
-		parent.writeTag(mod_digitize_elName,"divButtonPolygon",tagContent);
+	var realWorldPos;
+	if (s.isSnapped() == true) {
+		realWorldPos = s.getSnappedPoint(d);
+		s.clean();
-	if (parseInt(buttonMove)==1){
-		var tagContent = "<img name=\""+buttonMoveId+"\" onmouseover=\"registerButton('initButtonMove')\" id=\""+buttonMoveId+"\" title=\""+buttonMoveTitleUp+"\" src=\""+buttonMoveSrcUp+"\">";
-		parent.writeTag(mod_digitize_elName,"divButtonMove",tagContent);
+	else {
+		parent.mb_getMousePos(e,mod_digitize_target);
+		realWorldPos = parent.mapToReal(mod_digitize_target,new Point(parent.clickX,parent.clickY));
-	if (parseInt(buttonInsert)==1){
-		var tagContent = "<img name=\""+buttonInsertId+"\" onmouseover=\"registerButton('initButtonInsert')\" id=\""+buttonInsertId+"\" title=\""+buttonInsertTitleUp+"\" src=\""+buttonInsertSrcUp+"\">";
-		parent.writeTag(mod_digitize_elName,"divButtonInsert",tagContent);
+	if (d.get(-1).geomtype == geomTypePolygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
+		// close the polygon
+		parent.mb_disableThisButton(button_polygon);
-	if (parseInt(buttonDelete)==1){
-		var tagContent = "<img name=\""+buttonDeleteId+"\" onmouseover=\"registerButton('initButtonDelete')\" id=\""+buttonDeleteId+"\" title=\""+buttonDeleteTitleUp+"\" src=\""+buttonDeleteSrcUp+"\">";
-		parent.writeTag(mod_digitize_elName,"divButtonDelete",tagContent);
+	else if (d.get(-1).geomtype == geomTypeLine && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
+		// close the line
+		parent.mb_disableThisButton(button_line);
-function registerButton(functionName){
-	parent.mb_regButton_frame(functionName, mod_digitize_elName);
-function initButtonPoint(ind){
-	initButton(ind, buttonPointSrcUp, buttonPointSrcDown, buttonPointSrcUp, buttonPointTitleUp, buttonPointTitleDown, buttonPointId);
-function initButtonLine(ind){
-	initButton(ind, buttonLineSrcUp, buttonLineSrcDown, buttonLineSrcUp, buttonLineTitleUp, buttonLineTitleDown, buttonLineId);
-function initButtonPolygon(ind){
-	initButton(ind, buttonPolygonSrcUp, buttonPolygonSrcDown, buttonPolygonSrcUp, buttonPolygonTitleUp, buttonPolygonTitleDown, buttonPolygonId);
-function initButtonMove(ind){
-	initButton(ind, buttonMoveSrcUp, buttonMoveSrcDown, buttonMoveSrcUp, buttonMoveTitleUp, buttonMoveTitleDown, buttonMoveId);
+	else {
+		// set the calculated real world position as point of the geometry
+		d.getGeometry(-1,-1).addPoint(realWorldPos);
+		if(d.get(-1).geomtype == geomTypePoint){
+			parent.mb_disableThisButton(button_point);
+		// add first point of polygon to snapping list (if three points have been inserted).
+		else if (d.get(-1).geomtype == geomTypePolygon && d.getGeometry(-1,-1).count() == 3) {
+			s.add(d, 0, -1, -1)
-function initButtonInsert(ind){
-	initButton(ind, buttonInsertSrcUp, buttonInsertSrcDown, buttonInsertSrcUp, buttonInsertTitleUp, buttonInsertTitleDown, buttonInsertId);
+		// add last point of line to snapping list (if at least two points have been inserted).
+		else if (d.get(-1).geomtype == geomTypeLine && d.getGeometry(-1,-1).count() >= 2) {
+			s.store(d, mod_digitizeEvent);
+			s.add(d, -1, -1, -1)
+	return true;
-function initButtonDelete(ind){
-	initButton(ind, buttonDeleteSrcUp, buttonDeleteSrcDown, buttonDeleteSrcUp, buttonDeleteTitleUp, buttonDeleteTitleDown, buttonDeleteId);
+// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
-function initButton(ind, srcOver, srcDown, srcUp, titleUp, titleDown, id){
-	parent.mb_button[ind] = document.getElementById(id);
-	parent.mb_button[ind].img_over = srcOver;
-	parent.mb_button[ind].img_on = srcDown;
-	parent.mb_button[ind].img_off = srcUp;
-	parent.mb_button[ind].title_on = titleUp;
-	parent.mb_button[ind].title_off = titleDown;
-	parent.mb_button[ind].status = 0;
-	parent.mb_button[ind].elName = id;
-	parent.mb_button[ind].fName = "";
-	parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
-	parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
+var basepointObject = false;
+var basepointMemberIndex = null;
+var basepointGeometryIndex = null;
+var basepointPointIndex = null;
+var basepointDragActive = false;
-function digitizeEnable(obj){
-	if (obj.id == buttonMoveId || obj.id == buttonInsertId || obj.id == buttonDeleteId){
-		activeButton = obj.id;
-		setEvent(obj);
+function handleBasepoint(obj,memberIndex,geometryIndex,pointIndex){
+	if(!(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete)){ return false; };
+	basepointObject = obj;
+	basepointMemberIndex = memberIndex;
+	basepointGeometryIndex = geometryIndex;
+	basepointPointIndex = pointIndex;
+	if(mod_digitizeEvent == button_move){
+		mod_digitize_timeout();
+		basepointObject.style.cursor = 'move';
+		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].selectBasepoint;
-	else if (obj.id == buttonPointId || obj.id == buttonLineId || obj.id == buttonPolygonId){
-		obj.title = obj.title_off;
-		currentMemberIndex = -1;
-		registerGeometry(obj);
-		storeSnappingCoordinates();
-		var el = parent.frames[mod_digitize_target].document;
-		el.onmousemove = mod_digitize_go;
+	if(mod_digitizeEvent == button_delete){
+		basepointObject.style.cursor = 'crosshair';
+		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].deleteBasepoint;
-function digitizeDisable(obj){
-	if (obj.id == buttonPointId || obj.id == buttonLineId || obj.id == buttonPolygonId){
-		activeButton = null;
-		obj.title = obj.title_on;
-		closeGeometry(obj.id);
+function convertLinepointToBasepoint(obj, memberIndex, geomIndex, pointIndex){
+	if(!(mod_digitizeEvent == button_insert)){ return false; };
+	if(mod_digitizeEvent == button_insert){
+		obj.style.cursor = 'crosshair';
+		obj.onclick = insertBasepoint;
+		basepointGeometryIndex = geomIndex;
+function insertBasepoint(e){
+	var i = basepointMemberIndex;
+	var j = basepointGeometryIndex;
+	var k = basepointPointIndex;
+	var pos = parent.makeClickPos2RealWorldPos(mod_digitize_target,parent.clickX, parent.clickY);
+	var p = new Point(pos[0], pos[1]);
+	d.getGeometry(i,j).addPointAtIndex(p, k);
-var dwin = null;
-function mod_saveGeom(){
-	dwin = window.open("../php/mod_wfs_save.php","dwin","width=300,height=200");
+function deleteBasepoint(){
+	d.delAllPointsLike(d.getPoint(i,j,k));
-function cleanCanvas(){
-	var el = parent.window.frames[mod_digitize_target].document.getElementById('mod_digi_draw');
-	if (el) el.innerHTML = "";
-function checkCanvasTag(){
-	var isTag = (parent.window.frames[mod_digitize_target].document.getElementById('mod_digi_draw'))?1:0;
-	if(isTag == 0){
-		var draw = parent.window.frames[mod_digitize_target].document.createElement("div");
-		var tmp = parent.window.frames[mod_digitize_target].document.getElementsByTagName("body")[0].appendChild(draw);
-		tmp.setAttribute("id","mod_digi_draw");
-		tmp.setAttribute("style","position:absolute;top:0px;left:0px;width:0px;height:0px;z-index:100");
-	canvas[mod_digitize_target] = new parent.jsGraphics('mod_digi_draw', parent.window.frames[mod_digitize_target]);
-	canvas[mod_digitize_target].setStroke(3);
-function drawSnappingArea (centerX,centerY,radius,size){
-	canvas[mod_digitize_target].setColor("#ff0000");
-	canvas[mod_digitize_target].drawEllipse(centerX-(size/2)*radius,centerY-(size/2)*radius,size*radius,size*radius);
-	canvas[mod_digitize_target].paint();
-function storeSnappingCoordinates(){
-	snappingCoordinates = new Array();
-	// copy coordinates of other geometries in another array
-	var im = -1;
-	var cnt = 0;
-	for (var i = 0; i < D.length ; i++){
-		for (var j = 0 ; j < D[i]['geometry'].length ; j++){
-			for (var k = 0 ; k < D[i]['geometry'][j]['x'].length ; k++){
-				var pos = parent.makeRealWorld2mapPos(mod_digitize_target, D[i]['geometry'][j]['x'][k], D[i]['geometry'][j]['y'][k]);
-				// snap only if the two points have different coordinates
