[Mapbender-commits] r1601 - trunk/mapbender/http/tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 6 04:30:31 EDT 2007
Author: christoph
Date: 2007-08-06 04:30:31 -0400 (Mon, 06 Aug 2007)
New Revision: 1601
   trunk/mapbender/http/tools/mapFiler.php
   trunk/mapbender/http/tools/send_post.php
replaced old string functions by multibyte string function
Modified: trunk/mapbender/http/tools/mapFiler.php
--- trunk/mapbender/http/tools/mapFiler.php	2007-08-06 08:29:39 UTC (rev 1600)
+++ trunk/mapbender/http/tools/mapFiler.php	2007-08-06 08:30:31 UTC (rev 1601)
@@ -48,8 +48,8 @@
 function modify($myDir, $myFile){
 	global $factor;
-	$myContent = fopen($myDir."/".$myFile, "r") or die("Datei " . $myDir . " / ". $myFile ." konnte nicht zum Lesen geöffnet werden!");
-	$myNewContent = fopen($myDir."/".str_replace(".","_".$factor.".",$myFile), "w") or die("Datei " . $myDir . " / ". str_replace(".","_".$factor.".",$myFile) ." konnte nicht zum Schreiben geöffnet werden!");
+	$myContent = fopen($myDir."/".$myFile, "r") or die("Datei " . $myDir . " / ". $myFile ." konnte nicht zum Lesen ge�ffnet werden!");
+	$myNewContent = fopen($myDir."/".preg_replace(".","_".$factor.".",$myFile), "w") or die("Datei " . $myDir . " / ". preg_replace(".","_".$factor.".",$myFile) ." konnte nicht zum Schreiben ge�ffnet werden!");
 	fputs($myNewContent, "#Modified by MapbenderTools" . "\n");
 	fputs($myNewContent, "#Date: ". date("d.m.Y") . "\n");
 	fputs($myNewContent, "#Factor: ". $factor . "\n\n");
@@ -58,7 +58,7 @@
 		$myLine = fgets($myContent, 1024);
 		if(preg_match("/\bSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
 			if(count($matches) <= 2){
-				fputs($myNewContent, str_replace($matches[1], multiplicate($matches[1]), $myLine));
+				fputs($myNewContent, preg_replace($matches[1], multiplicate($matches[1]), $myLine));
 		else if(preg_match("/(.*OFFSET)\s*(\d+.?\d*)(\s*)(\d+.?\d*)(\s*)/i",$myLine,$matches)){
@@ -67,19 +67,19 @@
 		else if(preg_match("/\bMAXSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
 		else if(preg_match("/\bMINSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
 		else if(preg_match("/\bSYMBOLSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
 			fputs($myNewContent, "# ". $myLine);
 		else if(preg_match("/\bSYMBOLSET\s*(.*)/i",$myLine,$matches)){ //noch nicht fertig
-			$arraySymbolFiles[$countSymbolsFiles] = str_replace("\"","",$matches[1]);
+			$arraySymbolFiles[$countSymbolsFiles] = preg_replace("\"","",$matches[1]);
 			$countSymbolsFiles++;
 			fputs($myNewContent, $myLine);
@@ -101,7 +101,10 @@
 	# what is to do...
 	$myFile = basename($myLocation);
 	$myDir = dirname($myLocation);
-	$suffix = strstr($myFile, ".");
+	$suffix = "";
+	if (mb_strpos($myFile, ".") !== false) {
+		$suffix = mb_substr($myFile, mb_strpos($myFile, "."));
 	if(!isset($dir)){
Modified: trunk/mapbender/http/tools/send_post.php
--- trunk/mapbender/http/tools/send_post.php	2007-08-06 08:29:39 UTC (rev 1600)
+++ trunk/mapbender/http/tools/send_post.php	2007-08-06 08:30:31 UTC (rev 1601)
@@ -51,7 +51,7 @@
     if (empty($method)) {
         $method = 'POST';
-    $method = strtoupper($method);
+    $method = mb_strtoupper($method);
     $fp = fsockopen($host, $port);
     fputs($fp, "$method $path HTTP/1.1\r\n");
     fputs($fp, "Host: $host\r\n");
More information about the Mapbender_commits mailing list
