[Mapbender-commits] r1579 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 6 03:52:14 EDT 2007
Author: christoph
Date: 2007-08-06 03:52:14 -0400 (Mon, 06 Aug 2007)
New Revision: 1579
   trunk/mapbender/http/classes/class_gml2.php
replaced old string functions by multibyte string function
Modified: trunk/mapbender/http/classes/class_gml2.php
--- trunk/mapbender/http/classes/class_gml2.php	2007-08-06 07:51:25 UTC (rev 1578)
+++ trunk/mapbender/http/classes/class_gml2.php	2007-08-06 07:52:14 UTC (rev 1579)
@@ -66,16 +66,16 @@
 		xml_parser_free($parser);
 		foreach ($values as $element) {
-			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("boundedBy") && $element[type] == "open"){
+			if(mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("boundedBy") && $element[type] == "open"){
 				$boundedBy = true;
 			if ($boundedBy) {
-				if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")){
-					$this->bbox = explode(",", str_replace(",,","",str_replace(" ",",",trim($element[value]))));
+				if(mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("coordinates")){
+					$this->bbox = explode(",", preg_replace(",,","",preg_replace(" ",",",trim($element[value]))));
 					$boundedBy=false;
-			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "open"){
+			if(mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("featureMember") && $element[type] == "open"){
 				$this->member++;
 				$this->keys[$this->member] = array();
 				$this->value[$this->member] = array();
@@ -93,15 +93,15 @@
 					$geom = false;
 				if($geom == true){
-					if (strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")) {
-						$this->geometry[$this->member][$cnt_geom] =  str_replace(",,","",str_replace(" ",",",trim($element[value])));
+					if (mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("coordinates")) {
+						$this->geometry[$this->member][$cnt_geom] =  preg_replace(",,","",preg_replace(" ",",",trim($element[value])));
 						$coordinates = true;
 						// XXX: Increment counter to get all geometries of a feature member,
 						// comment it out to only show first geometry of featuremember
 						$cnt_geom++;
 					else if (!$coordinates && trim($element[value])) {
-						$coords = str_replace(",,","",str_replace(" ",",",trim($element[value])));
+						$coords = preg_replace(",,","",preg_replace(" ",",",trim($element[value])));
 						$tmp_array = explode(",", $coords);
 						if (count($tmp_array > 1)) {
 							$this->geometry[$this->member][$cnt_geom] =  $coords;
@@ -112,7 +112,7 @@
-				else if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "close"){
+				else if(mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("featureMember") && $element[type] == "close"){
 					$section = false;
 					$el = -1;
@@ -126,9 +126,9 @@
 	function sepNameSpace($s){
-		$c = strpos($s,":");
+		$c = mb_strpos($s,":");
 		if($c>0){
-			return substr($s,$c+1);
+			return mb_substr($s,$c+1);
 		else{
 			return $s;
More information about the Mapbender_commits mailing list