-				if (basepointDragActive == false || basepointDragActive == true && (D[i]['geometry'][j]['x'][k] != D[basepointMemberIndex]['geometry'][basepointGeometryIndex]['x'][basepointPointIndex] || D[i]['geometry'][j]['y'][k] != D[basepointMemberIndex]['geometry'][basepointGeometryIndex]['y'][basepointPointIndex])){
-					snappingCoordinates[cnt] = new Array();
-					snappingCoordinates[cnt]['map_x'] = pos[0];
-					snappingCoordinates[cnt]['map_y'] = pos[1];
-					snappingCoordinates[cnt]['member'] = i;
-					snappingCoordinates[cnt]['geometry'] = j;
-					snappingCoordinates[cnt]['point'] = k;
-					cnt++;
-	return false;
-function checkSnapped (basepointDragEndX, basepointDragEndY, defaultMouseCursor){
-	var minDist = false;
-	var min_i = -1;
-	for (var i = 0 ; i < snappingCoordinates.length ; i++){
-		var aDist = dist(basepointDragEndX, basepointDragEndY, snappingCoordinates[i]['map_x'], snappingCoordinates[i]['map_y']);
-		if (aDist < snappingTolerance){
-			if (minDist == false || aDist < minDist){
-				minDist = aDist;
-				snappedMember = snappingCoordinates[i]['member'];
-				snappedGeometry = snappingCoordinates[i]['geometry'];
-				snappedPoint = snappingCoordinates[i]['point'];
-				min_i = i;
+function selectBasepoint(e){
+	if(basepointDragActive == false && mod_digitizeEvent == button_move){
+		basepointDragActive = true;
+		s.store(d, mod_digitizeEvent, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
+		basepointObject.onmouseup = releaseBasepoint;
+		basepointObject.onmousemove = dragBasepoint;
-	if (minDist == false || minDist > snappingTolerance){
-		snapped = false;
-	else{
-		snapped = true;
-		checkCanvasTag();
-		cleanCanvas();
-		drawSnappingArea(snappingCoordinates[min_i]['map_x'], snappingCoordinates[min_i]['map_y'], snappingTolerance, 3);
+function dragBasepoint(e){
+	if(basepointDragActive){
+		var res = s.check(currentPos);
-	if (basepointObject != false){
-		if (snapped == true){
-			basepointObject.style.cursor = 'crosshair';
+		// replace basepoint by transparent blob
+		basepointObject.style.width = mod_digitize_width;
+		basepointObject.style.height = mod_digitize_height;
+		basepointObject.style.left = 0;
+		basepointObject.style.top = 0;
+		if (parent.ie) {
+			// ie cannot handle backgroundColor = 'transparent'
+			basepointObject.style.background = "url(/../img/button_digitize/trans.png)";
 		else{
-			basepointObject.style.cursor = defaultMouseCursor;
-		if (defaultMouseCursor == 'move'){
-			// replace basepoint by transparent blob
-			basepointObject.style.width = mod_digitize_width;
-			basepointObject.style.height = mod_digitize_height;
-			basepointObject.style.left = 0;
-			basepointObject.style.top = 0;
-			if (parent.ie){
-				// ie cannot handle backgroundColor = 'transparent'
-				basepointObject.style.background = "url(/../img/button_digitize/trans.png)";
-			else{
-				basepointObject.style.backgroundColor = 'transparent';
+			basepointObject.style.backgroundColor = 'transparent';
+function releaseBasepoint(e){
+	basepointDragActive = false;
+	var basepointDragEnd = new Point(parent.clickX, parent.clickY);
+	basepointObject.onmousedown = null;
+	var p = parent.makeClickPos2RealWorldPos(mod_digitize_target, basepointDragEnd.x, basepointDragEnd.y);
-function mod_digitize_go(e){
-	parent.mb_registerGML(mod_digitize_target,D);
-	parent.document.getElementById(mod_digitize_elName).style.visibility = 'visible';
-	// ie workaround
-	if (e == undefined){
-		e = parent.frames[mod_digitize_target].event;
+	var oldPoint = cloneObject(d.getPoint(i,j,k));
+		var snappedPoint = cloneObject(s.getSnappedPoint(d));
+		d.updateAllPointsLike(oldPoint, snappedPoint);
+		s.clean();
-	if(e){
-		// track mouse position
-		parent.mb_getMousePos(e, mod_digitize_target);
-		checkSnapped(parent.clickX, parent.clickY, 'default');
+	else {
+		var newPoint = new Point(p[0],p[1]);
+		d.updateAllPointsLike(oldPoint, newPoint);
+	basepointMemberIndex = null;
+	basepointGeometryIndex = null;
+	basepointPointIndex = null;
-	el.onmousedown = mod_digitize_start;
-	//el.onmousemove = mod_digitize_run;
-	mod_digitize_width = parent.mb_mapObj[ind].width;
-	mod_digitize_height = parent.mb_mapObj[ind].height;
-	mod_digitize_epsg = parent.mb_mapObj[ind].epsg;
+// --- basepoint handling (end) -----------------------------------------------------------------------------------------
-function mod_digitize_timeout(){
-	//isOn = false;
-	//parent.document.getElementById(mod_digitize_elName).style.visibility = 'hidden';
-	el.onmousedown = null;
-	el.onmouseup = null;
-	el.onmousemove = null;
-	//drawDashedLine();
+// --- registered functions (begin) ---------------------------------------------------------------------------------------
+function registerDigitizePreFunctions(stringFunction){
+	mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
-function registerGeometry(type){
-	// a new geometry will be inserted
-	if (currentMemberIndex == -1){
-		currentMemberIndex = D.length;
-		// generates a new member
-		D[currentMemberIndex] = new Array();
-		D[currentMemberIndex]['geometry'] = new Array();
-		D[currentMemberIndex]['element'] = new Array();
-		D[currentMemberIndex]['wfs_conf'] = -1;
-		D[currentMemberIndex]['geomtype'] = type.id;
-		// attach a new geometry
-		var geomInd = D[currentMemberIndex]['geometry'].length;
-		D[currentMemberIndex]['geometry'][geomInd] = new Array();
-		D[currentMemberIndex]['geometry'][geomInd]['x'] = new Array();
-		D[currentMemberIndex]['geometry'][geomInd]['y'] = new Array();
-		D[currentMemberIndex]['geometry'][geomInd]['complete'] = false;
-		currentGeometryIndex = 0;
+function registerDigitizeSubFunctions(stringFunction){
+	mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
+function executeDigitizeSubFunctions(){
+	for(var i=0; i<mod_digitizeSubFunctions.length; i++){
+		eval(mod_digitizeSubFunctions[i]);
-	// a geometry will be added to an existing geometry
-	else{
-		// FIXME: check if geometry types match
-		currentGeometryIndex = geomInd;
+function executeDigitizePreFunctions(){
+	for(var i=0; i<mod_digitizePreFunctions.length; i++){
+		eval(mod_digitizePreFunctions[i]);
-function mod_digitize_start(e){
-	isOn = true;
-	if (currentMemberIndex != -1){
-		// select the last geometry of the current member
-		var geomInd = D[currentMemberIndex]['geometry'].length - 1;
-		// check if a proper geometry is selected
-		if(D[currentMemberIndex]['geometry'][geomInd]['complete'] == true || (D.length == 0)){
-			if (activeButton != null){
-				alert("No geometry selected!");
-			return true;
-		// get the mouse position and calculate real world position
-			cleanCanvas();
-			var realWorldPos = new Array();
-			realWorldPos[0] = D[snappedMember]['geometry'][snappedGeometry]['x'][snappedPoint];
-			realWorldPos[1] = D[snappedMember]['geometry'][snappedGeometry]['y'][snappedPoint];
-		else{
-			parent.mb_getMousePos(e,mod_digitize_target);
-			var realWorldPos = parent.makeClickPos2RealWorldPos(mod_digitize_target,parent.clickX,parent.clickY);
-		snapped = false;
-		if (D[currentMemberIndex]['geomtype'].toLowerCase() == 'polygon'
-		&& D[currentMemberIndex]['geometry'][geomInd]['x'].length > 1
-		&& D[currentMemberIndex]['geometry'][geomInd]['x'][0] == realWorldPos[0]
-		&& D[currentMemberIndex]['geometry'][geomInd]['y'][0] == realWorldPos[1]){
-			// close the polygon
-			parent.mb_disableThisButton('Polygon');
-		else{
-			// set the calculated real world position as point of the geometry
-			xInd = D[currentMemberIndex]['geometry'][geomInd]['x'].length;
-			yInd = D[currentMemberIndex]['geometry'][geomInd]['y'].length;
-			D[currentMemberIndex]['geometry'][geomInd]['x'][xInd] = realWorldPos[0];
-			D[currentMemberIndex]['geometry'][geomInd]['y'][yInd] = realWorldPos[1];
-			// if the current geometry is a point, attach a label to it
-			if(D[currentMemberIndex]['geomtype'].toLowerCase() == 'point'){
-				parent.mb_disableThisButton('Point');
-			// add first point of polygon to snapping list (if three points have been inserted).
