[Mapbender-commits] r1270 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Apr 23 05:01:17 EDT 2007
Author: christoph
Date: 2007-04-23 05:01:17 -0400 (Mon, 23 Apr 2007)
New Revision: 1270
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
continuing a polygon as a line (and vice versa) disabled.
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2007-04-20 14:43:13 UTC (rev 1269)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2007-04-23 09:01:17 UTC (rev 1270)
@@ -480,23 +480,50 @@
 		executeDigitizePreFunctions();
 		obj.title = obj.title_on;
 		if (obj.id == button_point) {
+			if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
+				if (d.get(-1).geomType != parent.geomType.point) {
+					d.close();
+					executeDigitizeSubFunctions();
+				else {
+					s.add(d.getPoint(-1, -1, 0));
 			if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
 				d.addMember(parent.geomType.point);
 				d.get(-1).addGeometry();
 			else {
+// delete existing line or polygon
 				d.del(-1);
 		else if (obj.id == button_polygon) {
+				if (d.get(-1).geomType != parent.geomType.polygon) {
+					d.close();
+				else {
 				// new geometry
 				d.addMember(parent.geomType.polygon);
 			else {
+// continue a line as a polygon
 					var geometryTemplate = parent.cloneObject(d.get(-1));
 					d.del(-1);
@@ -509,14 +536,28 @@
 		else if (obj.id == button_line) {
+				if (d.get(-1).geomType != parent.geomType.line) {
+					d.close();
+				else {
 				d.addMember(parent.geomType.line);
 			else {
+// continue a polygon as a line
 					d.del(-1);
@@ -528,7 +569,7 @@
-				s.add(d.getPoint(-1, -1, 0));
 		else if (obj.id == button_clear) {
More information about the Mapbender_commits mailing list
