[Mapbender-commits] r1578 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 6 03:51:25 EDT 2007
Author: christoph
Date: 2007-08-06 03:51:25 -0400 (Mon, 06 Aug 2007)
New Revision: 1578
   trunk/mapbender/http/classes/class_gml.php
replaced old string functions by multibyte string function
Modified: trunk/mapbender/http/classes/class_gml.php
--- trunk/mapbender/http/classes/class_gml.php	2007-08-06 07:50:45 UTC (rev 1577)
+++ trunk/mapbender/http/classes/class_gml.php	2007-08-06 07:51:25 UTC (rev 1578)
@@ -112,7 +112,7 @@
 	function parseGml($index){
-		$data = str_replace("&", "&", $this->gml[$index]);
+		$data = preg_replace("&", "&", $this->gml[$index]);
 		$this->tagList = array_merge($this->multi, $this->pointSingle, $this->lineSingle, $this->polygonSingle);
@@ -137,32 +137,32 @@
 		foreach ($values as $element) {
-			if(strtoupper($element['tag']) == strtoupper("gml:featureMember") && $element['type'] == "open"){
+			if(mb_strtoupper($element['tag']) == mb_strtoupper("gml:featureMember") && $element['type'] == "open"){
 				$member = true;
-			if (in_array(strtoupper($element['tag']),$this->tagList) && $element['type'] == "open" && $member==true && $geom==false && $typeset==false) {
+			if (in_array(mb_strtoupper($element['tag']),$this->tagList) && $element['type'] == "open" && $member==true && $geom==false && $typeset==false) {
 				$this->geomColl[$index]->addGeometryMember($element['tag']);
 				$typeset=true;
-			if(in_array(strtoupper($element['tag']),$this->pointSingle) && $element['type'] == "open" && $typeset==true){
+			if(in_array(mb_strtoupper($element['tag']),$this->pointSingle) && $element['type'] == "open" && $typeset==true){
 				$foundGeom = true;
 				$geom = true;
 				$this->geomColl[$index]->addPoint();
-			if(in_array(strtoupper($element['tag']),$this->lineSingle) && $element['type'] == "open" && $typeset==true){
+			if(in_array(mb_strtoupper($element['tag']),$this->lineSingle) && $element['type'] == "open" && $typeset==true){
 				$foundGeom = true;
 				$geom = true;
 				$this->geomColl[$index]->addLine();
-			if(in_array(strtoupper($element['tag']),$this->polygonSingle) && $element['type'] == "open" && $typeset==true){
+			if(in_array(mb_strtoupper($element['tag']),$this->polygonSingle) && $element['type'] == "open" && $typeset==true){
 				$foundGeom = true;
 				$geom = true;
 				$this->geomColl[$index]->addPolygon();
-			if(strtoupper($element['tag']) == strtoupper("gml:coordinates") && $geom == true){
+			if(mb_strtoupper($element['tag']) == mb_strtoupper("gml:coordinates") && $geom == true){
 				$myGeom = $this->prepareCoordinates($element['value']);
 				$coord = explode(",",$myGeom);
 				for($i=0;$i<count($coord)-1; $i += 2){
@@ -171,22 +171,22 @@
-			if(strtoupper($element['tag']) == strtoupper("label")){
+			if(mb_strtoupper($element['tag']) == mb_strtoupper("label")){
 				$this->geomColl[$index]->addLabel($element['value']);
-			if ($foundGeom == true && $geom == false && substr($element['tag'], 0, 4) != "gml:" && isset($element['value'])) {
+			if ($foundGeom == true && $geom == false && mb_substr($element['tag'], 0, 4) != "gml:" && isset($element['value'])) {
 				$this->geomColl[$index]->addAttribute($element['tag'], $element['value']);
-			if((in_array(strtoupper($element['tag']),$this->pointSingle)
-					|| in_array(strtoupper($element['tag']),$this->lineSingle)
-					|| in_array(strtoupper($element['tag']),$this->polygonSingle))
+			if((in_array(mb_strtoupper($element['tag']),$this->pointSingle)
+					|| in_array(mb_strtoupper($element['tag']),$this->lineSingle)
+					|| in_array(mb_strtoupper($element['tag']),$this->polygonSingle))
 				&& $element['type'] == "close"){
 				$geom = false;
-			if(strtoupper($element['tag']) == strtoupper("gml:featureMember") && $element['type'] == "close"){
+			if(mb_strtoupper($element['tag']) == mb_strtoupper("gml:featureMember") && $element['type'] == "close"){
 				$member = false;
 				$foundGeom = false;
 				$typeset=false;
@@ -200,7 +200,7 @@
 	// and sets the bbox according to these values
 	// if found it very useful for testing the png output, but now it may be obsolete
 	function parseBbox($gmlIndex, $gml){
-		$data = str_replace("&", "&amp;", $gml);
+		$data = preg_replace("&", "&amp;", $gml);
 		$parser = xml_parser_create();
 		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
@@ -221,16 +221,16 @@
 		$max_y = "";
 				$cnt_member=true;
-				|| in_array(strtoupper($element['tag']),$this->polygonSingle)) && $element['type'] == "open"){
+				|| in_array(mb_strtoupper($element['tag']),$this->polygonSingle)) && $element['type'] == "open"){
 				$boundingbox=true;
-			if(strtoupper($element['tag']) == strtoupper("gml:coordinates") && $boundingbox == true){
+			if(mb_strtoupper($element['tag']) == mb_strtoupper("gml:coordinates") && $boundingbox == true){
@@ -249,12 +249,12 @@
-				|| in_array(strtoupper($element['tag']),$this->polygonSingle)) && $element['type'] == "close"){
+				|| in_array(mb_strtoupper($element['tag']),$this->polygonSingle)) && $element['type'] == "close"){
 				$boundingbox = false;
 				$cnt_member=false;
More information about the Mapbender_commits mailing list