-			&& D[currentMemberIndex]['geometry'][geomInd]['x'].length == 3){
-				var tempInd = snappingCoordinates.length;
-				var pos = parent.makeRealWorld2mapPos(mod_digitize_target, D[currentMemberIndex]['geometry'][geomInd]['x'][0], D[currentMemberIndex]['geometry'][geomInd]['y'][0]);
-				snappingCoordinates[tempInd] = new Array();
-				snappingCoordinates[tempInd]['map_x'] = pos[0];
-				snappingCoordinates[tempInd]['map_y'] = pos[1];
-				snappingCoordinates[tempInd]['member'] = currentMemberIndex;
-				snappingCoordinates[tempInd]['geometry'] = geomInd;
-				snappingCoordinates[tempInd]['point'] = 0;
-		drawDashedLine();
+function registerFunctions(){
+	mod_digitizePreFunctions = new Array();
+	mod_digitizeSubFunctions = new Array();
+	registerDigitizePreFunctions("updateExtent()");
+	registerDigitizePreFunctions("drawDashedLine()");
+	registerDigitizeSubFunctions("updateListOfGeometries()");
+	registerDigitizeSubFunctions("drawDashedLine()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].setStyleForTargetFrame()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].checkDigitizeTag()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseSnapping()");
+	parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
+function checkDigitizeTag(){
+	var attributes = new Array();
+	attributes[0] = new Array();
+	attributes[0][0] = "style";
+	attributes[0][1] = "position:absolute; top:0px; left:0px; z-index:26; font-size:10px";
+	node = parent.mb_checkTag(mod_digitize_target, "div", "digitize", "body", attributes);
+	if (node == false) {
+		alert("Fatal error: Element id 'digitize' is already taken!");
-	return true;
-// finishes a geometry by labelling it complete.
-// if no coordinates have been added, the geometry is discarded.
-// when a polygon is built and the polygon button is clicked again, the
-// polygon will be closed by connecting the last to the first point.
-// Actually, the first point is stored twice at index '0' and index 'length'
-function closeGeometry(obj_id){
-	var i = currentMemberIndex;
-	var j = currentGeometryIndex;
-	if(!isOn){
-		return;
+function setStyleForTargetFrame(){
+	var cssLink = parent.window.frames[mod_digitize_target].document.createElement("link");
+	cssLink.setAttribute("href", cssUrl);
+	cssLink.setAttribute("type", "text/css");
+	cssLink.setAttribute("rel", "stylesheet");
+	var cssTmp = parent.window.frames[mod_digitize_target].document.getElementsByTagName("head")[0];
+	cssTmp.appendChild(cssLink);
-	D[i]['geometry'][j]['complete'] = true;
-	var tmpLength = D[i]['geometry'][j]['x'].length;
-	// if no geometries have been inserted, delete the geometry or member
-	if (tmpLength == 0){
-		if (j == 0){
-			D.length--;
-		else{
-			D[i]['geometry'].length--;
+function initialiseSnapping(){
+//	try {if(snappingTolerance){}}catch(e) {var snappingTolerance;}
+//	try {if(snappingColor){}}catch(e) {var snappingColor;}
+	s = new Snapping(mod_digitize_target, snappingTolerance, snappingColor, true);
+// --- registered functions (end) -----------------------------------------------------------------------------------------
+// --- button handling (begin) --------------------------------------------------------------------------------------------
+function displayButtons(){
+//	try {if(geomList_x){}}catch(e) {var geomList_x = 10;}
+//	try {if(geomList_y){}}catch(e) {var geomList_y = 10;}
+//	try {if(buttonDig_id.length){}}catch(e) {var buttonDig_id = new Array();alert("exception: no digitisation buttons found in element vars.")}
+	document.getElementById("listOfGeometries").setAttribute("style", "position:absolute; top:"+geomList_y+"; left:"+geomList_x+";");
+	for (var i = 0 ; i < buttonDig_id.length ; i ++) {
+		if (parseInt(buttonDig_on[i])==1) {
+			var divTag = document.createElement("div");
+			divTag.setAttribute("id", "div_" + buttonDig_id[i]);
+			divTag.setAttribute("style", "position:absolute; top:"+buttonDig_y[i]+"; left:"+buttonDig_x[i]+";");
+			document.getElementById("digButtons").appendChild(divTag);
+			var tagContent = "<img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_titleUp[i]+"\" src=\""+buttonDig_srcUp[i]+"\">";
+			parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
-	if (obj_id == "Polygon"){
-		if (tmpLength > 0){
-			D[i]['geometry'][j]['x'][tmpLength] = D[i]['geometry'][j]['x'][0];
-			D[i]['geometry'][j]['y'][tmpLength] = D[i]['geometry'][j]['y'][0];
+function initDigButton(ind, pos){
+	parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
+	parent.mb_button[ind].img_over = buttonDig_srcUp[pos];
+	parent.mb_button[ind].img_on = buttonDig_srcDown[pos];
+	parent.mb_button[ind].img_off = buttonDig_srcUp[pos];
+	parent.mb_button[ind].title_on = buttonDig_titleUp[pos];
+	parent.mb_button[ind].title_off = buttonDig_titleDown[pos];
+	parent.mb_button[ind].status = 0;
+	parent.mb_button[ind].elName = buttonDig_id[pos];
+	parent.mb_button[ind].fName = "";
+	parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
+	parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
+function digitizeEnable(obj) {
+	if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
+		mod_digitizeEvent = obj.id;
+	else if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
+		obj.title = obj.title_off;
+		if (obj.id == button_point) {
+			d.addMember(geomTypePoint);
+			d.get(-1).addGeometry();
+		else if (obj.id == button_polygon) {
+			d.addMember(geomTypePolygon);
+		else if (obj.id == button_line) {
+			d.addMember(geomTypeLine);
+		el.onmousemove = mod_digitize_go;
-	drawDashedLine();
-function calculateDashes(pos0, pos1){
-	// pos0 is leftmost point
-	if (pos0[0] > pos1[0]){
-		var pos_temp = new Array();
-		pos_temp = pos0;
-		pos0 = pos1;
-		pos1 = pos_temp;
+function digitizeDisable(obj) {
+	if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
+		obj.title = obj.title_on;
+		d.close();
-	var p = pos0;
-	var q = pos1;
+// --- button handling (end) ----------------------------------------------------------------------------------------------
-	var m;
-	var draw = true;
+// --- display (begin) -----------------------------------------------------------------------------------------
+function updateExtent() {
+	var anInd = parent.getMapObjIndexByName(mod_digitize_target);
+	mod_digitize_width = parent.mb_mapObj[anInd].width;
+	mod_digitize_height = parent.mb_mapObj[anInd].height;
+	mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
+function calculateActualDash(p0, p1, width, height) {
+	// p0 is leftmost point
+	if (p0.x > p1.x) {var p_temp = p0; p0 = p1; p1 = p_temp; p_temp = null;}
+	var p = p0; var q = p1; var m; var draw = true;
 	// if line is not vertical
-	if (pos1[0] != pos0[0]){
+	if (p1.x != p0.x) {
 		// calculate slope
-		m = -(pos1[1]-pos0[1])/(pos1[0]-pos0[0]);
+		m = -(p1.y-p0.y)/(p1.x-p0.x);
