svn commit: r789 - trunk/mapbender/http/print/mod_printPDF.php
astrid_emde at osgeo.org astrid_emde at osgeo.org
Tue Oct 10 06:40:13 EDT 2006
Author: astrid_emde
Date: 2006-10-10 10:40:13+0000
New Revision: 789
WMS which are hidden, don't appear in the legend of the print anymore
Modified: trunk/mapbender/http/print/mod_printPDF.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/print/mod_printPDF.php?view=diff&rev=789&p1=trunk/mapbender/http/print/mod_printPDF.php&p2=trunk/mapbender/http/print/mod_printPDF.php&r1=788&r2=789
--- trunk/mapbender/http/print/mod_printPDF.php	(original)
+++ trunk/mapbender/http/print/mod_printPDF.php	2006-10-10 10:40:13+0000
@@ -89,98 +89,100 @@
 	for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
-		layers = pt.mb_checkScale(mod_legend_target,ind,i);
-		var layer = layers[0].split(",");
-		var title = layers[2].split(",");
-		var temp_legendurl = layers[3].split(",");
-		var layerparent= layers[4].split(",");
-		if( pt.mb_mapObj[ind].layers[i] != "" && pt.mb_mapObj[ind].layers[i]){
-		   if(i>0){
-		    document.forms[0].layers.value += "___";
-		    document.forms[0].wms_id.value += "___";
-		    document.forms[0].wms_title.value += "___";
-		    document.forms[0].legendurl.value += "___";
-			//document.forms[0].layers.value += pt.mb_mapObj[ind].wms[i].objLayer[ii].layer_title; //pt.mb_mapObj[ind].layers[i]	;
-			document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
-			document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
-			//---------- legendurl ----------
-			tmp_name = "";
-			for(var j=0; j<layer.length; j++){
-			 if(layerparent[j] == 0){
-				if(j>0){
-					document.forms[0].layers.value += ",";
+		if(pt.mb_mapObj[ind].wms[i].gui_wms_visible != 0){
+			layers = pt.mb_checkScale(mod_legend_target,ind,i);
+			var layer = layers[0].split(",");
+			var title = layers[2].split(",");
+			var temp_legendurl = layers[3].split(",");
+			var layerparent= layers[4].split(",");
+			if( pt.mb_mapObj[ind].layers[i] != "" && pt.mb_mapObj[ind].layers[i]){
+			   if(i>0 && document.forms[0].wms_id.value!=''){
+			    document.forms[0].layers.value += "___";
+			    document.forms[0].wms_id.value += "___";
+			    document.forms[0].wms_title.value += "___";
+			    document.forms[0].legendurl.value += "___";
-				var l = pt.mb_getchildsbyname(ind,i,layer[j]);
-			 	if (l) {
-			 		document.forms[0].layers.value += title[j];
-			 		if(j>0){
-						document.forms[0].legendurl.value += ",";
+				//document.forms[0].layers.value += pt.mb_mapObj[ind].wms[i].objLayer[ii].layer_title; //pt.mb_mapObj[ind].layers[i]	;
+				document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
+				document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
+				//---------- legendurl ----------
+				tmp_name = "";
+				for(var j=0; j<layer.length; j++){
+				 if(layerparent[j] == 0){
+					if(j>0){
+						document.forms[0].layers.value += ",";
-					for (var k=0; k<l["name"].length; k++){
-				 		if (tmp_name != l["title"][k]) {
-				 		    document.forms[0].layers.value += "*"
-				 			if(k>0){
-				 				 document.forms[0].legendurl.value += "*";
-				 			}else{
-				 				 document.forms[0].legendurl.value += '1*';
-							if (l["legendurl"][k] != '' || !l["legendurl"][k]==true){
-								document.forms[0].layers.value += l["name"][k];
-				  				document.forms[0].legendurl.value += l["legendurl"][k];
-							}else{
-								document.forms[0].layers.value += '0';
-								document.forms[0].legendurl.value += '0';
-							tmp_name = l["title"][k];
-				 		}	// if
-					 } // for var k=0
-				} // if (l)
-				else{
-					//prompt (!temp_legendurl[j] ,temp_legendurl[j] + !temp_legendurl[j]);
-						if(j>0){
+					var l = pt.mb_getchildsbyname(ind,i,layer[j]);
+				 	if (l) {
+				 		document.forms[0].layers.value += title[j];
+				 		if(j>0){
-						if (temp_legendurl[j]!= '' || !temp_legendurl[j] == 'true'){
-							document.forms[0].legendurl.value += temp_legendurl[j];
-						}else{
-							document.forms[0].legendurl.value +='0';
-				}// else (l)
-			   }//check parent==0
-			}//for var j=0
-			//document.forms[0].legendurl.value += layers[3];
+						for (var k=0; k<l["name"].length; k++){
+					 		if (tmp_name != l["title"][k]) {
+					 		    document.forms[0].layers.value += "*"
+					 			if(k>0){
+					 				 document.forms[0].legendurl.value += "*";
+					 			}else{
+					 				 document.forms[0].legendurl.value += '1*';
+								if (l["legendurl"][k] != '' || !l["legendurl"][k]==true){
+									document.forms[0].layers.value += l["name"][k];
+					  				document.forms[0].legendurl.value += l["legendurl"][k];
+								}else{
+									document.forms[0].layers.value += '0';
+									document.forms[0].legendurl.value += '0';
+								tmp_name = l["title"][k];
+					 		}	// if
+						 } // for var k=0
+					} // if (l)
+					else{
+						//prompt (!temp_legendurl[j] ,temp_legendurl[j] + !temp_legendurl[j]);
+							if(j>0){
+								document.forms[0].legendurl.value += ",";
+							if (temp_legendurl[j]!= '' || !temp_legendurl[j] == 'true'){
+								document.forms[0].legendurl.value += temp_legendurl[j];
+							}else{
+								document.forms[0].legendurl.value +='0';
+					}// else (l)
+				   }//check parent==0
+				}//for var j=0
-		} else{
-			 if(i>0){
+				//document.forms[0].legendurl.value += layers[3];
+			} else{
+				document.forms[0].layers.value += "0";
+			    document.forms[0].wms_id.value += "0";
+			    document.forms[0].wms_title.value += "0";
+			    document.forms[0].legendurl.value += "0";
-			document.forms[0].layers.value += "0";
-		    document.forms[0].wms_id.value += "0";
-		    document.forms[0].wms_title.value += "0";
-		    document.forms[0].legendurl.value += "0";
+		}//if
+	}//for
 function validate(){
More information about the Mapbender_commits mailing list