 		// check if p is left of the right vertical of the screen && the line is not above or below the screen
-		if (pos0[0] < mod_digitize_width && pos1[0] > 0
-		&& !(pos0[1] < 0 && pos1[1] < 0) && !(pos0[1] > mod_digitize_height && pos1[1] > mod_digitize_height)){
+		if (p0.x < width && p1.x > 0 && !(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height) ) {
 			// if p is left of the screen
-			if (pos0[0] < 0){
+			if (p0.x < 0) {
 				//calculate intersection of line with left vertical of screen
-				var iy = pos0[1] - m*(0-pos0[0]);
+				var iy = p0.y - m*(0-p0.x);
 				// if intersection is visible
-				if (iy > 0 && iy < mod_digitize_height){
-					p[0] = 0;
-					p[1] = iy;
+				if (iy > 0 && iy < height) {p = new Point(0, iy);}
 				// if intersection is below the screen
-				else if (iy > mod_digitize_height){
+				else if (iy > height) {
 					// calculate intersection with lower horizontal
-				    var ix = pos0[0]+((pos0[1] - mod_digitize_height)/m);
-				    if (ix > 0 && ix < mod_digitize_width){
-					   	p[0] = ix;
-					   	p[1] = mod_digitize_height;
-					else{
-						draw = false;
+				    var ix = p0.x+((p0.y - height)/m);
+				    if (ix > 0 && ix < width) {p = new Point(ix, height);}
+					else draw = false;
 				// if intersection is above the screen
-				else if (iy < 0){
+				else if (iy < 0) {
 					// calculate intersection with upper horizontal
-				    var ix = pos0[0]+(pos0[1]/m);
-					   	p[0] = ix;
-					   	p[1] = 0;
-					else{
-						draw = false;
+				    var ix = p0.x+(p0.y/m);
+				    if (ix > 0 && ix < width) {p = new Point(ix, 0);}
-				else{
-					draw = false;
-			else if (pos0[1] >= 0 && pos0[1] <= mod_digitize_height){
-				p[0] = pos0[0];
-				p[1] = pos0[1];
-			else if (pos0[1] < 0){
+			else if (p0.y >= 0 && p0.y <= height) {p = p0;}
+			else if (p0.y < 0) {
-				   	p[0] = ix;
-				   	p[1] = 0;
-				else{
-					draw = false;
-			else if (pos0[1] > mod_digitize_height && m > 0){
+			else if (p0.y > height && m > 0) {
-			    if (ix > 0 && ix < mod_digitize_width) {
-				   	p[0] = ix;
-				else{
-					draw = false;
-			else{
-				draw = false;
 			// calculate q coordinates
-			if (draw == true){
+			if (draw == true) {
 				// q is right of the screen
-				if (pos1[0] > mod_digitize_width){
+				if (p1.x > width) {
 					// calculate intersection with right vertical of the screen
-					var iy = pos1[1] - m*(mod_digitize_width-pos1[0]);
+					var iy = p1.y - m*(width-p1.x);
-						q[0] = mod_digitize_width;
-						q[1] = iy;
-					else if (iy < 0){
+					if (iy > 0 && iy < height) {q = new Point(width, iy);}
-						   	q[0] = ix;
-						   	q[1] = 0;
-						else{
-							draw = false;
+					    if (ix > 0 && ix < width) {q = new Point(ix, 0);}
-						   	q[0] = ix;
-						   	q[1] = mod_digitize_height;
-						else{
-							draw = false;
+					    if (ix > 0 && ix < width) {q = new Point(ix, height);}
-					else{
-						draw = false;
-				else if (pos1[1] >= 0 && pos1[1] <= mod_digitize_height){
-					q[0] = pos1[0];
-					q[1] = pos1[1];
-				else if (pos1[1] < 0){
+				else if (p1.y >= 0 && p1.y <= height) {q = p1;}
+				else if (p1.y < 0) {
-					var ix = pos1[0]+(pos1[1]/m);
-					   	q[0] = ix;
-					   	q[1] = 0;
-					else{
-						draw = false;
+				    var ix = p1.x+(p1.y/m);
-				else if (pos1[1] > mod_digitize_height){
+				else if (p1.y > height) {
-				    var ix = pos1[0]+((pos1[1]- mod_digitize_height)/m) ;
-					   	q[0] = ix;
-					else{
-						draw = false;
+				    var ix = p1.x+((p1.y- height)/m) ;
-		else{
-			draw = false;
 	// the line is vertical
-	else{
-		// x-Coordinates remain
-		p[0] = pos0[0];
-		q[0] = pos0[0];
+	else {
 		// check if line is not above or below the screen
-		if (!(pos0[1] < 0 && pos1[1] < 0) && !(pos0[1] > mod_digitize_height && pos1[1] > mod_digitize_height)){
-			if (pos0[1] < 0){
-				p[1] = 0;
-			else if (pos0[1] > mod_digitize_height){
-			else{
-				p[1] = pos0[1];
-			if (pos1[1] < 0){
-				q[1] = 0;
-			else{
-				q[1] = pos1[1];
-		else{
-			draw = false;
+		if (!(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height)) {
+			if (p0.y < 0) {p = new Point(p0.x, 0);}
+			else if (p0.y > height) {p = new Point(p0.x, height);}
+			else p = p0;
+			if (p1.y < 0) {q = new Point(p0.x, 0);}
+			else if (p1.y > height) {q = new Point(p0.x, height);}
+			else q = p1;
 		var points = new Array();
-		points[0] = Math.round(q[0]);
-		points[1] = Math.round(q[1]);
-		points[2] = Math.round(p[0]);
-		points[3] = Math.round(p[1]);
+		points[0] = new Point(Math.round(q.x), Math.round(q.y));
+		points[1] = new Point(Math.round(p.x), Math.round(p.y));
 		return points;
-	else{
-		return false;
+	else return false;
 function drawDashedLine(){
 	var smP = "";
 	smP += "<div class='t_img'>";
 	smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
-	smP += "<img   src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
-	// *all* members will be painted
-	for(var i=0; i<D.length; i++){
-		// paint all geometries of member i
-		for(var j=0; j<D[i]['geometry'].length; j++){
-			// paint the basepoints
-			for(var k=0; k<D[i]['geometry'][j]['x'].length; k++){
-				// calculate screen position from real world coordinates
-				var pos = parent.makeRealWorld2mapPos(mod_digitize_target,D[i]['geometry'][j]['x'][k],D[i]['geometry'][j]['y'][k]);
-				// if this geometry is a point
-				if(D[i]['geomtype'].toLowerCase() == "point"){
-					// smP += "<div class='label' style='top:"+(pos[1]-6)+"px;left:"+(pos[0])+"px;z-index:50;'>"+D[i]['label']+"</div>";
+	smP += "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
-				smP += "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:50;'";
-				if(j==0 && D[i]['geomtype'].toLowerCase() == 'polygon' && D[i]['geometry'][j]['complete'] == false){
+	for(var i=0; i<d.count(); i++){
+		for(var j=0; j<d.get(i).count(); j++){
+			for(var k = 0; k < d.getGeometry(i,j).count(); k++){
+				var pos = parent.makeRealWorld2mapPos(mod_digitize_target,d.getPoint(i,j,k).x,d.getPoint(i,j,k).y);
+				if (!d.getGeometry(i,j).isComplete() &&
+					( (k == 0 && d.get(i).geomtype == geomTypePolygon) || (k == d.getGeometry(i,j).count()-1 && d.get(i).geomtype == geomTypeLine))) {
+					smP += "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:50;background-color:"+linepointColor+"'";
+				else {
+					smP += "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:50;'";
+				if(j==0 && d.get(i).geomtype == geomTypePolygon && d.getGeometry(i,j).complete == false){
 					smP += " title='to close polygon, release the polygon button on the left' ";
-				if(isOn){
+				if(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete) {
 					smP += " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
 				smP += "></div>";
-			// paint the lines between basepoints
-			for(var k = 1; k < D[i]['geometry'][j]['x'].length; k++){
+			for(var k = 1; k < d.getGeometry(i,j).count(); k++){
+				var p0 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k));
+				var p1 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k-1));
-				var pos0 = parent.makeRealWorld2mapPos(mod_digitize_target, D[i]['geometry'][j]['x'][k]  , D[i]['geometry'][j]['y'][k]);
-				var pos1 = parent.makeRealWorld2mapPos(mod_digitize_target, D[i]['geometry'][j]['x'][k-1], D[i]['geometry'][j]['y'][k-1]);
-				points = calculateDashes(pos0, pos1);
-				if (points != false){
-					smP += evaluateDashes(points[0], points[1], points[2], points[3], i, j, k);
+				points = calculateActualDash(p0, p1, mod_digitize_width, mod_digitize_height);
+				if (points != false) {
+					smP += evaluateDashes(points[0], points[1], i, j, k);
 	parent.writeTag(mod_digitize_target,"digitize",smP);
-	updateListOfGeometries();
-function evaluateDashes(startX, startY, endX, endY, memberIndex, geomIndex, pointIndex){
+function evaluateDashes(start, end, memberIndex, geomIndex, pointIndex){
 	var str_dashedLine = "";
-	var deltaX = endX - startX;
-	var deltaY = endY - startY;
-	// s = distance between two linepoints
-	var s = 10;
-	var vecLength = dist(startX, startY, endX, endY);
-	var n = Math.round(vecLength/s);
-	var stepX =  deltaX/n;
-	var stepY =  deltaY/n;
+	var delta = new Point(end.x - start.x, end.y - start.y);
+	var vecLength = start.dist(end);
+	var n = Math.round(vecLength/dotDistance);
+	var step = new Point(delta.x/n, delta.y/n);
 	for(var i=1; i<n; i++){
-		var x = Math.round(startX + i * stepX) - 2;
-		var y = Math.round(startY + i * stepY) - 2;
+		var x = Math.round(start.x + i * step.x) - 2;
+		var y = Math.round(start.y + i * step.y) - 2;
 		if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
-			str_dashedLine += "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:50;' ";
-			if(isOn){
+			if (memberIndex == d.count()-1 && !d.getGeometry(-1,-1).isComplete()) {
+				str_dashedLine += "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:50;background-color:"+linepointColor+"' ";
+			else {
+				str_dashedLine += "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:50;' ";
+			if(mod_digitizeEvent == button_insert) {
 				str_dashedLine += "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+pointIndex+")'>";
 			str_dashedLine += "</div>";
@@ -834,443 +627,125 @@
 	return str_dashedLine;
-function handleBasepoint(Obj,memberIndex,geometryIndex,pointIndex){
-	if(!isOn){
-		return false;
-	// set the global variables that will be used in deleteBasepoint etc.
-	basepointObject = Obj;
-	basepointMemberIndex = memberIndex;
-	basepointGeometryIndex = geometryIndex;
-	basepointPointIndex = pointIndex;
-	if(mod_digitizeEvent == "dragBasePoint" && activeButton == 'dragBasePoint'){
-		mod_digitize_timeout();
-		basepointObject.style.cursor = 'move';
-		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].selectBasepoint;
-	if(mod_digitizeEvent == false && D[memberIndex]['geomtype'].toLowerCase() == 'polygon' && D[memberIndex]['geometry'][geometryIndex].complete == false){
-		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].closeGeometry("Polygon");
-	if(mod_digitizeEvent == "delBasePoint" && activeButton == 'delBasePoint'){
-		basepointObject.onmousedown = parent.window.frames[mod_digitize_elName].deleteBasepoint;
-function deleteBasepoint(e){
-	var i = basepointMemberIndex;
-	var j = basepointGeometryIndex;
-	var k = basepointPointIndex;
-	var xCoord = D[i]['geometry'][j]['x'][k];
-	var yCoord = D[i]['geometry'][j]['y'][k];
-	var deleted = false;
-	while (deleted == false){
-		var continueFor = true;
-		deleted = true;
-		//find points of other geometries with the same coordinates and delete them as well
-		for (var l = 0 ; l < D.length && continueFor == true; l ++){
-			for (var m = 0; m < D[l]['geometry'].length && continueFor == true; m++){
-				for (var n = 0; n < D[l]['geometry'][m]['x'].length && continueFor == true ; n++){
-					if (D[l]['geometry'][m]['x'][n] == xCoord && D[l]['geometry'][m]['y'][n] == yCoord){
-						deletePoint(l,m,n);
-						continueFor = false;
-						deleted = false;
+function updateListOfGeometries(){
+	var listOfGeom = "<table>\n";
+	for (var i = 0 ; i < d.count(); i ++) {
+		listOfGeom += "\t<tr>\n\t\t<td>\n";
+		listOfGeom += "\t\t\t<img src = '../img/button_digitize/geomInfo.png' title='WFS conf' onclick='showWfs("+i+")'>\n";
+		listOfGeom += "\t\t</td>\n\t\t<td>\n";
+		listOfGeom += "\t\t\t<img src = '../img/button_digitize/geomRemove.png' title='delete this " + d.get(i).geomtype + "' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>\n";
+		listOfGeom += "\t\t</td>\n\t\t<td style = 'color:blue;font-size:12px'>\n";
+		listOfGeom += "\t\t\t<div onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"));' ";
+		listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"))' ";
-function deletePoint(i,j,k){
-	// the last point is being deleted...
-	if ( (k == 0 || (D[i]['geometry'][j]['x'].length - k) == 1) && D[i]['geomtype'].toLowerCase() == 'polygon'){
-		// if the last basepoint of a polygon is being deleted,
-		// the first basepoint is now set to be the last but one as well,
-		// in order to close the polygon
-		// Shorten the array by one
-		D[i]['geometry'][j]['x'].length = D[i]['geometry'][j]['x'].length - 1;
-		D[i]['geometry'][j]['y'].length = D[i]['geometry'][j]['y'].length - 1;
-		// if only one point is left (which has been stored twice), remove it as well
-		if (D[i]['geometry'][j]['x'].length == 1){
-			D[i]['geometry'][j]['x'].length = 0;
-			D[i]['geometry'][j]['y'].length = 0;
+		if (d.get(i).wfs_conf != -1) {
+			listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"));' ";
-		// point that will be deleted is not the only point of the geometry
 		else{
-			// place a copy of the last point at index 0
-			var tmpIndex = D[i]['geometry'][j]['x'].length - 1;
-			D[i]['geometry'][j]['x'][0] = D[i]['geometry'][j]['x'][tmpIndex];
-			D[i]['geometry'][j]['y'][0] = D[i]['geometry'][j]['y'][tmpIndex];
-	// a point that is *not* the last point of a geometry is being deleted
-	else{
-		// move basepoints behind deleted basepoints up by one...
-		for(var z= k; z<D[i]['geometry'][j]['x'].length-1; z++){
-			D[i]['geometry'][j]['x'][z] = D[i]['geometry'][j]['x'][z+1];
-			D[i]['geometry'][j]['y'][z] = D[i]['geometry'][j]['y'][z+1];
-		// ...and adjust length of the array
-	// if all basepoints of this geometry have been deleted...
-	if (D[i]['geometry'][j]['x'].length == 0){
-		deleteGeometry(i, j);
-	else{
-		drawDashedLine();
-		//resetButtonsIfNoMembersLeft();
-function deleteGeometry (indexMember, indexGeometry){
-	var i = indexMember;
-	var j = indexGeometry;
-	// check whether the deleted geometry is the only geometry of the member...
-	if (D[i]['geometry'].length == 1){
-		deleteMember(i);
-	// ...if not, move other geometries one spot up
-	else{
-		var tmpLength = D[i]['geometry'].length - 1;
-		for (var z = j; z < tmpLength ; z ++){
-			D[i]['geometry'][z] = D[i]['geometry'][z+1];
-			D[i]['element'][z] = D[i]['element'][z+1];
-		D[i]['geometry'].length -= 1;
-		drawDashedLine();
-		resetButtonsIfNoMembersLeft();
-function deleteMember(index){
-	// delete geometry itself...
-	for(var z = index ; z < D.length - 1; z++){
-		D[z] = D[z+1];
-	// ... and adjust length of geometry array
-	D.length -= 1;
-	drawDashedLine();
-function convertLinepointToBasepoint(obj, memberIndex, geomIndex, pointIndex){
-	if(!isOn){
-		return false;
-	if(mod_digitizeEvent == "setBasePoint" && activeButton == 'setBasePoint'){
-		obj.style.cursor = 'crosshair';
-		obj.onclick = insertBasepoint;
-		basepointObject = obj;
-		basepointGeometryIndex = geomIndex;
-function insertBasepoint(e){
-	var pos = parent.makeClickPos2RealWorldPos(mod_digitize_target,parent.clickX, parent.clickY);
-	for(var z = D[i]['geometry'][j]['x'].length; z > k; z--){
-		D[i]['geometry'][j]['x'][z] = D[i]['geometry'][j]['x'][z-1];
-		D[i]['geometry'][j]['y'][z] = D[i]['geometry'][j]['y'][z-1];
-	D[i]['geometry'][j]['x'][k] = pos[0];
-	D[i]['geometry'][j]['y'][k] = pos[1];
-	drawDashedLine();
-function selectBasepoint(e){
-	if(basepointDragActive == false && mod_digitizeEvent == "dragBasePoint"){
-		basepointDragActive = true;
-		basepointObject.onmouseup = releaseBasepoint;
-		basepointObject.onmousemove = dragBasepoint;
-function dist(startX, startY, endX, endY){
-	return Math.sqrt(Math.pow(deltaY,2) + Math.pow(deltaX,2)) ;
-function dragBasepoint(e){
-	if(basepointDragActive){
-		checkSnapped(parent.clickX, parent.clickY, 'move');
-function removeDuplicates(i, j){
-	var length1 = D[i]['geometry'][j]['x'].length;
-	for (var k = 2; k < length1 && continueFor == true ; k++){
-		if (D[i]['geometry'][j]['x'][k] == D[i]['geometry'][j]['x'][k-1] && D[i]['geometry'][j]['y'][k] == D[i]['geometry'][j]['y'][k-1]){
-			deletePoint(i,j,k-1);
-function releaseBasepoint(e){
-	basepointDragActive = false;
-	basepointDragEndX = parent.clickX;
-	basepointDragEndY = parent.clickY;
-	basepointObject.onmousedown = null;
-	var pos = parent.makeClickPos2RealWorldPos(mod_digitize_target, basepointDragEndX, basepointDragEndY);
-		cleanCanvas();
-		pos[0] = D[snappedMember]['geometry'][snappedGeometry]['x'][snappedPoint];
-		pos[1] = D[snappedMember]['geometry'][snappedGeometry]['y'][snappedPoint];
-	if ((k == D[i]['geometry'][j]['x'].length - 1 || k == 0) && D[i]['geometry'][j]['complete'] == true && D[i]['geomtype'].toLowerCase() == 'polygon'){
-		D[i]['geometry'][j]['x'][0] = pos[0];
-		D[i]['geometry'][j]['y'][0] = pos[1];
-	// check if there are points in other geometries with the same coordinates
-	for (var l = 0; l < D.length ; l++){
-		for (var m = 0 ; m < D[l]['geometry'].length ; m++){
-			for (n = 0 ; n < D[l]['geometry'][m]['x'].length ; n++){
-				// this line would enable merging of snapped points of the same geometry
-				// if ((l != i || m != j) && D[i]['geometry'][j]['x'][k] == D[l]['geometry'][m]['x'][n] && D[i]['geometry'][j]['y'][k] == D[l]['geometry'][m]['y'][n]){
-				if (D[i]['geometry'][j]['x'][k] == D[l]['geometry'][m]['x'][n] && D[i]['geometry'][j]['y'][k] == D[l]['geometry'][m]['y'][n]){
-					D[l]['geometry'][m]['x'][n] = pos[0];
-					D[l]['geometry'][m]['y'][n] = pos[1];
-						removeDuplicates(l,m);
-			removeDuplicates(i,j);
+			listOfGeom += " onclick='parent.zoom(mod_digitize_target,\"true\", 1.0, " + d.get(i).getCenter().x + ", " + d.get(i).getCenter().y + ");' ";
-		snapped = false;
-		drawDashedLine();
-function cloneObject(someArray){
-	var a = someArray;
-	var z = new Array();
+		var geomName = d.get(i).e.getElementValueByName("name");
+		if (!geomName) {geomName = "new";}
+		if (d.get(i).geomtype == geomTypePolygon) {geomName += " (Py)";}
+		else if (d.get(i).geomtype == geomTypeLine) {geomName += " (Li)";}
+		else if (d.get(i).geomtype == geomTypePoint) {geomName += " (Pt)";}
-	for (attr in a){
-		var b = a[attr];
-		if (typeof(b) == "object"){
-			z[attr] = cloneObject(b);
-		else{
-			z[attr] = b;
-	return z;
-function cloneGeometryArray(originalArray){
-	z = cloneObject(originalArray);
-	// add the attribute 'complete' for every geometry
-	for (var i = 0 ; i < originalArray['geometry'].length ; i ++){
-		z['geometry'][i]['complete'] = true;
+		listOfGeom += ">" + geomName +"</div>\t\t</td>\n";
-	   return z;
-function addMember(newMember){
-	var index = D.length;
-	D[index] = new Array();
-	D[index] = cloneGeometryArray(newMember);
-	mod_digitize_go();
-	drawDashedLine();
-function setEvent(obj){
-	mod_digitizeEvent = obj.id;
-function delEvent(){
-	mod_digitizeEvent = false;
-function displayObject(someArray){
-	var str = "";
-	for (attr in a){
-		b = a[attr];
-			str += "<br>" + attr + "<br>";
-			str += displayObject(b);
-		else{
-			str += attr + ": " + b + "<br>";
-	return str;
+	listOfGeom += "</table>\n";
+	parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
+// --- display (end) -----------------------------------------------------------------------------------------
+// returns a form with the elements of a selected wfs
+// (if the original wfs is the selected wfs, the values are set too)
 function buildElementForm(wfsConfIndex, memberIndex){
 	var selMember = memberIndex;
-	// if the selected wfs is not the original wfs,
-	// the form template, updating and deleting are disabled.
-	if (parseInt(D[memberIndex]['wfs_conf']) != parseInt(wfsConfIndex)){
-		memberIndex = -1;
+	if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {memberIndex=-1;}
 	var str = "";
-	// the wfs conf needs to have a gid and a geom, otherwise saving does not work
 	var gid = false;
 	var geom = false;
 	var wfs = wfs_conf[wfsConfIndex];
 	var memEl;
-	if (parseInt(memberIndex) != -1){
-		 memEl = D[memberIndex]['element'];
+	if (parseInt(memberIndex) != -1) {
+		 memEl = d.get(memberIndex).e;
 	// search attribute 'element' in wfsConfArray
-	for (attr in wfs){
-		if (attr == "element"){
+	for (attr in wfs) {
+		if (attr == "element") {
 			str += "<form id='wfs_conf'>\n\t<table>\n";
 			b = wfs[attr];
-			// get the 'element name' of wfsConfArray['element'][i]
-			for (var i = 0 ; i < b.length ; i ++){
+			for (var i = 0 ; i < b.length ; i ++) {
 				var c = b[i];
 				var wfsElementName = c['element_name'];
-				// don't display geoms
-				if (parseInt(c['f_geom']) != 1){
+				if (parseInt(c['f_geom']) != 1) {
-					if (parseInt(wfs['element'][i]['f_gid']) == 1){
+					if (parseInt(wfs['element'][i]['f_gid']) == 1) {
 						gid = wfsElementName;
-					// display the element name and an input row for its value
 					str += "\t\t<tr>\n\t\t\t<td>\n";
 					str += "\t\t\t\t" + wfsElementName + "\n\t\t\t</td>\n\t\t\t<td colspan = 2>\n";
 					str += "\t\t\t\t<input name='" + wfsElementName + "' type='text' size=20 ";
-					// only if the selected wfs is the original wfs!
-						// get the 'element name' of memberArray['element'][j]
-						for (var j = 0 ; j < memEl.length ; j ++){
-							currentElementName = memEl[j]['name'];
-							// if the element is in both objects, display the value as default
-							if (currentElementName == wfsElementName){
-								str += "value = '" + memEl[j]['val'] + "' ";
+						for (var j = 0 ; j < memEl.count() ; j ++) {
+							currentElementName = memEl.getName(j);
+							if (currentElementName == wfsElementName) {
+								str += "value = '" + memEl.getValue(j) + "' ";
-					str += ">\n";
-					str += "\t\t\t</td>\n\t\t</tr>\n";
+					str += ">\n\t\t\t</td>\n\t\t</tr>\n";
-				else{
-					geom = wfsElementName;
+				else geom = wfsElementName;
-			// generating buttons "save", "update", "delete"
-			// a wfs_transaction url is required.
-			if (wfs['wfs_transaction']){
+			if (wfs['wfs_transaction']) {
 				str += "\t\t<tr>\n";
-				// if not all buttons will be generated, the missing columns will be generated afterwards.
 				var colspan = 0;
-				if (geom){
+				if (geom) {
 					str += "\t\t\t<td><input type='button' name='saveButton' value='Save' onclick='window.opener.saveGeom("+selMember+")' /></td>\n";
-				else{
-					colspan++;
-				if (parseInt(memberIndex) != -1 && gid){
-					if (geom){
+				else colspan++;
+				if (parseInt(memberIndex) != -1 && gid) {
+					if (geom) {
 						str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick='window.opener.updateGeom("+selMember+")'/></td>\n";
-					else{
-						colspan++;
+					else colspan++;
 					str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick='window.opener.deleteGeom("+selMember+")'/></td>\n";
-				else{
-					colspan++;
-				if (colspan > 0 && colspan < 3){
+				else colspan++;
+				if (colspan > 0 && colspan < 3) {
 					str += "\t\t\t<td colspan = " + colspan + "></td>\n";
 				str += "\t\t</tr>";
 			str += "\t</table>\n";
-			// str += "<input type='text' name='mb_geom'>";
-			// str += "<input type='text' name='mb_wfs_conf'>";
+//				str += "<input type='text' name='mb_geom'>";
+//				str += "<input type='text' name='mb_wfs_conf'>";
 			str += "</form>\n";
 	return str;
-function showWfs(index){
+// this method opens a new window and displays the attributes in wfs_conf
+function showWfs(index) {
 	wfsWindow = open("", "wfsattributes", "width=300, height=300, resizable, dependent=yes, scrollbars=yes");
 	wfsWindow.document.open("text/html");
 	wfs_conf = parent.get_complete_wfs_conf();
@@ -1281,80 +756,31 @@
 	str += " onChange='document.getElementById(\"elementForm\").innerHTML = window.opener.buildElementForm(this.value , " + index + ")'";
 	str += ">\n\t\t";
-	for (var attr in wfs_conf){
+	for (var attr in wfs_conf) {
 		str += "<option value='" + attr + "'";
 		// if the geometry is already associated with a wfs
-		if (parseInt(D[index]['wfs_conf']) == parseInt(attr)){
+		if (parseInt(d.get(index).wfs_conf) == parseInt(attr)) {
 			str += " selected";
 			defaultIndex = parseInt(attr);
 		str += ">" + wfs_conf[attr]['wfs_conf_abstract'];
 		str += "</option>\n\t\t";
 	str += "</select>\n\t\t</form>\n\t";
 	str += "<div id='elementForm'>\n</div>\n";
 	wfsWindow.document.write(str);
 	wfsWindow.document.close();
-	if (defaultIndex != -1){
+	if (defaultIndex != -1) {
 		wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, index);
-function updateListOfGeometries(){
-	var listOfGeom = "";
-	if (D.length > 0){
-		listOfGeom += "<table>\n";
-		for (var i = 0 ; i < D.length; i ++){
-		listOfGeom += "\t<tr>\n";
-		listOfGeom += "\t\t<td>\n";
-		listOfGeom += "\t\t\t<img src = '../img/button_digitize/geomInfo.png' title='WFS conf' onclick='showWfs("+i+")'>\n";
-		listOfGeom += "\t\t</td>\n";
-		listOfGeom += "\t\t\t<img src = '../img/button_digitize/geomRemove.png' title='delete this " + D[i]['geomtype'] + "' onclick='deleteMember("+i+")'>\n";
-		listOfGeom += "\t\t<td style = 'color:blue'>\n";
-		listOfGeom += "\t\t\t<div onmouseover='parent.mb_wfs_perform(\"over\",D["+i+"])' ";
-		listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",D["+i+"])' ";
-		// if a geometry is a wfs result -> zoom to geometry
-		if (D[i]['wfs_conf'] != -1){
-			listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",D["+i+"]);' ";
-		// ... a geometry has been digitized by hand -> zoom to first point (FIXME: zooming to the entire geometry would be better)
-		else{
-			listOfGeom += " onclick='parent.zoom(mod_digitize_target,\"true\", 1.0, " + D[i]['geometry'][0]['x'][0] + ", " + D[i]['geometry'][0]['y'][0] + ");' ";
-		var geomName = parent.getElementValueByName(D, i, "name");
-		if (!geomName){
-			geomName = "new";
-		var suffix = " ";
-		if (D[i]['geomtype'] == "Polygon"){
-			suffix += "(Py)";
-		else if (D[i]['geomtype'] == "Line"){
-			suffix += "(Li)";
-		if (D[i]['geomtype'] == "Point"){
-			suffix += "(Pt)";
-		listOfGeom += ">" + geomName + suffix +"</div>";
-		listOfGeom += "</table>\n";
-	parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
+function mod_saveGeom() {
+	dwin = window.open("../php/mod_wfs_save.php","dwin","width=300,height=200");
 function saveGeom(m){
@@ -1362,25 +788,19 @@
 	var ind = myform.wfs.selectedIndex;
 	var wfs = myform.wfs.options[ind].value;
 	myform = wfsWindow.document.forms[1];
-	D[m]['wfs_conf'] = wfs;
-	D[m]['element'] = new Array();
-	D[m]['element']['name'] = new Array();
-	D[m]['element']['val'] = new Array();
+	d.get(m).wfs_conf = wfs;
+	d.get(m).e = new Wfs_element();
 	var cnt = 0;
 	for( var i=0; i<myform.length; i++){
 		if(myform.elements[i].type == 'text'){
-			D[m]['element'][cnt] = new Array();
-			D[m]['element'][cnt]['name'] = myform.elements[i].name;
-			D[m]['element'][cnt]['val'] = myform.elements[i].value;
-			cnt++;
+			d.get(m).e.setElement(myform.elements[i].name, myform.elements[i].value);
-	//	alert(wfs_conf[D[m]['wfs_conf']]['wfs_transaction']);
-	var myconf = wfs_conf[D[m]['wfs_conf']];
+	var myconf = wfs_conf[d.get(m).wfs_conf];
 	document.sendForm.url.value = myconf['wfs_transaction'];
 	var str = '<wfs:Transaction version="1.0.0" service="WFS" ';
-	for (var q = 0 ; q < myconf['namespaces'].length ; q++){
+	for (var q = 0 ; q < myconf['namespaces'].length ; q++) {
 		//alert('xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" ');
 		str += 'xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" ';
@@ -1388,11 +808,11 @@
 	str += 'xsi:schemaLocation="http://www.someserver.com/myns http://wms1.ccgis.de/geoserver-1.3-beta4/wfs/getCapabilities?request=describefeaturetype&amp;typename=mapbender_user http://www.opengis.net/wfs../wfs/1.0.0/WFS-transaction.xsd">';
 	str += '<wfs:Insert>';
 	str += '<'+ myconf['featuretype_name']+'>';
-	for(var i=0; i<D[m]['element'].length; i++){
-		if(D[m]['element'][i]['val'] != ""){
-			var tmp = D[m]['element'][i]['name'];
+	for(var i=0; i<d.get(m).e.count(); i++){
+		if(d.get(m).e.getValue(i) != ""){
+			var tmp = d.get(m).e.getName(i);
 			str += '<' + tmp  + '>';
-			str += D[m]['element'][i]['val'];
+			str += d.get(m).e.getValue(i);
 			str += '</' + tmp  + '>';
@@ -1427,8 +847,7 @@
 //		str += '</gml:lineStringMember>';
 //		str += '</gml:MultiLineString>';
-	if(D[m]['geomtype'] == 'Polygon'){
+	if(d.get(m).geomtype == geomTypePolygon){
 		str += '<gml:MultiPolygon srsName="epsg:4326">';
 		str += '<gml:polygonMember>';
 		str += '<gml:Polygon>';
@@ -1436,11 +855,11 @@
 		str += '<gml:LinearRing>';
 		str += '<gml:coordinates>';
-		for(var k=0; k<D[m]['geometry'][0]['x'].length; k++){
+		for(var k=0; k<d.getGeometry(m,0).count(); k++){
 			if(k>0){
 				str += " ";
-			str += D[m]['geometry'][0]['x'][k] + "," + D[m]['geometry'][0]['y'][k];
+			str += d.getPoint(m,0,k).x + "," + d.getPoint(m,0,k).y;
 		str += '</gml:coordinates>';
 		str += '</gml:LinearRing>';
@@ -1453,43 +872,40 @@
 	str += '</'+ myconf['featuretype_name']+'>';
 	str += '</wfs:Insert>';
 	str += '</wfs:Transaction>';
-	document.forms[1].filter.value = str;
-	document.forms[1].submit();
+	document.sendForm.filter.value = str;
+	document.sendForm.submit();
+//	document.forms[1].filter.value = str;
+//	document.forms[1].submit();
 	return false;
 function updateGeom(m){
 	var myid_value;
 	var myform = wfsWindow.document.forms[0];
 	var cnt = 0;
-			if(D[m]['element'][cnt]['name'] == 'gid'){
-				myid_value = D[m]['element'][cnt]['val'];
+			if(d.get(m).e.getName(cnt) == 'gid'){
+				myid_value = d.get(m).e.getValue(cnt);
 			cnt++;
+//	alert(wfs_conf[D[m]['wfs_conf']]['wfs_transaction']);
 	var str = '<wfs:Transaction version="1.0.0" service="WFS" xmlns="http://www.someserver.com/myns" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:wfs="http://www.opengis.net/wfs" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.someserver.com/myns http://wms1.ccgis.de/geoserver-1.3-beta4/wfs/getCapabilities?request=describefeaturetype&amp;typename=mapbender_user http://www.opengis.net/wfs../wfs/1.0.0/WFS-transaction.xsd" xmlns:topp="http://www.someserver.com/topp">';
 	str += '<wfs:Update typeName="'+ myconf['featuretype_name']+'">';
 			str += '<wfs:Property>';
-			str += '<wfs:Name>'+D[m]['element'][i]['name']+'</wfs:Name>';
-			str += '<wfs:Value>'+D[m]['element'][i]['val']+'</wfs:Value>';
+			str += '<wfs:Name>'+d.get(m).e.getName(i)+'</wfs:Name>';
+			str += '<wfs:Value>'+d.get(m).e.getValue(i)+'</wfs:Value>';
 			str += '</wfs:Property>';
@@ -1498,33 +914,32 @@
 			var el_geom = myconf['element'][j]['element_name'];
-	//	str += '<' + el_geom + '>';
-	//	if(dig.D[0].type == 'text'){
-	//		str += '<gml:Point srsName="epsg:4326">';
-	//		str += '<gml:coordinates>';
-	//		str += dig.D[0].x[0] + "," + dig.D[0].y[0];
-	//		str += '</gml:coordinates>';
-	//		str += '</gml:Point>';
-	//	if(dig.D[0].type == 'line'){
-	//		str += '<gml:MultiLineString srsName="epsg:4326">';
-	//		str += '<gml:lineStringMember>';
-	//		str += '<gml:LineString>';
-	//		for(var k=0; k<dig.D[0].x.length; k++){
-	//			if(k>0){
-	//				str += " ";
-	//			str += dig.D[0].x[k] + "," + dig.D[0].y[k];
-	//		str += '</gml:LineString>';
-	//		str += '</gml:lineStringMember>';
-	//		str += '</gml:MultiLineString>';
+//	str += '<' + el_geom + '>';
+//	if(dig.D[0].type == 'text'){
+//		str += '<gml:Point srsName="epsg:4326">';
+//		str += '<gml:coordinates>';
+//		str += dig.D[0].x[0] + "," + dig.D[0].y[0];
+//		str += '</gml:coordinates>';
+//		str += '</gml:Point>';
+//	if(dig.D[0].type == 'line'){
+//		str += '<gml:MultiLineString srsName="epsg:4326">';
+//		str += '<gml:lineStringMember>';
+//		str += '<gml:LineString>';
+//		for(var k=0; k<dig.D[0].x.length; k++){
+//			if(k>0){
+//				str += " ";
+//			str += dig.D[0].x[k] + "," + dig.D[0].y[k];
+//		str += '</gml:LineString>';
+//		str += '</gml:lineStringMember>';
+//		str += '</gml:MultiLineString>';
 		str += '<wfs:Name>' + el_geom + '</wfs:Name>';
 		str += '<wfs:Value>';
@@ -1533,13 +948,12 @@
 		str += '<gml:outerBoundaryIs>';
 			if(k>0){
 				str += " ";
@@ -1550,7 +964,7 @@
 		str += '</wfs:Value>';
-	//	str += '</' + el_geom + '>';
+//	str += '</' + el_geom + '>';
 	str += '<ogc:Filter>';
 	str += '<ogc:PropertyIsEqualTo>';
 	str += '<ogc:PropertyName>gid</ogc:PropertyName>';
@@ -1559,9 +973,11 @@
 	str += '</ogc:Filter>';
 	str += '</wfs:Update>';
+	//document.forms[1].filter.value = str;
 	//prompt("",str);
+	//document.forms[1].submit();
 	return false;
 function deleteGeom(m){
@@ -1570,24 +986,20 @@
 	var cnt = 0;
 			cnt++;
 	str += '<wfs:Delete typeName="'+ myconf['featuretype_name']+'">';
@@ -1596,7 +1008,6 @@
@@ -1605,38 +1016,20 @@
 	str += '</wfs:Delete>';
 	//prompt("",str);
 	return false;
 	</script>
 	</head>
-	<body onload="registerFunctions();displayButtons()">
-	<table cellpadding='0' cellspacing='0' align = center>
-	<tr>
-		<td>
-			<form name='dig'>
-			<table cellpadding='0' cellspacing='2'>
-				<tr>
-					<td><div id = 'divButtonPoint'></div></td>
-					<td><div id = 'divButtonLine'></div></td>
-					<td><div id = 'divButtonPolygon'></div></td>
-					<td>&nbsp;&nbsp;&nbsp;</td>
-					<td><div id = 'divButtonMove'></div></td>
-					<td><div id = 'divButtonInsert'></div></td>
-					<td><div id = 'divButtonDelete'></div></td>
-				</tr>
-			</table>
-			</form>
-		</td>
-	</tr>
-	</table>
-	<div id = 'listOfGeometries'></div>
-	<form name='sendForm' action='../extensions/geom2wfst.php' method='POST' TARGET='_blank'>
-		<input type='hidden' name='url'>
-		<input type='hidden' name='filter'>
-	</form>
+	<body onload="registerFunctions();displayButtons();">
+		<table cellpadding='0' cellspacing='0' align = center><tr><td><div id='digButtons'></div></td></tr></table>
+		<div id = 'listOfGeometries'></div>
+		<form name='sendForm' action='../extensions/geom2wfst.php' method='POST' TARGET='_blank'>
+			<input type='hidden' name='url'><input type='hidden' name='filter'>
+		</form>
 	</body>
-	</html>
\ No newline at end of file
+</html>
More information about the Mapbender_commits mailing list
